11-13-2016, 04:36 AM | #1 |
Rep 8
Harman kardon upgrade
I've seen a set of harman kardon speakers advertised for less than £200 (looks to be 4 mid range speakers and 4 tweeters)... would there be any benefit in me installing these or would it be pointless without the full amp etc?
11-13-2016, 06:24 AM | #2 |
Rep 3,291
The HK speakers are higher impedance than any of the other speakers that came in F30's. I don't know if you have HiFi or the base stereo that we don't have in the US, but either way you would need a third party amp or the F30 HK amp.
11-15-2016, 12:36 PM | #3 |
Rep 1,201
The weak link of the base or HiFi stereo is the amp. If you want to upgrade anything in the audio system that's what I would do first, especially when HK speakers aren't very good either.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
11-15-2016, 01:06 PM | #4 |
Rep 8
Would the existing system be plug and play with an upgraded HK amp... also would the car need any coding to get it to see the new amp?
11-15-2016, 01:07 PM | #5 |
Rep 1,201
I don't think HK amp will be plug-and-play and coding is absolutely needed. You should get the bimmertech amp instead which is plug-and-play and doesn't need coding. Search this whole forum for the bimmertech amp and read the thousands of posts on it.
11-16-2016, 05:48 AM | #6 |
Rep 3,291
For the most bang-for-your-buck, easy to put in and take out later, the Bimmertech amp/DSP can't be beat. Buying an HK amp would be just as expensive and wouldn't be as good (and the HK amp with the Hifi speakers is not a plug-and-play upgrade...your HiFi speakers are 4-ohm and the HK amp won't like them). The HiFi speakers aren't bad once they have a decent amp behind them.
