02-13-2013, 04:38 PM | #23 |
Rep 1,997
02-13-2013, 04:46 PM | #24 |
Rep 690
If it doesn't work very well on your car have it checked out by the dealer. On my car it works very well, easily 9/10 attempts on the first try. However I had a loaner recently in which it was very hit or miss getting the trunk kick to work.
02-13-2013, 05:15 PM | #25 | |
Rep 2,266
F30 Sapphire Black M-Sport 335i 6MT
02-13-2013, 07:12 PM | #26 |
Rep 234
think of your foot as if it were riding a swing. it needs to go up behind the bumper, not just under it
Gone but not forgotten
14 335i 12 335i 6 speed 11 328i 06 330i |
02-13-2013, 07:38 PM | #27 | |
Rep 933
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL |
02-13-2013, 08:15 PM | #28 |
Too much is never enough
655
Rep 3,079
I can't comprehend how so many have an issue with this. It's such an intuitive thing. I've never had a single issue since day one.
You don't need to get anal about pointing your toe, lining up with the roundel or thrusting your leg in a certain manner. Just walk up and give a quick kick in/out. The sensor is up behind the bumper. It measures the longitudinal movement of your foot fore/aft. It does NOT use the park sensors. Distance from the bumper isn't particularly important (vertically). It has enough range to reach the ground. It also has a pretty reasonable range side to side. I literally just walk up and give a quick kick. Works 100% of the time. Don't overthink it. |
02-13-2013, 08:34 PM | #30 |
Just Copacetic!
177
Rep 616
I had a loaner recently that had the CA. Didn't have any problems using the kick/pull back technique. I've read in another thread that updating the software helped improve the success of opening the lid.
02-13-2013, 09:06 PM | #32 | |
Rep 7,047
I know it's "supposed" to work as I've got it to work, but, it doesn't work every time. My success rate is about 6-7 out of every 10 attempts. If this were implemented correctly we wouldn't have to have several threads about this very issue discussing the "proper technique". If it were implemented correctly it should work EVERY time you try it. I know a technique that works every time, use the button on the fob or simply use the button supplied on the trunk lid. Don't forget you have to have the fob in your pocket, or you'll just end up looking really silly continually kicking at your cool cars butt. |
02-13-2013, 09:21 PM | #33 | |
Rep 7,047
Yet, here we are again with another thread on this subject, over thinking it. I know how to do it as it's worked for me many times, and yet it doesn't work every time. As one poster suggested maybe something is wrong or out of alignment with some of these sensors. It just shouldn't cause this much issue for something that is supposed to be easy to use and part of "comfort" access. |
02-13-2013, 09:30 PM | #34 | |
Rep 2,266
02-13-2013, 09:35 PM | #35 |
Just Copacetic!
177
Rep 616
I recall a TV ad that had a dog wagging its tail under the rear bumper and caused it to open; believe it was on the E90 series. Maybe BMW was getting complaints of the trunk lid opening unintentionally?
02-13-2013, 09:51 PM | #36 |
655
Rep 3,079
Here are the "sensor wires" that are mounted behind the bumper.
Each sensor will detect the movement of your foot (or any object) as it passes under it them. The sensors can detect the direction of movement of your foot by evalutating the timing of the trigger events from each sensor. The motion itself is not what triggers the opening, it's the rapid change in direction. You need to make a pretty quick and purposeful in/out motion, not a lazy wave. It's not like a typical motion sensor. Just moving your foot around isn't going to trigger it. Thrust with purpose! |
02-13-2013, 10:11 PM | #37 | |
Rep 50
Following this technique my kids can even do it |
02-13-2013, 11:20 PM | #38 | |
Dinosaur supervisor
3027
Rep 4,214
I have NEVER failed since day one and when I tell my friends (incl. my mother who knows nothing about tech stuff) who doesn't know that it exist to kick behind the car they also make it on their first kick. |
02-13-2013, 11:29 PM | #39 |
Rep 924
From my experience it seems to fail only when I accidentally touch the sensor. The trick for me is to not touch the car and almost wave your foot in and under the bumper in a rapid but somewhat circular motion. Hasn't failed for me since I figured that out.
02-13-2013, 11:30 PM | #40 |
Rep 3,870
you dont need to kick quickly...
Actually, a slow kick in and up, then gently pull swing back out your leg and voila fast is no good... try a gently kick up and pull out...
02-13-2013, 11:49 PM | #41 |
Rep 1,209
im batting about .500 now... in fact first time i tried it when i left work it worked.
it's not so much that i was or anyone is over thinking it. it's more figuring out how it needs to function. I'm not surprised some people have issues w it... it's sort of advertised as a 'just stick your foot under it' and it's not exactly that simple. it'd be the same thing as if to lock your car you had to snap our thumb back instead of just touching the handle.
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
02-14-2013, 06:31 AM | #42 |
Rep 1,793
i know, i didnt mean it in demeaning way, just looks funny...
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
06-14-2015, 10:05 PM | #43 |
Rep 17
I've been trying to figure this out for six months and have yet to master it. I think I have gotten it work a handful of times. It does work though its awesome!
06-16-2015, 05:38 PM | #44 |
Rep 445
Believe it or not, I didn't know my car had this feature until I saw this thread...LOL! My Client Advisor never mentioned it and I never looked into it.
I just went outside to try it and nailed it on my first "kick." Ha Thanks!
2021 M340i xDrive Sedan | Portimao Blue Metallic | Cognac Vernasca Leather | Maple Matte Finish Wood Trim | 19-Inch 792M Wheels | Red Brake Calipers | Premium Package | Driving Assistance Package | Adaptive M Suspension | Harman/Kardon Surround Sound | Painted Rear Spoiler (Z50)
2014 335i xDrive Sedan | M-Sport | Estoril Blue Metallic | Venetian Beige Leather (Sold) |
