BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Door Panel Ambient Lights
Studio RSR
      11-30-2015, 05:39 PM   #67
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Originally Posted by derfl View Post
They are interchangeable and much brighter than the old ones.
I changed mine on my 2012. Lookin stunning now.
Cost about 16 Euro per piece and the installation Is easy within 10 minutes each door.
63319353133 is the correct part number and they are plug and play .
Good to know. Do the door panels have to be removed???
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      11-30-2015, 07:08 PM   #68
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
Diy Guide Now Pls. Yessss I Want So Bad.
I assume its easy tho, prob just need to pop the door card off.
      12-01-2015, 04:29 AM   #69
derfl
Drives: F30 335i
Will write one today.
      12-01-2015, 07:24 AM   #70
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2018 F80 M3  [9.75]
Awesome, thanks.
      12-01-2015, 08:36 AM   #71
tboooe
tboooe's Avatar
925
Curiosity got the best of me. Looks like someone did this on a russian BMW forum:
Комфортная подсветка в салоне
My build thread
      12-01-2015, 11:46 AM   #72
derfl
Drives: F30 335i
Here is my Quick and Dirty Version.....
First of all please excuse my bad english i will try my best to write it down that everyone can understand it.
What you need:
one LED Module per Door (Part: 63319353133)
Torx 20 Screwdriver
Small flat Screwdriver
4 hands
First you have to remove the inner door handle.
the easiest way is to pull it off with your fingers or a plastic sribe on the bottom of the handle. It´s just clipped in. Under the handle are two Torx 20 Screws. You cant miss them.
Now pull the door panel away where its marked.
There is no need to remove it completely. The panel is clipped in only.
Begin at the speaker corner.
Location of LED Module on the backward of the panel.
two hands have to pull the door panel away. The two other hands loosen the two clips where the light guide is inserted. Use a tiny flat screwdriver.
clips:
Insert for the light guide:
Pull the light guide out of the old LED Modul. Release the connector.
First push the connector to the new Modul so the LED Modul cannot fall down in the door.
Put in the light guide to the new LED Modul.
Reassemble everything the other way round.
That´s it. Have fun!
Greets from Austria
Flo
Kudos to spassacab from a german board who did this first an explained me erverything.
triax37130.00
      12-02-2015, 05:18 AM   #73
Luckky
Luckky's Avatar
Drives: BMW F30
Hi guys,
I don't have the option LED included in the panel doors.
But, Is it easy to install them ?
I have the LED under the AC module ( with the two colours red and white).
So maybe, if I catch this light, I can put the LED in the doors panels... (like the illuminated LCI AC)
What do you think ?
Best,
L
      12-02-2015, 10:37 PM   #74
Sii770i7
Sii770i7's Avatar
Singapore
Drives: F30 320i
What you need:
Torx 20 Screwdriver
4 hands
[IMG]http://fs5.directupload.net/images/151201/c4zemcqo.jpg[/IMG]
[IMG]http://fs5.directupload.net/images/151201/az2swgqt.jpg[/IMG]
[IMG]http://fs5.directupload.net/images/151201/glaybr5z.jpg[/IMG]
[IMG]http://fs5.directupload.net/images/151201/am5gxzyq.jpg[/IMG]
clips:
[IMG]http://fs5.directupload.net/images/151201/gwri5p4y.jpg[/IMG]
[IMG]http://fs5.directupload.net/images/151201/gxvrovwv.jpg[/IMG]
Pull the light guide out of the old LED Modul. Release the connector.h
Greets from Austria
Flo
Great guide! Thank you for that and am gonna do this sure. Just to confirm, I should be getting 4pcs, one for each door. Correct? Btw, do you have a picture of the led module to share?
      12-03-2015, 07:03 AM   #75
bmbk
bmbk's Avatar
Drives: BMW F30 316I
So tempted to do the mod, but a bit worry about pulling the door panels...can the module changed without completely removing the panels ? It looks like we need to remove the bottom as well to have minimum to access the location of the module.....
      12-03-2015, 08:48 AM   #76
derfl
Drives: F30 335i
yes, one Module per door is needed.
the last two pics show the LED Module. You get this whole part new.
You put a transparent cable (i said light guide cause i do not know a better english word for it) inside the hole (see last pic) of the grey Module. This transparent cable is fix installed in the door. The light will shine threw the transparent cable and you can see it then.
The small LED is located inside the grey module which you will buy.
There is no need to remove the whole door panel you get easily access when pulling it away.
The LED Module is easy to reach then.
Greets
@ Luckky i dont think you can do it cause there are two different door panels. One with an one without ambient light.
      12-09-2015, 08:39 AM   #77
xan
xan's Avatar
Norway
Drives: BMW 320d GT xDrive
Is it the same led modul for the back doors as well? I really want to do this, cause the ones that's already there, almost doesn't show.
My car was produced march 6 2014, but i recon they still used the old leds still, even though the new leds was first produced from march 1 2014?
I have changed the AC-trim, and in my opinion, I think the light there is brighter than from the doors. I tried to take a picture of it to demonstrate.
What do you think? Do I have the old led modul?
Bare in mind, that the lights seem brighter on the picture, than they are in real life.
      12-09-2015, 08:45 AM   #78
xan
xan's Avatar
Norway
Forgot to change the upload quality on attachments, so I'll try to upload the picture again, so it's easier to see the ambient light on the doors.
      12-09-2015, 08:47 AM   #79
xan
xan's Avatar
Norway
Here:
      12-09-2015, 03:58 PM   #80
derfl
Drives: F30 335i
The trim around the climate control is indeed brighter than the ones from the door also after going to the new ones.
It's hard to say from the picture but I think yours are the new ones already.
The old LEDs are almost not visible. Many guys did not know that there is a light.
On your picture the light is visible so I think you have the new ones.
Cheers
Flo
      12-09-2015, 05:32 PM   #81
xan
xan's Avatar
Norway
Cheers
Flo
That's what I was afraid of.
Was hoping that the new modul where as bright as the ambient light in the 5 series.
A buddy of mine has one, and there you can see the light very clearly, even in daylight.
      12-10-2015, 06:11 PM   #82
instalher
25cent millionaire
instalher's Avatar
Drives: 2020 m4 comp vert
2020 bmw  [0.00]
  [9.00]
  [0.00]
  [9.50]
2018 bmw 230i xdrive  [8.50]
ok I don't have this on my car but I will order part from dealer and try to install, I have run one wire into the door already and it can easily attach to the dual illumination in the under foot area of the car.
      12-11-2015, 06:37 PM   #83
Jonsiu
Jonsiu's Avatar
145
Drives: E92 328i, F30 335i
Finally ordered these from my dealer and following the BAVSound youtube video taking apart the panels was a breeze
Not the best photos, but you can see the difference!
ps. In case you live in Canada.. These are the last 4 LED modules they have in stock in Canada. All others are back order from Germany lol.
      12-27-2015, 02:23 AM   #84
danielmok39
Drives: bmw 328i GT
Hi all, I ordered the 63319353133 part from USA, I have changed the original LED module, but the brightness seem as same as the original one.
And the second one is the original LED module and the 63319353133 part LED module!
      12-27-2015, 12:17 PM   #85
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
Great DIY was super simple to do all 4 doors in about 20-30 I accidentally popped off 2/4 entire door panels and it was incredibly simple to replace them without breaking anything.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      12-27-2015, 04:30 PM   #86
Fronzdan
Drives: '24 M240 xDrive
So has anyone verified that this is the right part number and they are actually brighter?
Ok looked it up and it appears 63319353133 replaces 63319242150 ( active 11/01/2011 - 09/09/2014).
So who in US has 63319353133 in stock and who can verify are they brighter?
      12-27-2015, 05:17 PM   #87
cryptocar
cryptocar's Avatar
They are brighter. I did the mod last week it's not a huge change but it's noticeable. Sorry I didn't take pics before.
      12-27-2015, 06:57 PM   #88
Fronzdan
Where did you get them from? Best price I've seen so far is $22 each. I'm tempted to just mod the existing ones for that price. All you'd need to do is replace the LED and/or the resistor SMT parts.
