BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F32 changed to M4 seats
proTUNING Freaks
      04-27-2017, 04:02 PM   #23
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Mousejunior View Post
ok, let me take a picture of the under seat and let you know. Thanks David.
ok
      04-27-2017, 04:44 PM   #24
david51
david51's Avatar
France
538
Drives: bmw M3 F80
How to remove the airbag
Blahx929.50
      04-27-2017, 05:07 PM   #25
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Remove panels
Blahx929.50
      04-27-2017, 05:22 PM   #26
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Demounting rear panels bmw M3 / M4
Image 4
Tilt the backrest cover (1) slightly forward.
Push the rear panel (2) forward in the marked areas and remove it at the same time upwards and backwards.
      04-27-2017, 05:39 PM   #27
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Dismantling seat airbag
picture 1
Unhook the bead (1) from the backrest frame backrest.
Release the cable clamp (2).
Tilt the backrest upholstery with the padding slightly forward.
picture 2
Unclip the cable support (1) from the seat mechanism.
picture 3
Detach the airbag cable (1) from the seat mechanism clip (2).
Remove the airbag cable (1) from the seat mechanism in the area indicated.
picture 4
Release the cable clamp (1).
Unlock all the connectors (2) of the male housing (3) in the direction of the arrow.
Installation:
Ensure that the connectors (2) are securely locked in the male housing (3).
picture 5
Remove the nuts (1).
Tightening torque 72 12 03AZ.
Unlock the locking element (2).
Remove the side airbag (3) and remove the airbag cable from the backrest frame.
picture 6
Note for reply:
Ensure that the airbag cable (1) is correctly inserted through the hole in the backrest frame (2).
Nomana1466.00
      04-27-2017, 08:19 PM   #28
Mousejunior
Mousejunior's Avatar
Drives: 2018 M4 SMB 6MT
2018 BMW M4  [0.00]
Thank you for the detail post of how to remove the seat back cover as well as the seat airbag removal david51 really appreciate your help on this.
      04-28-2017, 01:34 AM   #29
Nomana
Nomana's Avatar
1466
Is it possible to clear error code only?
Not sure if the seat airbags still work.
Steering wheel airbag has 2 different models for USA and the rest of the world.
      04-28-2017, 12:10 PM   #30
Mousejunior
2018 BMW M4  [0.00]
No I tried. Cannot clear the error code directly.
Tomorrow I am going to switch the F32 seat airbag into the M seat. I will keep you posted to see if it works or not... finger cross
      04-28-2017, 01:42 PM   #31
Nomana
Nomana's Avatar
1466
Good luck mate
      04-28-2017, 03:23 PM   #32
david51
david51's Avatar
France
538
Drives: bmw M3 F80
In my opinion for the airbag it is necessary to use rheingold to record the new airbag
      04-28-2017, 03:25 PM   #33
david51
david51's Avatar
France
538
Drives: bmw M3 F80
The simplest and put the module under the driver's seat and the original airbag F32 on the M4 seat as I did on my F30
      04-28-2017, 03:34 PM   #34
Mousejunior
2018 BMW M4  [0.00]
This will be the project tomorrow. Thanks guys
Hope everything will work.
I don't think I will bother with the M logo light up or not... too much work of running another wire into the FEM
      04-29-2017, 05:29 AM   #35
aacabriolet
aacabriolet's Avatar
Drives: '14 435i Coupe
david51 you're a legend for sharing those. i'm not even doing a retrofit but if I was. people like you are a godsend! I can imagine that will help loads of people!
david51537.50
      04-29-2017, 09:44 PM   #36
Mousejunior
2018 BMW M4  [0.00]
Thank you david51 once again for your help. Everything works now. Nomana you have all the support you need, so now you can look for the seats
      04-29-2017, 11:52 PM   #37
david51
david51's Avatar
France
538
Drives: bmw M3 F80
For the illumination of the M3 logo, the easiest way is to connect as the next picture.
You can plug the power supply as I did on my F30
      04-29-2017, 11:54 PM   #38
david51
david51's Avatar
France
538
Drives: bmw M3 F80
thank you very much
      04-29-2017, 11:56 PM   #39
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you @david51 once again for your help. Everything works now. @nomana you have all the support you need, so now you can look for the seats
very good news
      05-01-2017, 09:33 PM   #40
Mousejunior
2018 BMW M4  [0.00]
david51 do you know the part number for the wire from pin 7 to pin 2 in the armrest? Should look something like this right? Might as well finish off with the light up logo.
      05-03-2017, 07:34 AM   #41
Nomana
Nomana's Avatar
1466
Appreciated all you guys for this. The community is so strong here with people like you guys. Especially David, I used to pm him long time ago and he tried his best to give me the best solution.
After I get new seats installed then I will try rheingold to record new airbags as David suggested.
Will report back if it works or not.
Ps. It might take some time for me to install because of my duty call.
Cheers
      05-10-2017, 05:57 AM   #42
GCinFLA
Top is M3 ZCP Plug
Bottom F30
Heated seats on both.
Notice extra blue/purple wire on M3 Plug.
Assuming that is light.
      05-10-2017, 06:08 AM   #43
GCinFLA
Did you swap F32 and F82 seat airbags to make it work?
Based on Realoem.com, appears while other airbags are different, seats are the same. F3x and F8x airbags are also the same part number.
      05-10-2017, 11:30 AM   #44
Mousejunior
2018 BMW M4  [0.00]
Yes the airbags have the same part number, but after I swapped the F32 one into the M4 seats, it worked believe it or not.
I will work on the light soon. david51 already told me it is pin #7 so your pictures are correct. I am just getting ready to get the pin / wires so I don't need to spike anything.
