05-22-2014, 04:05 AM | #1 |
Rep 3
bms stage 1 320i
Hi,
Im thinking about installing bms stage 1 to my f30 320i (all stock). Will the torque gain also reach at 1250 rpm and flat to 5k rpm like stock 320i? ( I am using octane 91 fuel) I read somewhere that power delivery in stage 2 is smoother like stock power. But I don't dare to tap wires as needed in stage 2. Will BMS make a full plug and play socket for stage 2 like it is on stage 1? Thanks, |
05-26-2014, 03:37 PM | #2 | |
Rep 190,807
05-28-2014, 12:43 AM | #3 |
Rep 3
Thanks Mike,
I like stage 2 but worry about needing to tap can wires. a. Will the wires be okay if I uninstall and reinstall about 2 or 3 times a year for services? b. Do you have picture of the can wires after uninstallation of stage 2? Stage 1 is safer by only using plug and play socket.. IMO.. Btw, if I run octane 91 (92 RON) .. is it safe to use BMS? Or should I go with 95RON.. it is the max RON that I can get locally. Cheers |
05-28-2014, 01:02 AM | #4 | |
Rep 190,807
You are good to uninstall it as many times as you like. If you feel it is going to be a lot of trouble, just go with stage 1 it will give you a nice increase in boost. As for the octane, as long as your fuel equals 91 octane you can use BMS products.
