BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport automatic -- 2TB do it!
      08-27-2015, 03:14 AM   #45
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
Originally Posted by KGB_123_99 View Post
I FDL coded only the following:
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
EGS/3000 Applikation -> LC -> aktiv
The last one is for launch control, I don't think it's mandatory.
I didn't code ICM because my car already had Sport+, I'm not sure if that's mandatory either. Try the 3 items above, then put car into sport mode, shifter to the left and step on it. If you get nice kicks when the car switches gears, you have the sports auto coded successfully.
So did launch control work for you? I think I coded it on my car but never got it to work.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      08-28-2015, 11:40 AM   #46
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
It works, I used it a whole one time
It's really overrated imo and can't be good for the transmission even if "the car is designed for it" so I don't use it ever.
You need to drive around for a while (10 miles I think) and have the engine at operating temperature. Then Sport+, shifter to the left, foot on brake to the floor and stomp the gas. Little flag shows up on the dash and you're off!
      10-06-2015, 12:06 PM   #47
Crashnbrn5
Drives: 2016 335i GT M-Sport
Hey Guys, not new to the coding scene but just learned about this little transmission upgrade you guys are talking about.
I'm taking delivery of a 2016 335i xdrive GT M-Sport with all the goodies. Is this model capable of being coded for an even faster tranny?? I appreciate the help, and I have a local coder that can follow directions VERY well. Thanks everyone.
      10-06-2015, 12:06 PM   #48
KGB_123_99
I think the M-Sport already comes with the sports transmission. Check for option 2TB on your VIN.
      10-06-2015, 12:23 PM   #49
Crashnbrn5
Oh Okay, I was thinking there is even a faster application on top of the sport auto, wouldn't that be nice!!
      10-06-2015, 12:31 PM   #50
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
smithf32 opinion ?
mge92 jamoka3
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      10-06-2015, 01:34 PM   #51
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
Originally Posted by ROBNYC View Post
smithf32 opinion ?
mge92 jamoka3
Its okay. Not the biggest difference in the world. This is coming from someone who had a car without it and coded it, and now has a car with it stock.
      10-14-2015, 01:11 PM   #52
KGB_123_99
A question for transmission experts...
Do the faster shift times mean that there is less overlap when the two gears are engaged, thus reducing the amount of friction and heat in the process? Would this mean that a sport transmission actually runs cooler and has superior durability because of this mode of operation?
      11-12-2015, 12:38 AM   #53
rednose
Australia
65
Drives: F30 330i LCI M Sport
Faster shift means less friction wear, so its actually a good thing for the transmission
      11-12-2015, 04:28 PM   #54
mbro
Drives: 320d
Anyone know the impact on the MPG with this change? Feeling a little excited here. Haha
      01-02-2016, 06:49 PM   #55
DLag30
Drives: F80M3 & F36
Just tried the SAT and I'm very happy with the result. In comfort mode it doesn't hang the revs in partial throttle anymore and shifts are snappier but not uncomfortable. For those who haven't done this, try it out.
Btw huge thanks for all the information in this thread!
      01-08-2016, 09:56 PM   #56
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Originally Posted by onet
In my case, there was no sport+ setting.
And in the FA SA205 appears on the list .
The following settings I have already coded to to get sport+
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
The question now is whether and which of the following code are in addition necessary to get the SAT.
Kombi => 300C ECO_FDS =>Function
ICM/IcmKod_B_S2TBA -> verbaut
ICM/IcmKod_B_S205A -> nicht_verbaut.
Since I have not changed yet a FA or performed a VO Coding I am unsure in that matter.
So if necessary and possible , I would like to just perform the missing coding without the change to 2TB.
So did you do the 2TB FA coding as well?
Edit: Easy with just doing the FA (205->2TB) and VO coding. All the FDL's were already done from the VO/ECU coding.
      01-17-2016, 03:08 PM   #57
vinniem
Drives: 316i family member & 430i
any guide on : FA 205 with 2TB please?
cant seem to find some details on how to change it to 2TB.
I have coded FDL per above, I notice a difference mainly in comfort mode, little zippiler now
thanks
      01-17-2016, 06:18 PM   #58
CntryClub007
490
thanks
I would just change the FA from 205 to 2TB and VO code (just code the ECU's) not FDL code everything.
Does your Launch control work? I noticed a huge difference in performance when I put the car into Sport+ and Manually shifted.
      01-18-2016, 05:18 AM   #59
vinniem
thanks, thats my question how do you change the FA?
i didnt bother with LC, i FDL coded the other 2
      01-29-2016, 07:31 AM   #60
hsk1610
Drives: 2013 328i xDrive
I have my car VO coded from 205 to 2TB and a few days ago the car went in for a service for a trim issue and they found some fault codes in the transmission. The SA said the trans was constantly looking for the paddle shifter so there were some fault codes being generated. Looked at the FEM module and it has the paddle shifters as being active by default if you code 2TB so you might want to manually turn that off.
      02-03-2016, 06:03 PM   #61
acobildo
Drives: 2013 328i
Where in FEM_BODY is the paddle shifter FDL?
      02-03-2016, 06:09 PM   #62
hsk1610
FEM_BODY => PADDLES_VERBAUT = aktiv
Change the aktiv value.
      02-03-2016, 09:29 PM   #63
CntryClub007
490
If it helps...
Sport Trans Shifter and Coding Tutorial 205 -> 2TB
http://f30.bimmerpost.com/forums/sho....php?t=1219013
      02-29-2016, 04:52 AM   #64
Montaxx
Montaxx's Avatar
Drives: F30 328i
So can I just change those values without doing the VO-Coding?
      02-29-2016, 09:40 AM   #65
KGB_123_99
Yes, FDL coding will attain the same result.
      02-29-2016, 03:38 PM   #66
Montaxx
Montaxx's Avatar
Drives: F30 328i
Thanks, will try it on my 328i tomorrow.
Edit: did work, I just FDL-Coded KOMBI, EGS and ICM with the values from above. Seems to work. I can see S1-S8 if I have the shift knob on the left, but don't see a big difference. Maybe because I'm driving a 328i anyways?
