05-15-2018, 05:59 PM | #48 | |
Rep 69
BEAMTECH H7 LED Headlight Bulb, 50W 6500K 8000Lumens Extremely Brigh CSP Chips Con... https://www.amazon.com/dp/B06XH38CDR..._mx2-Ab0Y7WEFM I posted pics of my beam pattern in the DIY thread. No adjustment needed for mine. |
05-15-2018, 07:29 PM | #49 |
¯\_(ツ)_/¯
537
Rep 1,000
05-15-2018, 09:49 PM | #50 |
Rep 81
I have a 2017 X3 with halogens and looking to upgrade the lighting. This process and bulbs should work similarly, right? By that I mean, it shouldn’t be much more different in terms of coding/bulbs and performance.
05-16-2018, 07:18 AM | #51 |
Rep 16,083
You should find a thread in the X3 forum where someone has already done it, especially where the coding is concerned. I know that F25 and F30 coding parameters are not the same.
05-16-2018, 07:24 AM | #52 | |
Rep 50
https://www.solidrop.net/product/run...00lm-bulb.html |
05-16-2018, 09:49 AM | #53 | ||
¯\_(ツ)_/¯
537
Rep 1,000
01-11-2019, 01:47 PM | #54 | |
Rep 4
How to code out the headlight errors/malfunctions with LEDs
I purchased a Carly Adapter II and got the Pro app to code. After trying to turn off the headlight voltage checks (1/2 and 2/2) for right and left, I still get the flashing and malfunction. It apparently didn't work. What did you do to eliminate the errors/flickering? |
01-11-2019, 02:59 PM | #55 |
Rep 16,083
Did your bulbs come with LED driver ballasts? Mine did, and they never threw an error. I still had to code out the warm and cold checks so that they wouldn't blink every minute or so.
06-27-2019, 05:28 PM | #56 |
Rep 51
UPDATE: its been over a year - sorry yall
the light output isnt perfect but better than halogen for sure (just lacks smoothness) here are the comparison pics comparo1 by Roma, on Flickr comparo2 by Roma, on Flickr LEDlo HALfog by Roma, on Flickr now its time to fix those fogs VK-5S H7 8000LM LED Link to the LED bulbs (EDIT 2022: no longer on Amazon) But if you are looking for an alternative https://amzn.to/3sJg2BW These are the best I've used since Last edited by roma3; 02-17-2022 at 02:02 PM.. |
10-26-2019, 11:17 PM | #58 |
Rep 3
LED
10-29-2019, 07:17 PM | #60 | |
Rep 101
I got these and they work/look great. A good tip, when installing, take the ring off (just a quarter turn of the bulb) of the bulb and install separately then after you get the metal tabs in place nice and secure, install the bulb into the ring. If you search YouTube there is a video of a guy running one of these in a bowl of water to show how water resistant they are.
There is a fine line between being a hero, and being a victim.
10-29-2019, 07:19 PM | #61 |
Rep 101
If your headlamps are not installed yet you may not need to install the ring separately since you'll have a better angle with the headlamps on a table than in the vehicle, working from the wheel well.
10-30-2019, 05:33 AM | #62 |
Rep 2,044
"VK-5S H7 8000LM LED
Link to the LED bulbs :https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1" Wow. These look exactly like the Supernova V.3 bulbs I want to put in now, right down to the label on the ballast! Do they have a removable collar & are they clockable (twist to align LEDs properly)? Murf Last edited by Littlebear; 10-30-2021 at 06:02 AM.. |
10-30-2019, 07:27 AM | #63 |
Rep 16,083
Almost every LED is packaged and sold by multiple sources. If it seems there are lots of choices on EBay or Amazon it pales in comparison to those on AliExpress.
02-12-2020, 02:30 PM | #64 |
Rep 51
Hey guys another update
Just put in Katana H7s and they are the best ones I've tried so far. here is a link to my post on them https://f30.bimmerpost.com/forums/sh...1#post25800381 or a link straight to amazon Katana mini H7 https://amzn.to/37mztUi Last edited by roma3; 02-17-2022 at 02:03 PM.. |
02-12-2020, 02:31 PM | #65 | |
Rep 51
