BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Major Coding Problem. Lost Access To Hu_entry
      01-14-2020, 03:26 PM   #1
MarkyMark1111
Drives: Bmw 320I
Exclamation Major Coding Problem. Lost Access To Hu_entry
I recently coded my BMW F30 320I. This was so to enable bluetooth media. I have since lost all bluetooth options and DAB. I tried to revert the changes by starting again, but when I go to HU_ENTRY to select code it is now greyed out.
Any and all help would be great appreciated!
as per https://www.bimmerfest.com/forums/sh...96&postcount=7
and youtube
      01-14-2020, 05:59 PM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Activate FA -> click on HU_ENTRY -> detect CAF -> select one and code.
Side note: if you don’t have CMB_MEDIA you can’t activate Bluetooth streaming by just coding HU_ENTRY
      01-14-2020, 10:06 PM   #3
MarkyMark1111
Drives: Bmw 320I
Thank you for the last piece of detail. I will then focus efforts on reverting the change.. Unfortunately detect CAF is also greyed out (as per screenshot).
I am using E-Sys 3.27.1 and Psdzdata 4.20.30.
Please assist further.
Many thanks
Last edited by MarkyMark1111; 01-15-2020 at 02:48 AM.. Reason: Further details added
      01-14-2020, 11:37 PM   #4
IK6SPEED
Drives: BMW M3 / AH3
Another example as to why those not experienced in coding shouldn't be doing this.
      01-15-2020, 02:36 AM   #5
MarkyMark1111
Drives: Bmw 320I
I can only agree and lesson thoroughly learnt, would appreciate some support in rectifying the issue.
Thank you
      01-15-2020, 05:40 AM   #6
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Download Esys 3.33.0
Your Esys is to old for the newest psdzdata.
You don’t need launcher for injecting CAFD.
If you need assistance, please send mee a Teamviewer request.
I’ll do it for you.
      01-15-2020, 05:43 AM   #7
MarkyMark1111
Drives: Bmw 320I
I’ll do it for you.
Hi that would be great, I'll private message you with my details.
Honestly really appreciate the support haven't slept all night..
      01-15-2020, 05:12 PM   #8
MarkyMark1111
Drives: Bmw 320I
HUGE THANKS Ibo24 . Via TeamViewer he connected to my laptop and BMW and rectified the issues. You have saved me many sleepless nights. Thank you for your help support and guidance!
      09-11-2021, 07:43 AM   #9
PonasUoantapas
Lithuania
Drives: BMW 328i F30
I’ll do it for you.
Hey, could you help me out with a similar issue? I tried activating Enhanced Bluetooth and apparently, things got out of hand as well. The code button is all greyed out and I no longer have most of the functionality from the ECU. :/
      03-07-2022, 12:26 AM   #10
ipeleng
Drives: BMW 320i (F30)
Having the same problem here.
      03-07-2022, 12:28 AM   #11
ipeleng
Ibo24, can you help me out as well?
      05-29-2023, 07:48 AM   #12
eiroh
Drives: F30 320i ED 2013
Hi everyone. Yesterday i tried the same things in my F30, changed 6NH to 6NL then code hu_entry but after that i lost acces to hu_entry CAFD. The problem is now my multimedia lost bluetooth connection, usb streaming rear camera and stuff like that. And it thinks its a F20 . Also i correct the VO coding back to original 6NL to 6NH again, but still have problem.
I can detect CAF and code CAFD, but still same problem accurs. Psdzdata is 4.37.31 and esys version is 3.27. Can anyone help ?
      05-29-2023, 08:57 AM   #13
TheNine90
Drives: bmw
Does it fail coding?
      05-29-2023, 09:32 AM   #14
eiroh
No it's not fail but i think its flashing wrong CAFD, because on the vehicle information screen i see f20. Now im downloading a full psdzdata file. Maybe there is missing CAFD file with the psdzdata i have.
      05-29-2023, 12:56 PM   #15
TheNine90
Drives: bmw
psdzdata is not issue. Check your fa
      05-29-2023, 03:46 PM   #16
eiroh
Is there a way to be sure my fa values is correct? Or can you give an example to check how it is correct?
      05-29-2023, 07:03 PM   #17
eiroh
Fix
Hi everyone, finally i fixed the problem and i will make a post to everyone who make mistake like i did to fix their problem by their own.
First of all i ask for latest E-sys and psdzdata files from shawn in this post: https://f80.bimmerpost.com/forums/sh....php?t=1814782
Then i install E-sys and psdzdata lite. You don't need a launcher to code CAFD in this E-sys version but it's limited and not let you play with CAFD settings like older versions do(this is another story).
First thing i do check the FA codes in the vcm menu according to this list;
S6NAA Car telephone in rear compartment
S6NBA Rear phone with cordless receiver
S6NCA Phone with cordless receiver
S6NDA Hands-free, Bluetooth + USB/audio
S6NEA Cell phone prep., Bluetooth + USB/audio
S6NFA Link, Music Player in mobile section
S6NGA Dummy-SALAPA
S6NHA Connection of mobile devices
S6NKA Enhanced connection of mobile devices
S6NLA Ext. connection mob. units and telematic
S6NMA MINI CONNECTED
S6NNA Hands-free kit
S6NRA BMW Apps
S6NSA - Convenience telephony extended with smartphone connectivity
I found this list on another website and start checking with the values i have.
So i decide to delete 6NK on the Salapa element and save it.
After that i read the VCM and get the list. Now with the new program i was able to see something, but CAFD name was:CAFD_FFFFFFFF_255_255_255.
And it means something is wrong.
Then i click the hu_entry tab and click the "Detect CAF for SWE" button on the right. The program give me a list of suitable CAFD files.
There was only two suitable CAFD files, i select the bottom one and click OK.
After that i saw one corrupted and one good CAFD unter the hu_entry tab.
I select the good CAFD file with green sign next to it and click code.(I didn't select the hu_entry, i select the CAFD and click code).
After coding everything was like as it should be. Multimedia was working properly. So i disconnect, close the program and reconnect the car again to see everything look okay.
After seeing this im totally sure everything is okay.
I decide to post this because there is not so much clear information about this problem and so many people who bought his BMW older than 2013 trying to enable bluetooth streaming.
My advice guys, make a flash drive with the musics you like and drive . Or buy a nbt if you have money
coding 3 series, e-sys, f30, hu_entry
