11-07-2013, 06:18 PM | #1 |
Rep 149
n20 stage 1 CEL light
I just installed my burger tuning stage1 box yesterday.I have 2012 f30 328i and today i have a check engine light. I hooked my obdII scanner to my car to read error. I can not connect. i think i remember seeing something about this box blocks the obdII connection. how can i find out this code on my car.
Thanks Aaron |
11-07-2013, 10:13 PM | #3 |
Rep 149
i found the code p0440 evap error. This is not a stage one issue. I am trying to reset but my scanner will not reset this code for some reason.
11-08-2013, 11:22 AM | #4 |
Rep 127
Try uninstalling the BMS. Clear the code. Drive for a bit and see if the code returns. If it doesn't return re-install the BMS. Let us know how it goes.
11-09-2013, 07:14 PM | #6 |
Rep 149
Correct. If u change to map 0 you can read codes thru obdii port. I'm not sure you can write thru that port. I can read this code but cannot reset it. I need to uninstall the bms and try to reset with my reader.
12-05-2013, 05:47 PM | #7 |
Rep 149
ok so i removed stage one and cleared my cel p0440 code. drove for a couple of days no CEL. I then installed the stage one again and after about a day I got the CEL again p0440. WTH! I wonder what is causing this.
12-06-2013, 08:19 AM | #13 |
Rep 389
I did a quick search for some ideas. I am sure you may know this but you could try looking at you gas cap.Good luck man and keep us updated
Read more at: http://www.obd-codes.com/p0440 Copyright © OBD-Codes.com |
05-07-2014, 02:16 PM | #14 |
Rep 149
so i finally got around to installing my used bms stage 1 for my n26 back in. I ran 2000 plus mile and no CEL and then all of sudden I get the CEL. P0440 EVAP erro. I had to clear CEL.....after about 200 miles.... CEL back same error. I wonder if I got a bad USED stage 1 from a seller on here?
05-07-2014, 02:25 PM | #15 | |
Rep 1,232
05-08-2014, 06:48 AM | #16 |
Rep 149
Originally I put it by the master cylinder as stated in the directions. I found it did indeed did get very wet. I took it out for a couple of months. I put it back in wrapped in a rubber glove and zipped tied it in a different spot.....no water got to it this time. BMS is saying i need to send them a bmw specific code (six digit). they suggest I buy some 150.00 cable to read my code. F that.
05-13-2014, 04:19 PM | #18 |
Rep 149
if you are asking if stage 1 is causing this issue then yes I am sure. everytime i run the bms stage one. I get this p0440 evap CEL. if I reset and remove bms I do not get this CEL ever. I stopped running the bms stage one for months and just started again running the bms stage one and CEL is back with same code. |
05-13-2014, 04:47 PM | #19 | |
Rep 115,980
Something to try though, leave the blue patch stock as is done for the electronic wastegate. There was an older DME version that ran better that way. Mike |
05-13-2014, 05:32 PM | #20 | |
Rep 1,436
05-21-2014, 06:58 AM | #21 | |
Rep 149
you can read codes by changing the map to "0". |
