03-08-2017, 08:52 PM | #1411 | |
Rep 8,364
FlorinQCK-2.50 |
03-27-2017, 12:14 PM | #1412 |
Rep 4
erro fsc
Good afternoon
I am trying to update the maps of a BMW S1 2010, but when trying to read the fsc code with SWID_reader 1B it gives the IFH-0009 error. The communication seems to be okay because it does not give a mistake when the call reads well the vin, and I even managed to change the language of cic. Thank you in advance for your help. |
FlorinQCK-2.50 |
03-27-2017, 12:17 PM | #1413 | |
Rep 40,737
FlorinQCK-2.50 |
03-27-2017, 02:04 PM | #1417 |
Rep 40,737
I wrote above that ENET is only for F/I/G Series cars, and that E-Series car must use DCAN Cable or ICOM Interface in this case, so I am lost as to why you then ask me if you can connect to E-Series car with ENET. No, you cannot. ENET Cable will not work for E-Series.
FlorinQCK-2.50 |
03-27-2017, 02:25 PM | #1418 |
Rep 4
erro fsc
I'm sorry if I did not tell you, but my English is bad, and it's the first time I'm trying to update the maps in a BMW.
With a k+dcan cable I can connect with ICOM, if possibile can explain how. Thank you in advance for your help. |
FlorinQCK-2.50 |
03-27-2017, 02:28 PM | #1419 |
Rep 40,737
DCAN Cable is not possible to pull 1B. You must use an ICOM Interface. That means buying a very expensive ICOM Interface, then configuring EDIABAS to use ICOM, then read 1B with SWID Reader. For map update only, ICOM is not worth the cost.
FlorinQCK-2.50 |
03-29-2017, 03:57 AM | #1420 |
Rep 19
Hi, i’m having problems when i run the FSc Generator.exe - i get a Microsoft.NET Framework error saying i’m getting an unhandled exemption with the following error
“Road is an unexpected token Expecting White Space. Line 815, Position 75” if i continue rather than quit, i can brows to my FSC file but the map list is empty. Any ideas? Ive attached my FSC file if anyone can help out, just rename to fsc please. I want generate fsc code to update my map to Next Europe 2017-1. Thanks Last edited by PSILVA; 03-29-2017 at 04:28 AM.. |
FlorinQCK-2.50 |
04-02-2017, 11:25 AM | #1421 | |
Rep 19
Thanks |
FlorinQCK-2.50 |
04-02-2017, 06:38 PM | #1424 |
Rep 10
wrong code ?!
I am trying to update a CIC on a E60 but it keeps telling me that the inserted code is incorrect.
Since this is a retrofitted unit, i'm not sure where's the problem (hardware/software/code). Could someone confirm that the code for Europe West Premium 2017-1 for this 1B is: CGBBG4OOFQKQOABIAAUQ thank you for your time! |
FlorinQCK-2.50 |
04-02-2017, 06:59 PM | #1425 | |
Rep 8,364
FlorinQCK-2.50 |
04-02-2017, 07:04 PM | #1426 | |
Rep 10
That is correct. i activated cic via script. already did this on another car and the update went smooth (although thhis one was not a retrofit, only a replacement for a used unit). Edit: What do you mean by "likely need to be done the same way" ? Last edited by sergiompais; 04-03-2017 at 03:27 AM.. |
FlorinQCK-2.50 |
04-09-2017, 10:33 AM | #1427 |
Rep 152
I downloaded the latest US 2017 map version 2.. Do I need the code? there was few post mentioned that code isn't necessary.
my last 7 digits are 0H24949 2014 X5 xDrive35i can someone help me with the code? Thanks in advance
Jeff
Current Ride - 2016 Toyota RAV4 Hybrid - 2014 X5 xDrive35 M - 2013 ML-350 (Gone) - 2012 Audi Q7 TDI (Gone) |
FlorinQCK-2.50 |
04-10-2017, 02:46 AM | #1430 |
Rep 3
F30 Na 2017-1
Trying to update CIC to North America Premium 2017-1 on F30.
Got everything up until I try to get code.txt, the file ends up being empty. My fsc.bat file uses 0x2D and 0x29 for region and 2017-1. Then in command I type fsc.exe FX99805.fsc 0x2d 0x29 FX99805 Any ideas why I can't come up with a code? My .fsc file is attached (change .pdf to .fsc). Thanks! |
FlorinQCK-2.50 |
