01-24-2017, 02:29 PM | #45 |
Rep 33
02-07-2017, 09:31 AM | #46 |
Rep 92
Thank you for this guide NISFAN.
Coded my car to bring on fogs with DRL when opening the car. The orginal fog lights looked awful. Found this old post and changed to the MTEC bulbs... great matching colour. Plus the guide even made it easy even for me to attempt!! |
06-27-2017, 02:16 AM | #47 |
Rep 15
Hint for others: if you care more about the visual effect, DO NOT go for the osram cool blue intense they're just slightly whiter then the oem ones (on attached pictures, you'll see one on the right side as you look at it)
However, I have to admit, they are bright and great for cornering - sort of compromise |
09-30-2017, 12:35 PM | #49 |
Rep 110
Sorry to bump this thread. Found it impossible to get the bulbs out on my 335 due to the radiator/intercooler there. wasnt able to twist and get them out. Is there another way to do this?
09-30-2017, 06:34 PM | #52 |
Rep 1,953
Drives: 2013 328i xDrive
Did you not turn the wheel to the side and unscrew the bolts holding the lining in? Worked pretty well for me.
09-30-2017, 07:05 PM | #53 | |
Rep 110
09-30-2017, 07:12 PM | #54 |
Rep 1,953
Sounds like instead you're not squeezing the tabs properly. I will say that when I was doing it the first one came off perfectly, but the second one I was having trouble with. I realized that I wasn't squeezing it in the right place because once you do it twists just fine. When I was doing it wrong I had a similar problem where it felt like there wasn't enough room to move.
09-30-2017, 07:14 PM | #55 | |
Rep 110
09-30-2017, 07:43 PM | #56 | |
Rep 1,953
https://youtu.be/hv33qDcN0d0 Last edited by Kailec; 10-01-2017 at 06:16 AM.. |
09-30-2017, 07:48 PM | #57 | ||
Rep 110
09-30-2017, 08:03 PM | #58 |
Rep 1,953
Ah okay, that makes sense. When the second one was pissing me off I tried to twist without removing the connector too. It wouldn't budge though, probably because the wires are perfectly long enough to not give much slack. Good luck!
11-20-2019, 05:33 AM | #59 |
Rep 1,268
I hope H8 35w MTEC MT-471 bulb is still the one to go for in 2019 as i've just ordered a set.
I have adaptive lights where the fogs turn on as i turn the wheel so want to stick with halogen to maintain the soft on-off and avoid blinding people as i turn. |
02-14-2020, 04:25 PM | #60 |
Rep 351
How did that turn out for you? Yellow fogs are slightly annoying me during winter months.
02-17-2020, 05:41 AM | #61 | |
Rep 1,268
New vs Old below. |
02-19-2020, 01:44 AM | #62 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
Those really are a great match. 5k are too blue and 4300 too yellow. When my current 4300 Phillips die if the mteck still exist I will pick up a set.
For now they are new and close enough to not be notably different from the drivers seat, nor at first glance, which is to say good enough! |
04-21-2020, 05:41 PM | #63 |
Rep 1
So my wife tagged a garbage can with the right corner and popped the fog into the bumper. Broke one of the two tabs on the bottom and broke off part of the support panel. I can get a new support panel, BMW Support Panel 51-11-7-266-198, for $30 but anyone know how hard it is to replace it? or just I just try to jbweld the part back in place?
04-25-2020, 08:45 PM | #64 | |
Rep 2,197
https://www.newtis.info/tisv2/a/en/
07-11-2020, 04:25 PM | #65 |
Rep 458
I did my 2013 Lexus GS 350. No problem. Same with wife’s Highlander.
When I disconnected the socket wire on the 435 there was a lot more hardware and like a plastic box, couldn’t just twist out the bulb like on the other two. Also Toyota wires there cars way better than BMW. Thoughts on my problem ? Thank you Last edited by Chaos236; 07-12-2020 at 08:44 AM.. |
12-04-2020, 08:38 AM | #66 | |
Rep 1
