BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Winter wheel help, TPMS
      10-24-2014, 06:05 PM   #1
F30MSport
F30MSport's Avatar
Drives: 2016 Alpine White M3 6MT
Hoping someone can help me out, I am currently running an aftermarket wheel/tire setup and had used my oem TPMS sensors from my stock wheels. To avoid having to keep swapping the sensors I wanted to purchase new bmw sensors and use. Seemed simple enough but I was told by a tire shop that the sensors would need to be calibrated, so every time I swapped the wheel setup I would get a tire light unless I pay to have the sensors calibrated to the car. Made it appear that the car couldn't recognize two different sets of sensors.
Is this true? What's the best approach here I am not trying to ride around with the tire light and want to be able to separate the wheels/tires myself come spring.
Thanks!
Alpine White '16 M3 6MT
      10-24-2014, 07:13 PM   #2
34.50
34.50's Avatar
Drives: 2013 335i xDrive Sport Line
I think the shop is trying to rip you off - it's easy enough to recalibrate the sensors after you install your new wheels/tires. It's done in the iDrive menu for TPMS...
2013 BMW 335i xDrive Sport Line
      10-24-2014, 09:04 PM   #3
Fronzdan
Drives: '24 M240 xDrive
Yeah not sure if they are talking about something special. But fill your tires to the proper pressure as measured by a pressure gauge. Then go into iDrive and reset the calibration. That's it.
      10-25-2014, 12:15 AM   #4
F30MSport
F30MSport's Avatar
That sob! I figured it was easy enough. Thanks guys
      10-27-2014, 05:51 PM   #5
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
You said the calibration was to avoid getting a light.. You will get the tire light every time you switch. But as others said, it's not a big deal to reset it. Not sure if what calibration they're talking about though. On tire rack, they tell you to do it through iDrive, no mention of any alternative...
      10-28-2014, 01:10 PM   #6
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
That tire shop is wrong. The sensors are auto re-learn. with that in mind, it will be cheaper in the long run to just purchase a set of sensors and leave them mounted to the winter wheels, as opposed to the cost of dismounting tires for 2 sets twice a year.
      10-29-2014, 12:45 PM   #7
bmw-again
bmw-again's Avatar
Drives: 17 440xi GC-15 X1 xline
Just switched summer to winter yesterday and I have two sets of sensors. Go into menu and click reset TPMS. Takes about 30 seconds maybe. They are trying to rip you off!
      10-30-2014, 09:30 PM   #8
F30MSport
F30MSport's Avatar
Thanks all I appreciate the reply's. Swapping sensors and looking to purchase a second set for spring
