11-13-2016, 10:41 PM | #1 |
Rep 2,357
Pure Stage 2 - Torque specs
Hi
I am planning on doing my swap next weekend. Could someone spend a few minutes in ISTA helping me translate these torque specs? 11 53 (4 and 10)AZ 11 42 (4,6 and 7)AZ 11 65 (1,2,4,8 and 9)AZ 11 22 (1,2 and 3)AZ Thanks a bunch!
(A Dane in China) |
11-15-2016, 07:40 PM | #2 |
Rep 314
11 53:
4AZ Feed line to crankcase. N55 M6x16 8.5 Nm 10AZ Radiator supply and drain line to exhaust turbocharger N55 M6 x 16 8 Nm 11 42: 4AZ Oil feed line (exhaust turbocharger) to crankcase-upper part. N55 M6x16 8 Nm 6AZ Oil return line to turbocharger N55 M6 x 16 8 Nm 7AZ Oil return line to crankcase bottom section N55 M6 x 16 8 Nm 11 65: 1AZ Exhaust turbocharger to cylinder head N55 M7 Replace flange nut. 13 Nm 2AZ Heat shield/retaining plate to crankcase top section N55 M6 x 16 8 Nm 4AZ Pressure converter (EPDW) to holder with heat shield. N55 M6 x 16 9 Nm 8AZ Holder to exhaust turbocharger. N55 M8 20 Nm 9AZ Exhaust turbocharger holder to cylinder crankcase. N55 M8 Replace micro-encapsulated screws 20 Nm 11 22: 1AZ Flywheel to crankshaft (automatic transmission) N55 M12x 19 Replace screws 1. Jointing torque 60 Nm 2. Final tightening 45 ° 2AZ DM flywheel to crankshaft (manual transmission) N55 M12x 25 Replace screw 1. Jointing torque 60 Nm 2. Final tightening 45 ° There's no 11 22 3AZ in the document |
ronanz1819.50 |
