09-06-2013, 09:39 PM | #4555 | |
Rep 8
hello i am having this issues as well.. my "connection via VIN" is grayed out.. please help idk what dll to register.. thanks |
09-06-2013, 09:57 PM | #4556 |
Rep 40,725
Do you show any targets in the connection window?
09-06-2013, 10:12 PM | #4557 |
Rep 8
[QUOTE=shawnsheridan;14626457]Do you show any targets in the connection window?[/QUOTE
I'm really sorry, I am new to this do you mean in the ZGW_SEARCH? when i try to run that program i get an error..: a file is missing or invalid i am gonna reinstall eysy |
09-06-2013, 10:15 PM | #4558 | |
Rep 40,725
[QUOTE=Abbas;14626491]
You need to register MSWINSCK.ocx to your OS. From the Command Line, enter: regsvr32 /u "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX" regsvr32 "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX" But ZGWSearch is informational only, and nonfunctional, so it is not even needed to run E-Sys. You can register the .OCX and use it, or not use it at all. Your choice.
09-07-2013, 12:42 PM | #4559 | |
Rep 8
[QUOTE=shawnsheridan;14626506]
thanks shawnsheridan! I was using my .gov work laptop which has a lot of restrictions through gpo or whatever.. I have administrative rights but i wasn't able to disable the windows firewall. After registering the .ocx on my personal laptop I was able to see the connection ZGWSearch. hopefully I'm almost there.. I gonna try to code code my loaner F30 today.. lol Thank you thanks thx |
09-07-2013, 01:14 PM | #4560 |
Rep 258
Right, I have now coded 6NS successfully into the car, then tried unpairing and re-pairing my phones but no streaming services or telephone 1/2 as yet.
Do I need to wait a couple of hours for this to spring into life as per some of the other coding options? |
09-07-2013, 02:16 PM | #4561 |
Rep 88
You have to go into the options of the phone in iDrive and select which options to use.
I think there are 4, 1st phone Data Music ... Only after setting the music option is it possible to stream music. with android its good, as soon as the phone connects, it starts the music app. Even starts TuneIn automatically. |
09-07-2013, 02:32 PM | #4562 | |
Rep 40,725
[QUOTE=Abbas;14628443]
09-07-2013, 03:16 PM | #4563 | |
Rep 258
I'm trying both my Nexus 4 and an iPhone 4s, so I'm sure the phones themselves are not at fault. |
09-08-2013, 02:14 AM | #4564 |
Rep 31
Hi guys,
After a software update yesterday to fix some gearbox issues, they had reset all my coding. Trying to code back it seems that all the files on my old E-Sys don't work anymore because of the CADF files on my car beeing updated now. Any chance to get hold on New E-Sys files? thanks |
09-08-2013, 02:27 AM | #4565 | |
Rep 40,725
09-08-2013, 06:02 AM | #4566 | |
Rep 88
Once you code 6NS, it should show the extra options. |
09-08-2013, 10:25 AM | #4567 |
Rep 258
I've written and verified the FA. Not sure what else is needed or that I can do to confirm it. 6NS appears in the directory tree.
09-08-2013, 10:31 AM | #4568 |
Rep 40,725
Did you also remove old option code, 6NH, 6NK, or 6NL?
09-08-2013, 12:55 PM | #4569 |
Rep 258
Yup, 6NH was removed (I swapped the H for an S). Can post a screenie if it helps.
Random thought: Could this be something in the way MY2014 cars are setup that was different to MY2013? |
09-08-2013, 01:08 PM | #4570 | |
Rep 40,725
Did you write modified VO to car afterwards?
09-08-2013, 01:50 PM | #4571 |
Rep 258
I believe so. I followed the 10 step how to modify FA pdf, and there is a verify step where you reload the car's FA. 6NS appears.
09-08-2013, 02:28 PM | #4572 | |
Rep 40,725
You are VO Coding Head Unit though, and not FDL Coding it correct?
09-08-2013, 02:36 PM | #4573 |
Rep 258
Yeah, I don't think I could FDL code it anyway as I don't have a token.
09-08-2013, 03:29 PM | #4574 |
Rep 40,725
Maybe VO Date needs to be changed.
09-08-2013, 04:23 PM | #4575 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
Shawn-
i got an error when i hit the SAVE button after changing a setting in the file. It said FAILED TO SIGN FDL ERROR [C158] The car(F10) is on F010-12-07-533 and i am using 49.4 PSDZ data. Is this my issue? |
09-08-2013, 07:14 PM | #4576 |
Rep 28
I'm trying to run from within VMWare. I ran the E-Sys installer from the Mac share and now it appears this UNC (see below error message) is in a config file somewhere. I have all related data stored within the VM. Not using the share for anything.
Anyone know where this string is so that I can correct it? I'm striking out searching under E-Sys. Or should I just reinstall E-Sys running from the C: drive of the VM? Thanks. |
