07-21-2023, 01:15 PM | #1 |
Rep 1,583
For what it's worth: free tuning
Did you notice that after washing, waxing, detailing...the car always runs much faster and handles better?
Seriously... Resetting the "adaptions" for the EGS and DME for me gave some very snappy response and overall smoother idle and engine sound. I used ISTA+ for the DME and Esys for the EGS, but I think ISTA+ also has EGS adaptation reset. Some background: replaced my timing chain tensioner in my N26 as a precaution (1 hr job, part $75) . Noticed a bit tighter chain and seemingly less rattle afterwards, although I do not think the chain or tensioner was about to fail. Recommend for anyone who has the original tensioner prior to 2015 to chnage, as they are more prone to fail, weaker spring, different oil passages (new design). A slacking timing chain can affect timing as the engine is trying to adjust to an increasing out of sync between the crankshaft sensor and cam-sensor. But, the real change in handling and shifting, smoother engine run came as I was hunting down a persistent info error (trailer AHM no message). During that process I reset the EGS and the DME. I also flashed the DME from the 2015 I-Step to a 2020 I-Step, but not sure if that contributed as well. Also, originally I had the 205 VO code for my EGS and about two years ago during an NBT HU retrofit I changed it to 2TB. There are a lot of posts on that...it's a low hanging fruit. As far as snappy shifting, longer acceleration before shifts...that was a vey noticeable improvement, especially at highway speeds passing. So the recent adaptation reset may have restored both the DME and EGS to "learning mode" again after months of slow city driving. Note: after resetting the DME, shut down car, allow it to sleep, then when starting let it idle for at least 2 mins.
07-21-2023, 08:26 PM | #2 |
Rep 103
I also noticed much better throttle response and smoother shifting after getting my I-Step updated at the dealership. The throttle adaptation reset procedure with the gas pedal also helps a bit.
The problem is that sluggishness returns after about a week. So the real question is how to automatically reset everything on every start up. Maybe a bm3/mhd tune fixes this? |
07-21-2023, 10:26 PM | #3 |
Rep 1,583
I prefer keeping stock. But I like the more sporty and snappy response.
I believe the computer adjusts to your driving habits. Since being in the city, stop and go and all, eventually it probably settles in a less aggressive setup.
07-22-2023, 10:51 AM | #4 |
Rep 4,879
The car automatically adjusts to driving habits. If you drive like an "old grandma" it adjust as so. If you are aggressive all the time, same deal.
It will dynamically adjust without resetting the adaptations (that's just the fast track). And yes, fully agree with there is a change when you reset them. If I do higher RPM downshifts coming off the highway, my 4th gear gets a pretty harsh shift flare (much better have xHP, but it's still there). Resetting brings it back to normal, as does lower RPM shifts over time. |
07-22-2023, 02:53 PM | #5 |
Rep 1,117
Cars are released and the istep controlling its performance based on the pre-release testing, often tens if not hundreds of thousands miles, is used.
As real world result come in over the first several years, those parameters are adjusted accordingly. One should always get their istep updated yearly for the first 4 years at minimum. The shifts and performance of the N55 F3x improved dramatically with newer steps. Same with B58s. Depending on when/if your car was ever updated, that might have been your significant improvement. |
07-22-2023, 06:16 PM | #6 | |
Rep 1,583
OUCH! Hilarious, but true.... The stop and go city traffic eventually gets you.
Wires1648.50 |
07-22-2023, 06:25 PM | #7 | |
Rep 1,583
But now that my car is at 103K miles, unlikely that it will ever go back to the dealer under my ownership, so may flash the other ECUs too. And if I sell it I can go back to stock all the way using my original FA/VO files and the latest I-Steps.
07-22-2023, 06:33 PM | #8 | |
Rep 1,117
07-23-2023, 10:12 AM | #9 |
Rep 4,879
