BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Door Panel Ambient Lights
Studio RSR
      12-27-2015, 08:14 PM   #89
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
I got my 4 modules from getbmwparts. They're my primary supplier for OEM parts. I check against ECS but most of the time getbmwparts has been cheaper.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      12-28-2015, 06:49 AM   #90
danielmok39
Drives: bmw 328i GT
Originally Posted by cryptocar View Post
They are brighter. I did the mod last week it's not a huge change but it's noticeable. Sorry I didn't take pics before.
But I have changed to the new LED module, it seems as same as the original one, is there any problem with my new LED module????
Here is the photo after I changed the new LED module, it is still not noticeable
      12-28-2015, 10:53 AM   #91
Fronzdan
Drives: '24 M240 xDrive
In your picture of the two LED modules opened up, is the bottom one the new version? Just from the picture it would appear the only difference between the two is that they lowered the resistor values for each LED, thus increasing the current through each. This would increase the brightness some, if the LEDs weren't being driven to their max mcd rating already.
      12-28-2015, 07:15 PM   #92
cesare87
Drives: 435i
I need to do this, I didn't even realise there was lights there until I read this thread.
      12-28-2015, 11:46 PM   #93
danielmok39
Drives: bmw 328i GT
The bottom one is the new version LED module! So is the new module brighter?
      12-29-2015, 10:05 AM   #94
Fronzdan
According to cryptocar, yes. And looking at the pic, assuming the LEDs are the same, they increased the current. So they would be slightly brighter.
      12-29-2015, 10:06 AM   #95
cryptocar
cryptocar's Avatar
It's nothing game changing but it's apparent. At least on my Coral Red leather interior.
      12-29-2015, 03:02 PM   #96
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Maybe a dumb question but did you increase the ambient lighting setting to max in idrive?
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      12-29-2015, 03:07 PM   #97
M5 F90 (2018)
Drives: M5
You all got me thinking so i just went and checked mine and with the Idrive and on the speedo set to max and with the orange light it looks ok. I have black interior. My car is a week old LCI 335
      12-29-2015, 03:17 PM   #98
ZKing1208
Drives: 2016 328i Msport MG
I have a 2016 328 M sport on the way with premium package and Nav... Will my car have ambient lighting in the doors or anywhere else???
2018 M3 Comp
      12-30-2015, 12:03 AM   #99
danielmok39
Drives: bmw 328i GT
Yes, I did increase the ambient lighting setting to max already!
      12-31-2015, 12:30 AM   #100
bmbk
bmbk's Avatar
Drives: BMW F30 316I
Got my modules today. did the change, its morning, cant see any difference now. Will take a picture later at night and post it.
I noticed the following, the module dont sit very well at the housing. When i hold the module close the holder, its slightly brighter. I dont know the workaround for it.
While holding the module
Not holding the module
      12-31-2015, 12:37 AM   #101
bmbk
bmbk's Avatar
I think there is a design failure for the module and its holder mechanism
      12-31-2015, 09:06 PM   #102
danielmok39
Drives: bmw 328i GT
Let see how is the result at night
      12-31-2015, 09:58 PM   #103
Fronzdan
Have you guys tried swapping the internal boards and re-using the old housing?
      01-01-2016, 03:15 AM   #104
cryptocar
cryptocar's Avatar
My neW LED modules for directly on the light guide rods fit just fine there is doubt regarding the jump in brightness output. It's not huge but it's nonetheless noticeable.
      01-01-2016, 05:01 AM   #105
danielmok39
Drives: bmw 328i GT
Hi guys, I installed the new LED module here are the photos after I installed.
But I broke the light bar in driver side, it affects the brightness of the new module. do you guys have any solution with the broken glass (I mean the light bar!).
      01-01-2016, 05:12 AM   #106
bmbk
bmbk's Avatar
ok, updates.
There are some improvement. at night its brighter. But there is a catch.
On my door, i installed this white leather lining as the light is very dim, so with the low light output, when it falls on the white surface, it got reflected. So after the light mod, its even brighter now. Thats for sure. But what ever falls on the dark surface, i think there are no difference. See pics below for details.
      01-01-2016, 05:39 AM   #107
bmbk
bmbk's Avatar
When that happend ? I nearly broke mine when trying hard to remove them...
      01-01-2016, 06:47 AM   #108
danielmok39
Drives: bmw 328i GT
Me too, I broke mine when trying hard to remove them as well......
      01-01-2016, 07:10 AM   #109
Terabyte
Austria
18
Drives: BMW F30 316d
You tried to remove the light bar?
As far as I know, the light bar is not easy removeable.
Or did you nearly break it when removing door panel?
      01-01-2016, 09:47 AM   #110
danielmok39
Drives: bmw 328i GT
No, I mean I broke a part of the light bar when I remove led module!
