02-02-2021, 10:39 AM | #1 |
Rep 191,344
*NEW PRODUCT* MAD Intercooler & Charge Pipe W/ Install Video
In this video, the stock intercooler and FTP charge pipe were replaced by the MAD FMIC 5" & CP
Upgrade from your stock intercooler to the MAD stepped core intercooler for maximum performance and reliability! The stock BMW intercooler is small, inefficient, and cannot keep up with the high boost that your tuned car targets. MAD BMW 5” intercooler will keep the intake air temperature in check, allowing your BMW to perform at its best at all times. The MAD F chassis BMW 5” intercooler uses a high fin density core for maximum cooling. It also features a stepped core design to maximize the cooling area. Weighing 22lbs only with dimensions of 21"x8.5"x5", It provides the perfect cooling solution for stage 1 applications. This intercooler is compatible with stock and aftermarket charge pipes. Features:
Fitment:
SKU: MAD-010 Upgrade from the stock BMW N55 charge pipe to the MAD N55 charge pipe for maximum airflow and reliability! The stock BMW N55 charge pipe is plastic and prone to failure. It's only a matter of time before the charge pipe to break. The MAD N55 charge pipe is a strong aluminum piece; it will provide better airflow and won't fail, and fits like stock. The MAD charge pipe retains the BMW C-clip and O-ring for the best fitment. Do not forget to move them from the stock charge pipe to the MAD option. The MAD charge pipe comes with two meth bungs; both bungs are sealed. If you do not intend to use methanol injection, keep them closed. Features:
Fitment: Fits Rear-wheel drive vehicles only.
SKU: MAD-017
02-08-2021, 10:18 AM | #2 |
Rep 191,344
02-15-2021, 10:34 AM | #3 |
Rep 191,344
MAD N55 charge pipe vs FTP
(nothing was wrong with FTP, we replaced it with MAD because we wanted to confirm fitment on the car that's all)
03-01-2021, 02:07 PM | #4 |
Rep 943
Drives: F30 328i Msport
Is there any difference in the intercooler compared to the Gplus units on ebay\amazon? Fin density looks identical, welds look identical, overall shape\form is identical too, and shipping weight is shown as 23lbs, which is the same as the Gplus.
03-01-2021, 04:01 PM | #5 | |
Rep 191,344
the shape/design is used by a large number of companies, in all fairness, Wagner was the first one to do it. The 23lbs is what I estimated the weight to be. As far as I know, this intercooler has nothing in common with Gplus other than looking similar which applies to a number of intercoolers from different brands. the manufacturer is different, the fin density is different as well.
RMachuca3d724.50 |
03-17-2021, 10:01 AM | #7 |
Rep 191,344
I have not tested it in-house but i also have not received a single fitment complaint with the MAD intercooler
