BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > M performance Carbon Fibre Shift knob auto
Studio RSR
      05-13-2013, 07:43 PM   #1
kevinp
kevinp's Avatar
Drives: 2012 335 f30, 2010 escalade
Heres a pic of a before and after. If you need help with a DIY just let me know is pretty simple once you figure out what to do.
BMW M perf. gloss black kidney grills, BMW M perf. Carbon f mirror caps, Superbright led front turn signal white plasma projector, Weather tech digital mats front back and trunk, BMW rear entertainment system, 7000k white 18 smd led foot area,M perf. carbon f shift knob, Front lip carbon f, HID fog lights 6000k h8, front and back reflectors to match ,Pair of carbon f side grills, License plate carbon f. cover and error free smd lighting.
      05-13-2013, 08:12 PM   #2
Biglabulis
Drives: 2013 estriol blue 328i xdrive
Where did you get that?
      05-14-2013, 01:33 AM   #3
kevinp
kevinp's Avatar
Bmw dealership. But i seen them online ranging from $180 to $260 plus whatever shipping will cost you.
      05-15-2013, 02:22 AM   #4
8E88
Drives: 335i '13
Looking good, and I need some help with DIY, please. How to?
      05-15-2013, 02:27 AM   #5
GuiltyNL
Drives: F31
Do you feel the carbon texture when touching the knob?
      05-15-2013, 01:17 PM   #6
artieg30
Drives: 2016 F06
yes i have the same shift knob on mine and it's "raw" carbon fiber... in other words they didn't put a layer of clear coat or whatever they use on the external CF parts to protect it from the elements... the same can be said for the M-perf interior trim.
      05-16-2013, 02:28 AM   #7
GuiltyNL
Drives: F31
Thanks, nice!
      05-22-2013, 01:36 AM   #8
kevinp
kevinp's Avatar
To start first take the middle black piece (where R, N, D, - +, M/S is located ) thing off with a really small screw or something pointy like the one in the pic from the side. Is glue stick on theres no bolt or screw holding it doesnt matter which side theres a slight little gap all around it. Ignore the P button just chilling there for now. I will get to that later.
      05-22-2013, 01:45 AM   #9
kevinp
kevinp's Avatar
When the middle black piece is removed youll be left with the first picture. It is a very tiny screw with 6 stars if thats what you want to call it. That is what holds most of the knob together. After that screw is removed you will get second picture take it out completely but remember the middle whole you took out the screw from from the frame because when you put it back it has to go back on the same spot. The P button comes out off automatically after this screw is taking off. As you can see i cracked it from the sides a little and i scratch the bottom, because at the beginning i was trying to force it out because i didnt think there was a screw holding until later that i discovered the middle black piece came out and underneath was the screw. Make sure you take out the screw and the rest will be a breeze no need to force it. Don't make my mistake, you can potentially sell that part or put it back for next owner if carbon is not there style.
      05-22-2013, 01:48 AM   #10
8E88
Drives: 335i '13
Attachment 865492
Attachment 865493
Thank you
      05-22-2013, 01:54 AM   #11
kevinp
kevinp's Avatar
After that install the M performance carbon fibre knob making sure is align properly with the Parking button as well then put the screw back in the middle hole so it holds it together. After that, peel off the tape from the Middle black m performance part and then put it in the middle and then bombazo you are done. Pretty much putting it back the same way you took it out.
Make sure you are very careful with the unlock button on the side it has two tiny little clip on legs(top and bottom of it) that break off easy... i unfortunately broke one of mine when i was trying to force it at the beginning and now the top dents a little in, and i believe its just the bottom leg clip on holding it. It gets annoying so just be careful with that.
      05-22-2013, 01:57 AM   #12
kevinp
kevinp's Avatar
Hope that clarify it a bit.
1. No clue why my pics always come out sideways.
2. Any other questions just let me know.
      05-22-2013, 02:12 AM   #13
kevinp
kevinp's Avatar
Youll be rolling with this now.
Now just admire those 5 min of your hard work lol ... Initially 40 min but with a DIY should be 5 10
      06-03-2013, 11:54 AM   #14
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
hey can you post more pictures of your car. I like what i see in your sig... What to see the headlights... can i get a link to the projector bulb? and pics of the led foot area.
      06-12-2013, 10:33 PM   #15
hksusa
Drives: 2013 BMW 335i M Package
Can't seem to find this for sale anywhere. Any links?
      06-18-2013, 01:53 AM   #16
kevinp
kevinp's Avatar
i will just give some time... im trying to finish it all with most of the mods and i will post pictures of it fully done... its going to look filthy
Plenty go on ebay... turner motorsport... or actual bmw dealership but theyll rape u so avoid it unless u absolutely cant find it.
      06-18-2013, 01:47 PM   #17
F30form
Drives: '13 Mini Cooper S Hardtop
or www.shopbmwusa.com
      06-18-2013, 02:06 PM   #18
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Im curious, so the black transparent plastic is held together by Glue?
is it the same as the non sport shifter?
Thanks!
      06-19-2013, 10:29 AM   #19
kevinp
kevinp's Avatar
Thanks!
Yes the middle part of it is. The top "P" park sign is held together by the rest of the frame when its put back together. and yes should be the same, as long is automatic shifter.
      07-23-2013, 11:22 AM   #20
giddyup69
Drives: '13 F30 335xi
Just a quick thank you to this thread! Made my shifter install very easy.
'13 F30 335xi • white/black • m-sport
      08-13-2013, 06:01 PM   #21
c3r2z8f30i
c3r2z8f30i's Avatar
43
Drives: 2020 540ix & 2021 x5 40i
Looks good, I don't have the sport shifter do you thinks it the same process
      08-14-2013, 10:56 PM   #22
kevinp
kevinp's Avatar
No its not i tried already with the loaner i had... it is not the same if someone can show how to do it yourself without the sport shifter would be great
