01-20-2022, 10:05 PM | #111 |
Rep 16,082
Bulbs come and go all the time. I'd give these a try:
https://www.amazon.com/BEAMTECH-H7-L...ef_=ast_sto_dp |
Stuart j55.00 |
01-21-2022, 09:14 PM | #112 | |
Rep 117
Thanks |
01-22-2022, 11:47 PM | #113 | |
Rep 1,217
The biggest difference in the many bulbs that I have tried has been brightness. So far the brightest bulb has been this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Also, I have tried a couple of the fanless bulbs (lasfit and sylvania) and found them to be alot less bright than the bulbs with a built in fan. The fan has never failed on any of the bulbs that I have tried but one of the led chips did eventually fail. Anyway, good luck with your selection. |
Stuart j55.00 |
01-23-2022, 06:59 PM | #114 | ||
Rep 117
Thank you 👍 |
12-17-2023, 12:58 PM | #115 | |
Mess Deck Commando
244
Rep 807
///Sursum Ab Ordine
12-17-2023, 01:43 PM | #116 |
Rep 16,082
This link still works: https://www.amazon.com/BEAMTECH-H7-L...ef_=ast_sto_dp
12-17-2023, 01:49 PM | #117 | |
Mess Deck Commando
244
Rep 807
///Sursum Ab Ordine
01-14-2024, 03:02 AM | #120 | |
Rep 10
brilliant guide, thanks for linking it to me in the other post - your links are quite old and I guess the years and technology has moved on. What are your thoughts on something like this, https://www.ebay.co.uk/itm/354505286...BlBMUPy7_PGgYw Is this too bright at 200W, will it blow the fuse? What rating is the Low beam Fuse? I'm assuming 15A, if so I guess I wouldn't want to exceed 80% of the fuse rating, so that leaves 72W per bulb. What Power was the bulbs you used ? |
01-14-2024, 07:20 AM | #121 |
Rep 16,082
They're not 200w. No LED is. They may be 20w at best. Many sellers of LEDs use a wattage rating that would be required from an incandescent to realize the same lumens output.
03-28-2024, 08:09 PM | #122 |
Rep 4,095
Drives: F30 328i
In the process of swapping to LED bulb and have installed these H7 into my Lows and can seriously say its extremly bright and Work amazing..
https://www.amazon.com/dp/B0C7ZQSYD7...roduct_details I was planning on installing similiar style on the HIGH Beam but the Heat Sink was too big just seen you Modified yours? I sent them back and ordered a pair with No heat sink just normal plugs but the bulb itself didnt fit in the hole right to lock in the collar. What is really the difference on these style of bulbs? Did u File the backs down im guessing? Appreciate any help.. Ive swapped the LOWS,FOGS, Parking, Need to get turn signals any recommendations to get rid that orange yoke?
03-28-2024, 10:04 PM | #123 |
Rep 16,082
I cut mine with a rotary tool and abrasive blade. You may not have that option with fan cooled. As I recall I may have done some trimming inside the lamp with a multi-tool as well. I have these for turn signals, but they may not fit an F30. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
