BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 steering wheel upgrade to sport with paddle shifters
Studio RSR
      05-14-2015, 08:19 PM   #45
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
Originally Posted by jondaman View Post
Based on another post, the FEM is around the passenger footrest area? I want to see if I need to order the cables to connect it or not. Coming from a baseline car, it probably doesn't have the connection
Yes, the FEM is in the Front Passenger Footwell (kickpanel by the door.)
My car is a Sport Line but it didn't have the wiring, however an EU Base Line has the wiring. It's case-by-case.
      05-14-2015, 10:29 PM   #46
jondaman
jondaman's Avatar
Drives: 2013 328i
To open the passenger footwell, do I just pull on the plastic cover that is closer to the front of the car (shorter piece). I tries pulling it a bit but it didn't want to give, I just wanna make sure that is the right piece before putting force on it.
Do you know of a tutorial?
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i,
F30 Liquid Blue Matallic 328i
Current Garage Queen: Mineral White F83 M4
      05-15-2015, 01:26 AM   #47
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
To get at the FEM, you'll need to remove a few trim pieces before you can access it:
1. Remove passenger side door side sill cover strip
2. Remove bottom trim piece just below the passenger glove box.
3. Removal of A-pillar trim piece at bottom of FEM
It shouldn't take more than 15-20 minutes to do. It helps when you know what's behind the trim pieces holding them in. The pics below should guide you through...
      05-15-2015, 07:17 PM   #48
jondaman
jondaman's Avatar
Drives: 2013 328i
Thanks. I thought the FEM was near the footwell at the center and not the outside of the car, thanks for the diagram. I will have to check if the wire is connected on mine tomorrow.
Do you work for BMW? How did you get your hands on those things so fast :P
For other people who are interested, here is the FEM module location.
Here is the Pin Diagram, you are looking for connector number 8. the SZL (Steering Column switch Cluster):
And finally the wiring diagram.
      05-15-2015, 07:49 PM   #49
squidlyboy
squidlyboy's Avatar
Thats right. Its covered up by the passenger side A-pillar kick panel. That kick panel is in turn covered up by that side's door sill piece, which is why you have to go "outside" so to speak. The pictures are not that great, but its all inside.
I updated the procedure using your pic, which is a much better way to show where everything is. thats a great pic of the fem
      05-15-2015, 07:57 PM   #50
jondaman
jondaman's Avatar
Drives: 2013 328i
Thanks a lot, my friend. I found the electrical systems document and giving it a good read.
Next stop is to learn coding
      05-16-2015, 01:35 AM   #51
jondaman
jondaman's Avatar
Drives: 2013 328i
Last quick question before I do this, is the SZL connector number 9 on the diagram FEM diagram?
      05-16-2015, 02:25 AM   #52
squidlyboy
squidlyboy's Avatar
I don't think that's right. If you go back to that original wiring post:
http://f30.bimmerpost.com/forums/sho...0&postcount=82
You need to go from FEM (Connector: A173*7B , Pin: 5) --> SZL (Connector A83*2B , Pin: 3)
Connector A173*7B is the 3rd from left. Looks like you are pointing to 2nd from left (what you highlighted in red).
Those high-level diagrams you pulled from the BMW system brochures are nice for high-level overviews and diagrams, but when you are going down to the actual wiring connectors, pins, etc.. you should switch to Rheingold ISTA/D for all official connector identifiers (e.g. A173*7B). That's where Timur's pics came from and where mine came from (I don't work for BMW lol). I'll send you a PM...
Good luck with the install - almost there ...
      05-16-2015, 10:52 PM   #53
jrortiz
jrortiz's Avatar
Puerto Rico
Drives: 2012 328i
Someone should do a DIY
Black Sapphire Metallic / Premium Package / Technology Package / Cool Weather Package / Lighting Package / Harmon Kardon surround sound system / Vossen VSF/1 Matte Graphite
      05-23-2015, 11:23 PM   #54
ngbernie
Drives: F30
Originally Posted by twincam23 View Post
you replaced your wheel so I think you just need to code your car for it.
below are the parts I bought.
Keep in mind that I didn't get a new steering wheel, I just modified my M-sport wheel. Connecting lines will vary depending what feature your wheel currently have. I have heated wheel.
Bought everything from ECS
http://www.ecstuning.com/
Screw Set ES#2599088
Rear Steering Wheel Cover ES#2706880
CONNECTING LINE, STE ES#2633640
Bought the paddles off Ebay from autopartsus
located in NY.
About the connecting line, there seems to be many variants:
http://bmwfans.info/parts-catalog/F3...ther#7848337_5
I do not have any of the options - heating, sport transmission and warnings -but wish to code to sport transmission. Should I be getting 32307848335 (ECS Part# ES#2633640) instead?
Or it is a 1 size fit all, the one you listed works even if you do not have the options listed?
They are the same price
      05-24-2015, 12:02 AM   #55
twincam23
twincam23's Avatar
Drives: 2014 ActiveHybrid 3
correct, my part number covered lane change/departure warning which my wheel didnt have and it still worked.
looked at the part you mentioned on the ECS site, it looks like the correct cable for you.
      05-24-2015, 08:41 AM   #56
ngbernie
Drives: F30
Thanks, that was great info.
About the wire connecting to the airbag, it's a totally separate loom from this wiring?
I'm coming from a non M-sport steering wheel trying to retrofit to M-sport, but the new airbag didn't come with any wirings. I suppose the existing one can be used back?
      05-24-2015, 11:08 AM   #57
twincam23
twincam23's Avatar
If the existing airbag connector fits, use it.
      06-24-2015, 01:01 AM   #58
LittleBlackHawk
Drives: F30 --> E89
Hi, is there any trick while drilling the hole for the paddle? I am thinking about doing the same retrofit, but wondering how to locate the hole precisely and what kind of the drill bit is recommend? The metal seems hard and thick. Thank you.
aps335.50
      07-22-2015, 08:43 AM   #59
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
OK, time to add some notes. I installed paddle shifters to my factory m-sport wheel last night using this thread and others, and here are some tips to save you some heartache:
0.) This is a great guide generally: http://www.mediafire.com/view/m33a3n...30_Rev._3L.pdf
1.) If you have an M-sport wheel and need advice on removing the airbag, go here: http://f30.bimmerpost.com/forums/sho...php?p=18297090
2.) If you do not have factory paddles, and need to know where to drill, go here:
http://f30.bimmerpost.com/forums/sho...d.php?t=973545
3.) If you forgot to buy the factory screws for the paddles, a pair of #6 x 3/4 sheet metal screws will work fine. Yes really.
4.) See attached picture. You need to understand that the horn operates by means of the central ring contacting the aluminum steering wheel frame. This ground point needs to be installed so that it does not make contact between the horn ring and the wheel frame unless you think a constant horn blowing while you frantically jam your car back into the garage and run to disconnect the battery sounds fun.
With that in mind.. good luck and have fun. I think it's about a 2 hour job if you can avoid these pitfalls.
2019 M5C Matte MBB / Tartufo
      07-22-2015, 07:48 PM   #60
jrortiz
jrortiz's Avatar
Puerto Rico
Drives: 2012 328i
@IancoleTX Thank you very mucho for sharing the information.
      07-22-2015, 09:04 PM   #61
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
No problem bro, good luck!
      09-16-2016, 10:45 AM   #62
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
IancoleTX Thanks for the information! I literally had that problem where my horn was going off and I was frantically trying to pull over to disconnect my battery after repeatedly pressing the horn button to try to get it to stop. Good thing I had a socket wrench handy in my trunk...
I should have taken a picture when I fixed the problem, but essentially there's a tiny piece of metal connected to a black screw in the base plate of the steering wheel, which can be found near the circled area in IancoleTX's photo. At first I didn't know what to do, until I realized that it was bent so far that it was touching the metal base plate, keeping the horn circuit connected even after the central ring lost contact with the base plate. All that needs to be done is to bend that little metal piece away from the base plate and problem solved!
If you want to see how the horn works, press on the ring surrounding the hex nut and it will depress, almost like a button. When you press the horn (essentially pressing on the entire airbag housing when installed in the steering wheel), you connect a circuit by touching the central ring to the steering wheel base. Normally the central ring is the positive terminal and the steering wheel base is the ground. However, if the ground wire is touching the central ring, the circuit is still connected as there is still a ground. I've also attached another picture to hopefully make this clearer!
      11-16-2016, 05:13 PM   #63
Aello
Drives: 335i xDrive M-Sport Package
I have a 2014 335i with the M-Sport package which has the M sport steering wheel and steering wheel heater. What do I need to buy in order to retrofit paddles on? And how can I tell if it's prewired?
      01-24-2017, 11:28 AM   #64
madmortar
Drives: 2013 BMW 328i M-Sport
Any advice on what bit to use when drilling the holes in m-sport steering wheel?
      01-24-2017, 11:38 AM   #65
david51
david51's Avatar
France
538
Drives: bmw M3 F80
If you have the son as indicated then you are prewired
      01-25-2017, 04:09 AM   #66
stuartey
Drives: 2011 f10 520dse
i have the sport, and bought the wire and connectors, turns out the wire was alresdy installed. added the 2TB to vo and all worked fine
