08-16-2018, 02:00 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
*** Boost/Torque by Gear (% Reduction) - New Map Configuration option - bootmod3 ***
Hey guys, this one's been in the works for some time and we're happy to release it with the 0.10.029 system update.
Many of you can attest to being very hard to effectively put down power even with a Stage 1 OTS map even after going with great tires and setting up suspension and alignment right. We've come up with a simple and easy to use way to help you reduce boost (torque) for any given gear so you can better put it down. 1st and 2nd gear are most often the ones that need some help but we've exposed gears 1-6 for it. Some may even use it to create a low boost map using it as a simple boost tuner Update is up on bootmod3.net and the Android app store has the update. iOS version is in review as usual and hopefully live in the App Store in the next 24-72hrs. Let us know if any questions at all
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
08-16-2018, 02:50 PM | #2 |
Nemo banks
65
Rep 253
Legendary
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
08-17-2018, 09:51 AM | #3 |
Rep 2,382
Perfect.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-18-2018, 12:04 PM | #4 |
Rep 921
Perhaps a dumb question, but if I don't track the car and do a lot of long distance highway driving, would it make sense to reduce the boost in 6th gear to reduce wear and tear on the engine? Or is that a bad idea?
bm3, boost by gear, bootmod3 |
