07-14-2014, 11:00 AM | #67 |
Rep 3,947
So the consensus is that it'll fit an M Sport but the issue is that it's short on hardware (screws? pop-its?). Anyone know the part number to make up for the shortage?
07-14-2014, 11:50 AM | #68 |
Rep 3,406
I recently ordered these.
http://www.jcwhitney.com/husky-liner.../p2020646.jcwx Can't wait to have them installed. |
07-14-2014, 12:54 PM | #69 |
Rep 613
added mine right after delivery. installing them takes about an hour if you want to do a excellent job.
im happy with them
f*ckin' love my car <3
08-05-2014, 03:06 PM | #70 |
Rep 1,479
Drives: 2020 M340Xi (G20)
+1 -- time and money well spent!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
08-05-2014, 04:15 PM | #71 | |
Rep 131
Sorry..those are ugly as sin
01-22-2015, 12:13 AM | #73 | |
Rep 51
This pic speaks volumes if you consider that dirty... |
01-26-2015, 09:09 AM | #74 |
Rep 126
For those who installed the mud flaps; did you have to take your wheels off to get the job done? I'm looking to order them for my 328i xDrive.
01-26-2015, 09:23 AM | #75 | |
Rep 390
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
01-26-2015, 10:07 AM | #76 |
Rep 274
Question for all: I have an M-Sport with the side skirt extensions installed. I have rims in the back that stick out, and I am starting to get little chips on the rim lip. I assume that it is from rocks being kicked up from the front tire. Do you think front mud flaps would prevent this? An will they work on the front on an M-Sport with side skirt extensions?
01-28-2015, 11:31 AM | #77 |
Rep 274
Tried it last night, the side skirt extensions prevent them from fitting on. Anyone seen a part number for front mud flaps that are made to fit over the side skirt extension?
07-03-2016, 04:04 PM | #79 |
Rep 700
08-24-2016, 09:09 AM | #81 |
Rep 178
What tools are needed?
Hi, I just ordered a set of these off Amazon for $84. What tools do I need? I definitely don't have the tools or jack and jackstands to take off my rear wheels like someone else did.
Can I do it with a stubby Phillips screwdriver and leave the tires on? I've got a 2013 328I. Thanks. |
08-26-2016, 01:56 PM | #83 |
Rep 112
So, when i checked my rear wheelwell, i noticed that my car actually does not have any expanding rivets instead it's all hex bolts. I dry fitted the mud flat and it seems that all the holes lined up.
08-26-2016, 04:29 PM | #84 | |
Rep 291
stroker1562.50 |
08-30-2016, 05:35 PM | #85 |
Rep 178
Installed mine today.
Ok I installed mine today. I was able to do it without taking the wheels off. The fronts were real easy to do because I could turn the tires out of the way. I just used a small punch to push the pins through the rivets, and an 8 mm socket for the one bolt. Real easy to do the fronts.
The rears were tougher to do because I had a hard time getting my socket in there, there's not much clearance with the rear tire but I was able to do it. I also used a drill to drill the holes for the self tapping screws that go on the bottom. They are self tapping screws but good luck trying to self tap them, I didn't have a little stubby screwdriver. Drilling small holes made the screws go in there super easy. So I mounted the mud flaps and tightened all the bolts first, then just drilled with it fully mounted. I think they look great, and you might be able to see some of the black spots on my car, that was from armor all that flings off my tires. I won't have to worry about that anymore. Basically all you need is an 8mm socket and a short extension, and a punch or something small to push the rivets in. I just used a pair of pliers to pound in the new rivet posts to lock them in. It's real straight forward and easy to do if you can fit your socket in there, and the fronts are super simple to do. Definitely no need to have a shop install these unless you have no tools at all, but then considering how much BMW would charge to do it, you could buy a set of tools with the money you save. I got mine on Amazon for about $80 with free shipping for the full set front and rear. They came from San Francisco BMW so they are the real deal genuine BMW mud flaps. Last edited by stroker15; 08-30-2016 at 05:41 PM.. Reason: Forgot to add where I got them from. |
(-_-)BmwF30xdrive(-_-)253.00 |
08-30-2016, 05:50 PM | #86 |
Rep 178
Yes the expanding rivets are on the fronts. On mine it was 8 mm bolts. 2013 328I sport.
09-11-2016, 07:40 PM | #87 |
Rep 112
So, when i was taking out the front plastic rivets, the pins would fall into the fender as i pull the rivets out. Now i am worried that the pins will cause rattle in those areas, has anyone else experienced this?
09-11-2016, 07:56 PM | #88 |
Rep 291
