BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Another interior wrap (DINOC CA-421)
      11-07-2018, 05:53 AM   #221
japanwings
Belgium
118
Drives: 2018 F36 Gran Coupe
$5 and 1 hour work..i like the result
3D carbon wrap from Karlor (aliexpress)
      11-10-2018, 06:43 AM   #222
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: M4CPC // HP4 Comp.
Looks clean but I had let flown the waves of the wrap into the same direction.
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      03-26-2019, 04:19 PM   #223
mlev
mlev's Avatar
Drives: 2022 Tesla Model Y Performance
Reviving this thread...looks like the DINOC CA-421 matches the OEM Dry Carbon in the M Perf interior pieces. Can anyone confirm?
      03-27-2019, 08:05 AM   #224
Nomana
Nomana's Avatar
1466
Not much
Oem raw exposed cf is more textured.
There is no front oem raw matte cf vent trim and if you want to add that look to compete the interior (assume you already have all oem cf for interior), I think it's not a bad idea using Dinoc
      03-28-2019, 12:45 PM   #225
Dang3r
Schmollbraten
Dang3r's Avatar
I would partly agree, the CA-421 is the closest structured wrap to the OEM Carbon pieces of BMW. Had given up to try wrapping the shifter because of too much roundels, corners and so on...and at the end I fed up with the tries so I bought the Performance peaces at a dealer. After installation it was for me a match close to 90% and thats enough.
mlev370.00
      03-28-2019, 05:41 PM   #226
Doyvidlah
Drives: 2014 BMW 328i
Has anyone tried the carbon fiber "decals" off eBay?
I'd like to do this but am nervous about taking apart the Interior of my car
https://www.ebay.ca/itm/5D-Carbon-Fiber-Interior-Decal-Sticker-Trim-Package-For-BMW-3-Series-F30-F31/292973547505?fits=Make%3ABMW&hash=item4436958ff1:g :WnwAAOSwALdcc2~W
      03-28-2019, 09:37 PM   #227
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I wouldn't take a chance on that. Vinyl wrap has to be actually wrapped around the back of the part, otherwise it will peel off at the edges. Those decals don't look like they have enough material to do that.
As for taking apart the interior that's not optional, it's mandatory. The wrapped parts have to be removed to be wrapped.
      03-30-2019, 01:12 PM   #228
Dang3r
Schmollbraten
Dang3r's Avatar
Agree, if you havent any experience with wrapping I would highly recommend to buy a roll and try that way.
The decals wouldnt make it easier.
      03-30-2019, 02:19 PM   #229
Billfitz
Billfitz's Avatar
Buy a roll larger than you need. You will screw things up on the first few attempts. What I found to be key is a low wattage heat gun, mounted on a work bench, so you can hold the piece being wrapped in one hand, passing it through the hot air stream, using the other hand to stretch and place the vinyl.
      04-02-2019, 11:25 AM   #230
RCaSH193
Drives: 15 F30
First attempt came out pretty good
