01-15-2018, 06:34 AM | #12851 |
Rep 40,789
PM sent.
01-17-2018, 12:57 PM | #12852 |
Rep 152
Drives: 2015 435i Gran Coupe
How do I find the default settings for AC system for turning on when car is started.
I can't find that anywhere. Currently the car won't turn off the ac upon start. After a few minutes, the AC button will flash and that point the air can be turned off. Also, the MAX AC button does not do anything anymore. |
01-17-2018, 01:04 PM | #12853 | |
Rep 8,364
01-17-2018, 01:28 PM | #12854 |
Rep 152
So the only 2 are
3002- Memory_Off nicht-aktiv 3003 - MEMORY_UMLUFT nicht_aktiv When using bimmercode, there were 3 options AC on with auto : Default for this? AC Memory: Default for this? AC circulation setting memory: Default for this? Thanks for the quick response! |
01-17-2018, 01:55 PM | #12855 | |
Rep 8,364
Usually, MEMORY_UMLUFT and MEMORY_OFF are set to nicht_aktiv from factory. AC_ON_WITH_AUTO to aktiv. You can set them however you want depending on desired behavior. |
01-17-2018, 03:09 PM | #12856 | |
Rep 152
Upon changing the Air Condition Memory : it looks as the simple and expert are in conflict. When I change in expert, the opposite results in simple and vice versa. End result is that AC won't turn off, MAX AC is not functioning Thoughts on what i should do next? |
01-17-2018, 03:16 PM | #12857 | |
Rep 8,364
01-17-2018, 03:23 PM | #12858 |
Rep 152
01-17-2018, 05:36 PM | #12860 |
Rep 40,789
PM sent.
01-17-2018, 06:07 PM | #12861 |
Rep 152
01-19-2018, 07:03 AM | #12863 |
Rep 40,789
PM sent.
01-19-2018, 06:11 PM | #12865 |
Rep 40,789
PM sent.
01-20-2018, 03:15 PM | #12867 |
Rep 8,364
01-20-2018, 06:18 PM | #12868 |
Rep 2
Drives: BMW 335i 2012
Hi,
Does anyone know if you need Launcher Pro to code the auto start/stop function? I read in one of TokenMaster's post that you don't actually need a token to change this setting. I believe its the VO coding. Also, thanks to Shawn for sharing the Esys files. You do a great job buddy! |
01-20-2018, 06:25 PM | #12869 | |
Rep 40,789
01-20-2018, 06:29 PM | #12870 |
Rep 740
Can I get a link to latest esys for psdzdata 63?
Also, to upgrade, I believe I read that I have to delete the current esys, is that correct or can I just upgrade? Thanks!!
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
