11-25-2015, 03:25 PM | #23 |
Rep 3,089
Pleae post lots of pics. I want to do this as well after I did the LCI ac/radio trim mod.
11-25-2015, 03:49 PM | #24 |
Rep 1,407
Drives: 13' F30 328i 6MT
Sweet cant wait to see, With the lighting pack was the climate control lighting plug n play?
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
11-25-2015, 05:00 PM | #25 |
Rep 121
Following
2015 BMW 328i Touring M Sport EBII
2003 Ford Falcon XR8 Ute *Sold 2011 FPV GT-E 5.0L S/C *Sold 1981 Ford XD Fairmont Wagon 302 *Sold |
11-25-2015, 08:19 PM | #26 |
Rep 1,140
You have to custom make an adapter, if you read the DIY by Dante then yes, it will be plug and play, just a PITA to hide the cable IMO. Otherwise it went well and looks awesome!
11-26-2015, 11:42 AM | #27 |
Rep 1,407
Cool yeah I saw that Next mod for sure... Wish it came in Matte Black vs Piano since nothing in my car is piano black but it looks nice
12-05-2015, 07:19 PM | #28 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
Does anyone know if the connection to the ambient lighting on the doors can be tapped with a custom fabricated Y-connector like is done with the LCI A/C Radio Faceplate?
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-08-2015, 03:28 PM | #29 |
Rep 1,140
Unfortunately no, since the connector to the Ambient Lighting in the pillar is not present for M-Sport cars, you would not be able to just make an adapter. You have to tap the wiring from the rear door harness.
12-08-2015, 03:33 PM | #30 |
Rep 1,140
Update:
I was finally able to get this completed over the past weekend. Wasn't able to take any pics, but by following this guide and the post on the same topic by 'Timmahh', it is a breeze. - I found it very easy to disconnect the rear door harness and pull it out a bit to make the wiring connections, then reconnect and tuck it back into it's spot. - The harnesses that are ordered come with all the attaching connectors for running the wire down the pillar, as a tip make sure you don't connect the last 2 attach points until after the wiring is done, gives you more slack to work with. - For the wiring, Pin 1 goes to the brown ground wire. Pin 2 (middle pin) on the lighting harness goes to the White/Red wire, this is the Orange Ambient Wire. Pin 3 goes to the White/Blue wire, this is the White Ambient wire. Overall looks great, glad I was finally able to get it done! |
12-12-2015, 10:38 AM | #34 |
Rep 346
The rear panel. The light source attached nicely and clips onto the rear of the panel. As I did not purchase the repair cable, my installer ran a cable to tap into front under dash ambient lights.
01-27-2016, 09:00 AM | #37 | |
Rep 346
The right way is to connect to the door ambient light. You need to buy a repair cable to do that but my installer just connect to the under dash ambient llight. |
01-28-2016, 08:50 AM | #39 |
Rep 817
Drives: bmw M3 F80
Model in blue
01-28-2016, 04:06 PM | #40 |
Rep 616
just so I'm clear, 63319242154 is the actual mount for the led and 61319242163 is the led with a lead attached to it that runs down to the connector at the rear door?
where does 61129335592 fit in? thanks. |
02-02-2016, 07:56 PM | #42 | |
Rep 817
Drives: bmw M3 F80
I just change the orange LEDs by blue I always have a choice of blue or white |
02-02-2016, 07:59 PM | #44 |
Rep 817
Drives: bmw M3 F80
