BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > M performance Carbon Fibre Shift knob auto
Studio RSR
      08-14-2013, 11:40 PM   #23
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Drives: 2023 230i Mineral White
Is the part number 61312250696 for the "raw" CF shift knob?, I don't want the shiny clear coated one, thanks.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
      08-15-2013, 12:00 AM   #24
kevinp
kevinp's Avatar
Drives: 2012 335 f30, 2010 escalade
i dont know i didnt buy it from mod bargains...
and thats where your probably getting it from ... since the number ur giving me...
but they're pretty legit i bought a few things from them and always top notch quality oem usually, if not better. And at $140 can't go wrong i paid like 220 back then from a bmw dealership with shipping and handling. Sent them a message to see if it is the same one.
BMW M perf. gloss black kidney grills, BMW M perf. Carbon f mirror caps, Superbright led front turn signal white plasma projector, Weather tech digital mats front back and trunk, BMW rear entertainment system, 7000k white 18 smd led foot area,M perf. carbon f shift knob, Front lip carbon f, HID fog lights 6000k h8, front and back reflectors to match ,Pair of carbon f side grills, License plate carbon f. cover and error free smd lighting.
      08-15-2013, 02:05 AM   #25
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Thanks. I actually found the part number from
http://www.getbmwparts.com/partlocat...catalogid=4462 , but it hard to tell which one it is.
      08-15-2013, 02:16 AM   #26
kevinp
kevinp's Avatar
yea thats the one...
buy it from either or **********s has great customer service in case anything goes wrong... they fucked up in my order, well they took way longer then they should have because all the items i order were at different warehouses so they had to ship two different packages. They sorted it out and it was shipped the next day. But look around see if you can find it cheaper best ive found so far has been $140.
      09-04-2013, 12:17 AM   #27
fthirty
fthirty's Avatar
Drives: 2013 328i Msport
Anyone know what size that little screw is? Just tried installing it tonight but I didnt have the correct hex size. Fail
      09-04-2013, 06:05 AM   #28
Waterbelly
Drives: 2020 X3M Comp
Warning: it is a torx, not a hex! If you go at it with a hex, you will strip it and end up sad.
Don't know the exact size, but you can get a small torx set at any hardware/home improvement store for less than $10.
Matt
      09-04-2013, 10:29 AM   #29
fthirty
fthirty's Avatar
Thanks. I didn't use a hex in case I were to strip it, just didn't know what it was called. Smallest torx I had was labeled T10. Guessing a T8 or T9 should do the trick. I can update once I figure it out.
      09-04-2013, 10:44 AM   #30
EvenKeel
Drives: Sedan
The aluminum shifter looks better with your burl+aluminum trim. Obviously, different strokes for different folks.
      12-12-2013, 06:20 AM   #31
knightsabers
knightsabers's Avatar
Australia
454
Drives: Audi R8 v10 Spyder
Thanks for the instructions, Got it done in 5 mins, simple & fast with a Torx Screwdriver.
      12-15-2013, 08:02 PM   #32
EHDEN
EHDEN's Avatar
Lebanon
394
Drives: 435i
2014 BMW 435i  [7.00]
nice write up! to get the tranny lever out initially, is it as simple as unscrewing it?
      12-15-2013, 09:03 PM   #33
USC2000
USC2000's Avatar
Drives: F30 328i M Sport
I need to add this to mine.
      12-15-2013, 09:12 PM   #34
USC2000
USC2000's Avatar
      12-18-2013, 12:15 PM   #35
Jvee90
Drives: 2013 328i, 2008 335i sedan
+1. I'd like to know too
      12-19-2013, 09:29 AM   #36
kevinp
kevinp's Avatar
I think theres a lot more to it for the tranny lever... i wouldn't put my two cents in since i haven't done it, but welcome for anybody that has done it or seen it done to comment on the procedure.
      12-23-2013, 02:11 AM   #37
Jvee90
so am i reading this correctly...you don't have to take the lever out? does the whole silver surround come off when you take out the black middle part and the one screw holding everything together?
      12-30-2013, 10:24 PM   #38
knightsabers
Australia
454
The silver bezel is held in place by one Torx Screw, Removing it is all it took.
I'll attach a pic of the screw
Process is simple.
1. Wedged a flat head screw driver into the Gap of the Black piece and wedged it out. It was held in place weak glue.
2. Remove Torx Screw from silver bezel
3. Install M Performance CF Gear Shift
4. Screw torx screw back in
5. Remove 3M tape from replacement black piece and stick on.
6. Step back and admire the job
nyalpine907433.00
      12-30-2013, 11:51 PM   #39
Jvee90
thanks, knight. was totally over thinking it. for some reason i thought the whole knob needed to come out. appreciate it. now time to buy!
      12-31-2013, 12:26 AM   #40
inChargeOfIT
Drives: 2013 335i Sport
thanks for the write up!
      02-07-2014, 09:54 AM   #41
fherjohn
fherjohn's Avatar
Drives: m3 e93
Next mod
      02-12-2014, 07:59 PM   #42
doug piston
doug piston's Avatar
Drives: F30 320
I have the poverty package 320 with the sports package. I was curious how it's carbon fiber know would look and thought I'd post it here for those curious.
I am to lazy to resize so you'll finger will get some exercise.
https://www.dropbox.com/s/cf0gsmamwg...2017.46.07.jpg
Edit: and it turns out to be a horrible pic. Damn Garage and iPhone.
      02-12-2014, 08:48 PM   #43
Damn Dirty Ape
Drives: 2015 Infiniti Q50S
thanks took about 5-10 minutes. my dash kit took about 30 though.
      02-13-2014, 04:49 PM   #44
kevinp
kevinp's Avatar
What are you talking looks elegant. I'm kinda anxious for the m3 in mineral white or mineral gray with red seats and ceramic brakes. Time to save up until is release that will probably be the upgrade.
