06-09-2016, 09:02 AM | #595 |
Rep 982
06-09-2016, 12:05 PM | #596 | |
Rep 3,089
1. Aligning the sills - what I did was use a stack of books on both ends of the sills to get them as close as possible to the rocker panels so I could better align them. I also kept the masking on the double sided tape except for a small section as the ends of the sill. Because the sills are flexible, they will sag so that leaves enough space to remove the masking once I get the ends of the sill aligned and stuck to the rocker panel. 2. I am very surprised your sills are not prill-drilled with holes! Are your sills OEM? Anyway, I would just space out the 15 holes evenly on the sills. And yes, the 6mm holes are right though as I mentioned its a very snug fit! I had to hammer in the plastic screw part that is supposed to expand the rivet. EDIT: I see on your thread that you bought aftermarket sills. 3. The length of the rivet only needs to be longer than the combined thickness of the sill and rocker panel as the bottom part of the rivet closest to the rivet head is all that really expands. The rivets you linked to doesnt look like the ones I have. The part # is 07149193301 Please let me know if you have any additional questions.
06-09-2016, 12:08 PM | #597 |
Rep 3,089
Right! My M4 ones needed a fair amount of plastic to be cut in order to align correctly. I heard the specific 4 series ones are much easier to install.
06-09-2016, 03:01 PM | #598 | |
Rep 454
Drives: 428i M Sport Gran Coupe
http://www.ebmotor.com/style-real-ca...up-p-2292.html
2015 428i M-Sport Gran Coupe, Glacier Silver, 6sp Manual, HK Audio
"I fear the day that technology will surpass our human interaction. The world will have a generation of idiots." - Albert Einstein |
06-09-2016, 03:12 PM | #599 | ||
Rep 454
I obtained the details of the 3M tape & adhesion promoter from your very detailed post.
06-09-2016, 03:18 PM | #600 |
Rep 3,089
I just pushed the sill against the rocker panel at the very ends. At least my sill sagged a lot so I could push the ends up without the middle section touching the rocker panel. I first did the front edge then the back edge. Since your sill is CF I imagine its not as flexible. In that case I think the best thing you can do is align the sill as close as you can with a stack of books then try to only press the front edge of the sill against the rocker panel. With only this portion stuck against the rocker panel you should still have some flexibility to adjust the horizontal alignment at the other end of the sill. Does that help at all???
06-09-2016, 03:23 PM | #601 | |
Rep 454
06-09-2016, 03:52 PM | #603 | |
Rep 454
06-09-2016, 03:53 PM | #604 |
Rep 3,089
The M4 ones need cutting. You should get the ones made specifically for the 4 series.
06-09-2016, 04:06 PM | #605 | |
Rep 982
51192361679/51192361680 Atleast that's what it shows when I search for schwelleraufsatz on Leebmann |
06-09-2016, 04:57 PM | #606 |
Rep 507
06-10-2016, 06:15 AM | #607 |
Rep 20
thanks guys. i will be getting this instead of the m4 version.
http://www.ebay.com/itm/191783509677...%3AMEBIDX%3AIT |
06-10-2016, 06:50 AM | #608 | |
Rep 810
07-02-2016, 11:45 PM | #609 |
Rep 1,170
Tboooe, very impressive GC build! Love all the mods you've done, big and small. Had a blast reading through your journal. Can't wait to see what's next!
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
08-15-2016, 10:48 AM | #610 | |
Rep 241
Drives: '19 330i xDrive M Sport
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
08-15-2016, 11:11 AM | #611 |
Rep 3,089
No I did not. Where did you get the reflector from? Mine from iND supposedly used the OEM BMW part as the base for the paint so the fit was as expected.
08-15-2016, 11:12 AM | #612 | |
Rep 241
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA Last edited by CyclingBroStyle; 08-15-2016 at 11:26 AM.. |
08-15-2016, 12:19 PM | #613 | |
Rep 3,089
08-15-2016, 01:57 PM | #614 |
Rep 241
Just emailed them INd responded in seconds absolute GRADE A customer service they are sending me a replacement, on that note I will say their products are worth every penny!
08-19-2016, 01:25 PM | #615 |
Rep 220
08-19-2016, 01:53 PM | #616 |
Rep 220
very interested in getting the bulb |
