02-03-2022, 03:04 AM | #1 |
Rep 220
F30 335i with 18x9.5 +33 and 255/35R18 square
Wasn’t sure if this would fit. But my rims and tyres finally arrived and I was able to pop them on. I think fitment is excellent, may have been able to go slightly more aggressive in the front but I wouldn’t bother.
There’s maybe 2-3mm clearance between wheel and strut Looking straight down there is no poke, and there is maybe only 1-2mm of tuck. This is with KW V3 coilovers, 2.4 degrees front camber and 2 degrees rear. Wheels are 18x9.5 +33 no spacers - GTC Wheels GT-CX wheels which I believe are exactly the same as the VMR V710 (same factory just rebranded) Tyres are 255/35R18 semi slicks (tyre size is a bit small as they didn’t come in 255/40) This is a RWD Last edited by Tobz_au; 02-03-2022 at 04:19 AM.. |
03-06-2024, 06:54 AM | #3 | |
Rep 3,947
I'm on a square setup of ARC8 18x8.5 ET38 and 255/40/18. I think the ideal track setup would be something like a square setup of 18x9.5 ET 35 with 275/35/18 tires. The challenge will be clearing the front coilovers. |
alohasurftoad3078.00 |
