BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 Wheel Fitment Cheat Sheet
      02-22-2021, 09:10 AM   #23
Bradyt40
Drives: BMW 335i F30
So the question I have I think is pretty simple but want other BMW guys to chime in. So currently I am running the style 361 in 20x8 et 36 in the front and 20x8.5 et 47 in the rear with 265/30zr20 all around. I don’t have any rubbing issues or anything at the moment. I bought the car like this and not sure if it has been lowered at all. I like the height and wheel well space just fine. I want a more meaty tire and was looking at going with 18x9 up front with et 35 or something close and 235/45zr18 up front (26.3 x 9.3 tire) and 18x10 in the rear et 45 with a 265/40zr18 in the rear (26.3 x 10.4 tire) these tires match up height wise with my current ones and the front tires are 9.3 vs 10.4 wide on my current ones. I would think I would be perfectly fine but just want to verify this. Any thoughts?
      02-26-2021, 10:38 AM   #24
El Lechero
Drives: BMW 435i F32
Hey guys, I have a F32 435i. Was curious with others experiences with fitment. It's currently stock suspension. I'm personally looking for (idk the proper terminology) the wheel and tire to be flush with the fender with no rubbing. Eventually plan on lowering with coilovers. Just seeing what people's thoughts are on going wide like the examples listed or should I stick to thinner wheels? I've been looking at rohana rfx11s front 19x8.5 and rear 19x9.5. Any suggestions? Thanks!
      02-26-2021, 10:47 AM   #25
LJG92
England
Drives: BMW 420d grand coupe
Originally Posted by not.ramos View Post
Hey guys!
I'm kind of tired of people being "gate-keepers" for wheel-fitment, so I figured I'd give other forum-members an easy way out.
For reference, I have NO fender-work, stock camber arms, and on AirLift 3P suspension. I will be going to KW's this weekend so I'll modify this post as needed.
For each spec, play with camber as needed. For most of these I held -2.2 to -2.5 camber all around. Being on coilovers and air suspension is recommended just to get the right fitment.
My recommended tire is Achilles ATR Sport 2, some sizes offered may vary, I get mine from Walmart and Amazon. These tires stretch well, hold PSI, have good grip in both wet and dry conditions, and most importantly - they are CHEAP! However, relative to other tires, they are slightly stiffer and louder as you should expect from a tire from this price point. I've had 6 (soon to be 7) sets of wheels within the last 18-24 months and I have ran Achilles on all of them at one point.
Fender To Lip:
19x10 +10
19x11 +30
215/35/19
245/35/19
Aggressive (My Favorite Setup!):
19x9.5 +15
19x10.5 +35
235/35/19
265/30/19
Aggressive (Square):
19x10 +20
245/35/19
or
18x10 +25
255/40/18
Meaty Tire:
19 or 18x8.5 +35
19 or 18x9.5 +35
245/40/19 or 18
275/35/19 or 18
I hope this helps those looking for the "right" fitment. Adjust any sizes to your liking. If you are curious how the following sizes may fit or compare to your current wheels, click here! Any others with wheel/tire recommendations, feel free to reply.
NOTE: If you are on air suspension, take into account that your front air strut extends 15-20 mm passed the normal spring distance. In other words, running the meaty setup I mentioned prior may rub your bag and pop it (happened to me!). PM me on here or DM me on Instagram: @brandon_rramos so I can help you out!
Very helpful thank you !!
      02-26-2021, 11:22 PM   #26
not.ramos
Enthusiast
not.ramos's Avatar
Drives: 6MT M2C
That's the basic spec, if you want to be a little more aggressive do 19x9.5 +35 square with a 255/35/19.
IG: brandon_rramos
ULTRA MOTORSPORTS
      03-10-2021, 04:38 PM   #27
Galip1993
Drives: dodge challenger srt 392
Hello guys, just about to pull the trigger on some wheels but wanted to know if the size 18x9.5 +27 square wheel setup would fit with maybe 255/40/18 tires all round lowered with a basic set of springs?
      11-13-2021, 06:30 PM   #28
harmz
Drives: 430d Gran Coupe & 530D LCI
Hi mate
The bbs rsii look amazing!! So I have recently picked up a set of bbs rs793 which I want to build for my f36, assuming the similarities between the f30 and f36 for fitment! But what size lips and barrels did you run ? Any help would be appreciated
      11-21-2021, 02:39 PM   #29
gioangelo
Drives: 2014 BMW 328i RWD
As mentioned above, here is my favorite setup!
BBS RS-ii (RS714)
19x9.5 +15
19x10.5 +35
215/35/19
245/35/19
AirLift 3P Suspension w/ -2.2 camber all around
Would I be able to run 19x9.5 +35 and 19x10.5 +35 if I am on lowering springs on my F30? Would that even look good?
      11-22-2021, 08:08 AM   #30
_baz
_baz's Avatar
Drives: F30 330e
I really think you'll struggle with inner clearance up front with a 9.5 ET35
      12-01-2021, 12:55 AM   #31
not.ramos
Enthusiast
not.ramos's Avatar
Drives: 6MT M2C
You can but it may poke out with stock camber.
IG: brandon_rramos
ULTRA MOTORSPORTS
      11-15-2022, 01:41 PM   #32
Ammy340i
Drives: BMW 340i
Will 19x10 ET 20 fit in the rear of my f30 BMW 340i?
Amrit Singh
      11-17-2022, 07:54 PM   #33
Lozza47
Lozza47's Avatar
38
Drives: 2013 F30 335i / 2011 E92 M3
I just bought 9.5 + 38 wheels square on 255/40/18. Seems doable with a front spacer so just sorting that out as we speak. Then a bit of a camber to look flush and it'll be quite aggressive. I'm hoping
2011 E92 M3 - Mineral White - Pure Edition I
      01-20-2024, 11:29 AM   #34
mprotacio
Drives: 2017 440i xdrive
Hey guys!
Fender To Lip:
19x10 +10
19x11 +30
215/35/19
245/35/19
19x9.5 +15
19x10.5 +35
235/35/19
265/30/19
19x10 +20
245/35/19
or
18x10 +25
255/40/18
Meaty Tire:
19 or 18x8.5 +35
19 or 18x9.5 +35
245/40/19 or 18
275/35/19 or 18
I hope this helps those looking for the "right" fitment. Adjust any sizes to your liking. If you are curious how the [...]
I have a 440i drive and I was planning on going with H&R sport springs, was wondering if the Agressive 19” squared setup would work in terms of not rubbing after lowering?
I’m currently on my winter setup with 255/35/19 et 35 squared and I’m rubbing on full lock out without being lowered, I’m sure it’ll get worst when I do lower the car. Unless i run spacers? (Somewhat new to the whole fitment thing)
Thanks in advance!
      01-22-2024, 02:13 PM   #35
not.ramos
Enthusiast
not.ramos's Avatar
Drives: 6MT M2C
Consider running 18 or 19x9.5 ET +38 with a 245/35/18 and it should be fine on springs. You may need a small spacer up front to clear the spring
IG: brandon_rramos
ULTRA MOTORSPORTS
      02-19-2024, 11:20 AM   #36
Erock8485
Drives: 2013 BMW 328i Xdrive (Stock)
Can I install 225/45R18 on 18x8.0 ET34 (OEM RIM PN 7845880) on the front and 255/40R18 on 18x8.5 ET47 (OEM RIM PN 7845881)on the rear of my 2013 328i xDrive (Non Msport)
      02-27-2024, 12:01 PM   #37
hairy65
Drives: BMW 335d xdrive
Will a 20x9j with an offset of et38 square set up fit a 335d xdrive? Car is totally standard.
aggressive, fender to lip, fitment, meaty, wheel and tire, wheel sizes
