BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Has anyone got a link to aus/nz 2021 NBT next map update
      05-14-2021, 05:49 AM   #1
Jizmdogsmack
Drives: 2014 BMW 328i Sport
As description says I'm looking for a link for the 2021 next NBT update for an f30
      05-16-2021, 09:17 PM   #2
Jizmdogsmack
Cheers
      05-26-2021, 12:44 AM   #3
//m535i
//m535i's Avatar
Drives: AUDI RS5 Sportback 2022
Don't suppose anyone has link to the CIC (Premium) 2021 ANZ map?
Many thanks in advance.
      06-25-2021, 07:21 AM   #4
plodmanau
Australia
Drives: 2015 BMW 340i m-sport
Hey Seth_Z,
Is that map good for NBTEvo (ID4)?
Cheers
      06-27-2021, 07:15 AM   #5
rednose
Australia
65
Drives: F30 330i LCI M Sport
Originally Posted by plodmanau View Post
Hey Seth_Z,
Cheers
That won't work for Evo
They are however available online for around $25 USD
Latest one is:
Road Map Australia/New Zealand EVO 2021-1
      07-27-2021, 01:16 AM   #6
agent_orange
Drives: 2014 F25 X3 30d, 2021 F87 M2C
Thanks heaps for hosting the data files Seth_Z, worked great in my MY14 F25 X3.
      07-28-2021, 02:29 AM   #7
brob
Drives: BMW 435i
Originally Posted by Seth_Z View Post
Not sure if it breaks any rules by try this.
https://ebl6-my.sharepoint.com/:f:/g...M6rox9RjI76hyA
Hi Seth,
It's way too many years since I last tried to update my BMW maps, and since then, this new FSC key seems to be needed to proceed. Can you give me a clue how to work with the map file and the FSC generator .rar file that I've just downloaded? PM if you like.
Rob
      08-11-2021, 08:41 PM   #8
Snappa2000
Snappa2000's Avatar
Australia
Drives: 2013 M3 E92
Did you ever find a link for 2021 Premium?
      08-12-2021, 04:57 AM   #9
//m535i
//m535i's Avatar
I've found no links for CIC Premium 2021. Even paid sites seem to only have the 2020 as the latest.
I'm happy to be corrected if anyone can provide a link for the 2021.
      08-13-2021, 06:55 AM   #10
brob
Drives: BMW 435i
Seth,
Thanks so much for the link, although it seems to have gone down since. Learned a lot afterwards - successfully loaded E-Sys and Launcher PRO 2.8.2 from TokenMaster, plus his famous BFU_XODE.est file and his scathing activation code. Took me a bit of time to get my Win 10 PC to talk to the car, but succeded to down load and decode the FSC. Imagine my surprise when having uploaded the map files to the car, I did NOT need the FSC to activate or accept the upload. I simply opened the Nav system and it all worked. The 2021 update is a significant improvement over the 2019 version in many ways, so I'm a very happy camper. Thanks again, Rob
      08-17-2021, 08:27 AM   #11
rednose
Australia
65
Originally Posted by brob View Post
Seth,
You may have had an FSC code loaded from factory, sometimes you can get away with one update, if you have the tools (which it looks like you have) try and generate a Lifetime code, then you can install every map update with the same code
      08-18-2021, 01:37 AM   #12
brob
Drives: BMW 435i
Lifetime FSC
Hi Rednose,
I did wonder if an FSC code had been loaded by the dealer when I had them do a map upgrade as a "special" deal a couple of years ago. If so, would that mean that the FSC that's in the car now is already a Lifetime one? If not, I'm unsure of how to generate a Lifetime FSC myself. Nowhere in the process I used was any mention made of Lifetime versus OneTime codes, although I had seen references to them in other threads and posts. One snippet I picked up from elsewhere was that the last four character of a Lifetime code were AD7Q, whereas mine are AACA. Presumably you can't just substitute these characters for those in a Onetime code to convert it to Lifetime?
So what's the process to generate the Lifetime FSC - do you change the entry at the "Upgrade Index (hex/dec)" box on the E-Sys screen from 0x01 to something else like say 0x02, or is it more subtle than that. For further clues, I did inspect the FSC file, but apart from the VIN and date of manufacture data, the rest is gobbledegook.
      08-18-2021, 02:54 AM   #13
rednose
Australia
65
Hi Rednose,
My Lifetime code ends in AD7A so not sure how true the snippet you came across is.
You will find out the next time a map is released, you'll have to try the next map and see if it asks for a code, if it does and the one you have doesn't work your nav will stop working until you get a working code.
I found out the hard way and my relative was left with no nav for a week until I sorted it.
      08-18-2021, 07:30 AM   #14
brob
Drives: BMW 435i
Lifetime FSC
Well, I certainly wouldn't want that to happen.
So back to the point regarding a Lifetime code, am I on the right track with the "Upgrade Index" entry in E-Sys, or can you steer me in the right direction, perhaps via PM, so that I can proceed further down this track.
Thanks
      08-18-2021, 07:47 AM   #15
rednose
Australia
65
Thanks
I did it so long ago I can't remember how but I'm pretty sure I followed this guide
https://www.e90post.com/forums/showthread.php?t=1461515
      08-18-2021, 10:06 AM   #16
brob
Drives: BMW 435i
Thanks Rednose - seems like that post is for CIC rather than NBT, but I seem to remember Jaeger's software gave Lifetime and Onetime options. I'll check it out and report in a day or two. Brob
      08-19-2021, 08:18 AM   #17
rednose
Australia
65
All good, my version has CIC and NBT
      08-31-2021, 06:56 AM   #18
penfold2105
Drives: BMW 430d M Performance
>> CIC
Road Map PREMIUM Europe East 2021-1 (1USB) - https://yadi.sk/d/AKLedORqkZpe3Q
Road Map PREMIUM Europe West 2021-1 (1USB) - https://yadi.sk/d/P3LfVZDgONDBCQ
Road map premium turkey 2021
https://disk.yandex.com/d/rIXQ2Tp_JMTsqQ
Road map premium middle East 2020
https://www.dropbox.com/sh/av57aqtpl...thiuafWda?dl=0
Road Map North America PREMIUM 2021 (1USB) - https://drive.google.com/folderview?...uH96q8ssmOdCqZ
Road Map Australia New Zealand Premium 2020
https://drive.google.com/drive/mobil...gj?usp=sharing
>> CIC-Mid
Road Map Europe East MOTION 2021 - https://yadi.sk/d/cqo0fUdMQUFSfQ
Road Map Europe West MOTION 2021 - https://www.dropbox.com/sh/5tg7m2ez5...CxgNzwifa?dl=0
Road Map Europe East MOVE 2020 - https://yadi.sk/d/qbjw81_j1Yoi9g
Road Map Europe West MOVE 2020 - https://yadi.sk/d/U1fClwpC2G8oZQ
>> NBT
Road Map Europe East NEXT 2021-1 - https://yadi.sk/d/uT5oMrT3Eo-V7Q
Road Map Europe West NEXT 2021-1 - https://yadi.sk/d/q5maL0d0hV2S0w
Road Map North America NEXT 2021-1 https://drive.google.com/file/d/1ibX...w?usp=drivesdk
>> NBT Evo
Road Map Russia EVO 2020-3 - https://yadi.sk/d/uIFqLz8FTfvjdA
Road Map Europe EVO 2020-3 - https://yadi.sk/d/SrpKY-qQ89h8DQ
Road Map Europe Way 2018-1 - https://yadi.sk/d/rWxbhnoHFCJ7Eg
>> EntryNav
Road Map Europe Route East 2021-1 - https://yadi.sk/d/vfdTUP2AERZUQQ
Road Map Europe Route West 2021-1 - https://yadi.sk/d/WeVokyaaazhy6Q
>> MGU (iDrive7)
Road Map Europe Live 2020-2 - https://yadi.sk/d/qXMR6lWBuEz-Yg
If you need FSC for premium maps see vid. If helped please subscribe.
Thanks
Can someone send me the NEXT New Zealand Australia one please.
      09-06-2021, 10:55 PM   #19
penfold2105
https://f30.bimmerpost.com/forums/sh...8#post27996338
Guys I put some direct links from my server for maps which may save time.
      11-04-2021, 08:42 PM   #20
Tobz_au
Australia
245
Drives: F30 335i
Life saver, thanks so much managed to update my maps to 2020 using your files and FSC Generator video!
      02-05-2022, 12:18 AM   #21
BabyFox
Drives: 135i
Thanks a lot, that's awesome, now I just need to figure out the fsc code part
      02-05-2022, 09:58 PM   #22
MJBO
MJBO's Avatar
Australia
2616
Drives: 2023 G81 M3 Touring
I was able to generate the FSC code for the 2022 maps for my car using the files auto backed up by BimmerCode.
