BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Auto wipers
      01-14-2013, 02:55 PM   #1
Spacebug
Spacebug's Avatar
Drives: 2013 F31 320D M Sport
Auto wipers
Does anyone else think their auto wipers are a step behind the speed they should be at for any given level of rain?
Current: 2017 F10 530D, M Sport Plus, Graphite Grey, 19", HK, ProNav, HUD, Digital Dash
Previous: 2014 F10 525D, M Sport Plus, Carbon Black, 19's, ProNav, HK
2013 F31 320D MSport, 2013 F30 320D MSport, E91 320D MSport, 2002 E46 320i Vert, 1998 Lotus Elise 111S
      01-14-2013, 03:11 PM   #2
zofinger
zofinger's Avatar
England
319
Drives: F30 335d MSport
My previous car (VW) had auto wipers and the F30 are a step up. I'm finding them much better in terms of their speed for any given level of rain. You know you can adjust their sensitivity on the stalk right?
      01-14-2013, 03:13 PM   #3
Spacebug
Spacebug's Avatar
I've not really noticed that the adjustment makes much difference. Do you notice a significant difference?
My wife's Clio sport has auto wipers and they work far better.
      01-14-2013, 03:17 PM   #4
zofinger
zofinger's Avatar
England
319
Definitely. I typically have them set to the lowest sensitivity and it's ok for me. With finer rain I have to increase sensitivity.
      01-14-2013, 03:20 PM   #5
Spacebug
Spacebug's Avatar
Maybe mine is broken... I could not say I notice any difference.
Will have to look at this a little closer.
Thanks
      01-14-2013, 03:26 PM   #6
HighlandPete
Drives: BMW F11 535i Touring
Similar in my 535i. I'm in my 3rd long term BMW with auto wipers, they have all been superb, normally on the lowest setting with plenty of scope for increasing sensitivity if necessary. I'm up in the highlands, so plenty of experience in all kinds of rain.
Key to any auto wipers in my experience, is keep the screen clean, particularly around the sensor area. Worth cleaning with white vinegar to ensure there is no grease residue distorting the light, or the rain drops.
HighlandPete
      01-14-2013, 03:30 PM   #7
elgandashvili
Drives: F30
Thanks
Probably not broken. I feel the same way about mine.
      01-14-2013, 04:28 PM   #8
Doc943
Doc943's Avatar
Drives: F30 320d SE
Same.
      01-14-2013, 04:59 PM   #9
oop north
Drives: Subaru Outback 3.0R
The car I had for four days (330d) also seemed always too slow on the auto wipers for my liking
      01-14-2013, 05:14 PM   #10
Spacebug
Spacebug's Avatar
Glad it's not just me then, on second thoughts, actually that's not true. I was hoping it was just me and then I'd be able to get them sorted and they'd be usable...
Ah well!
      01-14-2013, 08:34 PM   #11
letsavit
Drives: BMW 320d sport
Yea, I have mine on highest setting and still manually wipe now and then.
      01-15-2013, 01:39 AM   #12
DieselRocket
Drives: 435d M Sport
I had exactly the same problem with my 330d for the first few weeks - i.e. it always felt like it was running too slow for the amount of rain.
I then had my car detailed and winter prepped, including getting all the glass cleaned and coated with Gtechniq. Since then, the rain sensors have behaved differently and I now keep them on either minimum setting or one up from minimum and all is fine.
So I guess the idea of keeping your screen clean around the sensor works.
      01-15-2013, 02:03 AM   #13
zofinger
zofinger's Avatar
England
319
No doubt that if the windscreen is clear (in/out) it helps. Especially removing oils/grease because, as suggested above, that can distort water which I gotta assume can't help the sensor. Hope that helps a little. Other than that you have a tech issue or simply the function doesn't suit your driving needs.
      01-15-2013, 02:09 AM   #14
KyleBerg
Drives: F30 335i M-Performance
I feel the same with mine though I'd say my car is nearly always pretty clean. But thanks for the suggestion - I will have a closer look at keeping the sensor area clean.
Kyle
      01-15-2013, 03:02 AM   #15
RobUK
RobUK's Avatar
Drives: 340i MPPSK
My auto wipers seem fine. I'm pretty fussy about having a clean windscreen plus I 'Rain-X' my windscreen now and then.
Life is a state of mind
      01-15-2013, 04:22 AM   #16
f1swk
f1swk's Avatar
36
Drives: f31 330d
works spot on in mine,must be the screen being clear
      01-15-2013, 04:45 AM   #17
TonyS
Drives: F30 335i
I was told a couple of years ago by a BMW tech (yeah, I know) that the wipers "auto-calibrate" on the first couple of sweeps, so if you're finding them not reacting to the rain well enough, switching them off and on again will force them to re-calibrate.
On my E46 this did seem to work, although it may just be placebo effect. So far my F30 has been fine, but it's worth a try if you've got this problem.
I'd be interested to hear if this has any effect or if it's just snake oil
      01-15-2013, 04:52 AM   #18
BMerman
BMerman's Avatar
Drives: F30 330D Msport
Mine was the same sluggish for the first few weeks, but after a few applications of glass polish and rain-x they are fine now
F30 330D Msport EBII - Arrived
Beige Leather - Burr Walnut - Avanced Parking - Prof Media - 403M wheels - Adaptive M suspension - Heated seats/steering wheel - Xenons - HK sound - M performance Grill/rear Diffuser - M Sport brakes
      01-15-2013, 11:58 AM   #19
Doc943
Doc943's Avatar
Drives: F30 320d SE
This crappy weather does build up a film quite quickly so will be extra vigilant on my weekend cleans.
      01-15-2013, 01:08 PM   #20
rjberry
rjberry's Avatar
Drives: F31 340i Ruby Red II
I've noticed first thing when I go out they are slow to wake up and I usually have to turn them off and then back on. Once they have been given this nudge they usually perform to the point where I don't notice them.
There are times when they are slightly out of sync with my needs but usually just as I'm about to reach for that button they come to life. If I didn't know better I'd swear they were just messing with me
      01-15-2013, 01:47 PM   #21
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
Too slow and always a step behind. Not as good as the Mercedes we had or my GTI.
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      01-15-2013, 04:06 PM   #22
DieselRocket
Interesting. I was about to complain to my dealer but the detailing put an end to that. It does sound like there might be a general issue on this.
In line with what others have said, my E46 M3 never skipped a beat on auto wipers and both my 5 series were perfect.
Wonder if it's something they can adjust or re-program if they get a lot of customers complaining.
