07-26-2023, 08:09 PM | #1 |
Rep 128
Brought my car for diagnosis today
Hi,
I brought my car to the dealer today to get some items diagnosed. The guy seemed to look at me like I was high though when I was explaining my issues. I must admit, that they're a bit odd. The car is a b58, rwd, 6mt. (2018) vehicle has 92,898km. 1. Consumed about 1L of oil in 4-5000kms. Then it consumed another 1L in 1-1500kms. It's been fine afterwards. start/stop worked during this oil consumption phase, and then stopped working afterwards. It's the only item that coincided with the oil consumption. - This was agreed that it was odd and will be looked at. 2. Hesitation when cold. Just the first couple minutes when the car has been sitting overnight. After a day of work, it doesn't do this. The easiest explanation is it's turbo lag in first gear, but it doesn't do this at any other time. - guy said his n55 does this and recommended that I idle the car for 5-10 minutes before taking off. Given that these are DI engines, I don't like the idea of idling the car for this long. Should I actually be doing this? Seems a bit outdated, we're not dealing with chokes here. - Not being looked at. 3. earlier today, when travelling at 30-32 km/h, going down hill in traffic, I was in third gear, and the car was 'pulsing'. rpm was erratic and the car was pulling and then slowing. rpm was at about 1200-1300. constant, light throttle was given. - being lumped into the diagnosis for item 4. although I was advised that I should have been in a higher gear. Usually you can tell when a car is struggling, and I 'cruise' in traffic in 3rd like this without issue frequently. 4. car just shakes when stopped sometimes. The first 2-3 times this happened, the tank was full. the last couple times it was at a half tank. In my unprofessional opinion, it's like the motor momentarily lost fuel, and then got it back again. - this is being diagnosed as well. No lights have come on, or notifications (other than the low oil warning). My fear is that nothing will appear for the diagnosis, and I will have wasted this time and money for no reason. Just curious if anyone else has had any similar experiences to the above, and what had transpired. |
07-26-2023, 08:18 PM | #2 |
Rep 1,821
don’t know about your oil consumption issue, some of the other issues with hesitation and all, there are a few things i’d look at replacing… they’re known to go bad and can be viewed as regular maintenance. you can also look up these topics on bimmerpost to see if what others have reported sounds like what you’re experiencing:
1. vanos actuators, intake and exhaust side. 2. fuel tank breather valve 3. spark plugs/coils/injectors - if any of these have never been changed on your car, i’d definitely do them.
Djphonics44.50 |
07-27-2023, 06:10 AM | #3 |
Rep 518
Not sure what gear your mechanic expects you to be in.
Sure you CAN be in a higher gear at 30kph, but why. Anything higher and it will either shift you down to 2nd or 3rd when you push the gas, or if it's a manual, 3rd is higher than you should be. |
Djphonics44.50 |
07-27-2023, 06:58 AM | #4 | |
Rep 128
I'll do some digging in the forum regarding the forementioned items. |
07-27-2023, 07:01 AM | #5 | |
Rep 128
he was suggesting a lower gear. If I was accelerating, I'd agree, but just coasting, especially downhill, I don't see why I need to be in higher gear. None of my other cars have needed to cruise at 2k rpm like this. Either way, I won't shift up moving forward. (no pun intended) |
07-27-2023, 07:26 AM | #6 |
Rep 4,879
Your #2 point is normal. You don't need to idle forever; it has a bit of hesitation/surge if you start the engine cold, and drive off and put the engine under load right away. Mine does it for the first block as a climb the hill out of my neighborhood and then it goes away (did this since new).
Now, that being said, with the other things you identified, sounds like there is root cause that would explain this (if it's not like above) and your other issues (except oil). |
07-27-2023, 08:25 AM | #7 | |
Rep 1,821
is your car bucking in low RPM? there's a thread about B58s bucking, and that's related to the vanos actuators that I mentioned.
07-27-2023, 10:08 AM | #8 | |
Rep 128
I agree with the plugs. I've been trying to dig up a maintenance schedule to get everything thrown in my calendar. I've got to get my e91 off my quick jack so I can do all my fluid swaps, and get it up to snuff. I'm surprised that changing out injectors in considered a maintenance item. I've never had to replace any in my life, and have had some higher mileage cars. |
07-27-2023, 10:57 AM | #9 | |
Rep 1,821
My plan is to do my 2nd plug change, coils, injectors, and vanos actuators all by the time my car hits 65k miles. i also like doing preventative maintenance, but many people just wait until an issue actual gets identified and fix it then. injectors definitely dont last forever, they get gunked up, and cause issues similar to what you're having. a stuck injector has also been one of the top killers of B58 engines. but all of that stuff is unrelated to your original post, sometimes throwing money at a problem before it's identified can hurt if you end up not fixing it. at the same time, if doing maintenance that needs to be done either way fixes an issue you've been having, you can feel quite good after.
07-27-2023, 06:20 PM | #10 | |
Rep 128
Received the call that the car is a-okay. It's always frustrating knowing something ain't right, but can't be found. |
