04-05-2015, 02:39 PM | #23 | |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
Lucky for M-Sport Wheel owners! |
04-17-2015, 07:06 PM | #25 |
Rep 265
Drives: 2014 328i AW
Short answer is no. I've got a laundry list of mods getting done once they are done I'm going to revisit this. I havs the PINS and the wheel installed just need to figure out the wiring which I personally have no business messing with
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
04-22-2015, 08:46 PM | #26 |
Rep 987
Should have confirmed, I got my paddle shifters working with those pins connected, along with Paddles_verbaut set to aktiv in FEM_BODY. No other codes required.
I'll also be swapping my GWS to the Sport GWS. Just waiting for it in the mail and should be plug-n-play. |
04-23-2015, 12:47 AM | #27 |
Rep 135
04-23-2015, 08:22 PM | #28 | |
Rep 987
As quoted from my earlier post in the thread...
04-24-2015, 08:39 PM | #29 |
Rep 345
Do someone get a non-paddle M-sport wheel to retrofit the paddles and get them to work? I'm very interest to do this.
Black Sapphire Metallic / Premium Package / Technology Package / Cool Weather Package / Lighting Package / Harmon Kardon surround sound system / Vossen VSF/1 Matte Graphite
Wood11221.50 |
04-24-2015, 08:49 PM | #30 | |
Rep 135
04-26-2015, 10:55 AM | #31 |
Rep 345
+1 Please keep us posted, hope it work to do the mod ASAP.
04-30-2015, 05:44 PM | #32 | ||
Rep 107
F80
04-30-2015, 08:09 PM | #33 |
Rep 345
+1 Please let us knows how it went.
05-02-2015, 06:29 PM | #34 |
Rep 135
Got the parts from ECS today.
Will try to tackle tomorrow if I find the proper DIY instructions to retrofit my M sport steering wheel. Did a search and couldn't find it. Is it just plug and play? First problem, how do I disconnect the battery from an AH3? Is it the same as any F30? |
TMac335i68.00 |
05-02-2015, 07:04 PM | #35 |
Rep 265
Can you list out the part numbers you ordered and where you ordered them from? That wire harness is that a part u ordered or is that the one you removed from the car? Thanks I'm trying to solve this mystery as well
05-07-2015, 09:56 PM | #36 | |
Rep 345
05-07-2015, 10:42 PM | #37 |
Rep 135
partly. I couldn't figure out how to attach the paddles. by the time i realized that I had to drill my wheel for the paddles to screw into, I have already put everything back. I will try again this weekend.
Plus I ordered screws for the paddles. http://f30.bimmerpost.com/forums/sho....php?t=1122768 here where I found the info about drilling it. http://f30.bimmerpost.com/forums/sho...d.php?t=973545 |
05-09-2015, 03:55 PM | #38 |
Rep 135
Update:
drilled a couple of holes for the paddle screws, put everything back. started the car.. paddles didn't work. did more research, coded FEM_BODY, 3190, PfSteeringWheelPaddles, PADDLES_VERBAUT to aktiv SUCCESS!! |
05-09-2015, 03:58 PM | #39 |
Rep 265
05-09-2015, 04:25 PM | #40 | |
Rep 135
below are the parts I bought. Keep in mind that I didn't get a new steering wheel, I just modified my M-sport wheel. Connecting lines will vary depending what feature your wheel currently have. I have heated wheel. Bought everything from ECS http://www.ecstuning.com/ Screw Set ES#2599088 Rear Steering Wheel Cover ES#2706880 CONNECTING LINE, STE ES#2633640 Bought the paddles off Ebay from autopartsus located in NY. |
05-10-2015, 01:19 PM | #41 | |
Rep 345
BTW http://www.getbmwparts.com/ also have the parts almost at the same price but the shipping is less. Still looking for the P/N on the paddles.
05-13-2015, 10:00 PM | #42 | |
Rep 397
I have a baseline car with cruise control and no heat. I ordered a M wheel with pedals and would like to now what I need to do first hardware wise. Thanks.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
05-13-2015, 10:52 PM | #43 | |
Rep 987
Some cars are pre-wired, some aren't. It's as simple as that. If not, see below my quote for proper wiring to have fully functioning paddles.
Otherwise it's just a simple coding to FEM_BODY, EGS, ICM and KOMBI with VO code change from 205 to 2TB. Of course you could probably just do FDL coding which is what I did, since I already enabled 2TB without paddles. |
05-14-2015, 05:48 PM | #44 | ||
Rep 397
