      01-01-2013, 08:52 AM   #1629
shawnsheridan
shawnsheridan's Avatar
Originally Posted by kon View Post
and confirmed working for F30, but it appears vehicle with older version of "implementation" don't have this menu option...
It seems to have been added in 48.x, but not for the F10. Is there an actual "M Performance" option on the F30 that this eye candy goes along with?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      01-01-2013, 08:52 AM   #1630
shawnsheridan
Originally Posted by clarence View Post
Not prewired for 6NF, as it's only for connecting to the sharkfin antenna (for better phone signal). 6NF has connection to both USB in combox & sharkfin simultaneously if u use a media cradle.
Thanks for clarifying.
Anyone have a picture of this connection?
      01-01-2013, 08:55 AM   #1631
kon
Singapore
Drives: F30 310i > G20 310i
F30 code is the same as F20? and there's a M135i out there... so...
      01-01-2013, 08:56 AM   #1632
shawnsheridan
Ok. That makes sense then. With a M135i, it is probably set to mpm by default.
      01-01-2013, 08:57 AM   #1633
clarence
Drives: F30 328i M-Sport
Is the Country Controller the 8xx Option Codes, like 801 for Germany, and 812 for England? I can't find one in my VO, so I guess there isn't one for U.S.?
Is there any other impact of removing a Country Controller?
Yes, 8xx are the country controllers. I doubt there are much impact apart from some items that are mandatory by law (e.g. belt reminders, warning screens etc.) where they'll get disabled.
No, there doesn't seem to be one for US.
      01-01-2013, 09:00 AM   #1634
kon
Singapore
anybody knows the code to disable the seat belt chime?
I did fdl coding using the cheat sheet, but it still continue to chime...
3000 Ausstattungsflags SeatBeltReminder_SBR_Fahrer
Found another cheatsheet, but couldn't find the option in ACSM 3000:
3000 SBR_FA_GWF_SBR_FA
3000 SBR_BF_GWF_SBR_BF
What did I do wrongly?
      01-01-2013, 09:04 AM   #1635
kon
Singapore
so by removing country controller, it becomes "USA" enabled?
      01-01-2013, 09:09 AM   #1636
shawnsheridan
You list only the Driver's side.
For F30 you should code both of these:
SeatBeltReminder_SBR_Fahrer (Driver)
SeatBeltReminder_SBR_Beifahrer (Passenger)
Double check that both are set to nicht_aktiv.
This won't disable the short initial Gong on starup though, just the persistent one.
      01-01-2013, 09:11 AM   #1637
dos1973
Drives: F30
where can i find this country controller.
which file?
      01-01-2013, 09:13 AM   #1638
shawnsheridan
which file?
In your FA (VO) along with all your other option codes, listed under SALAPA-Element.
      01-01-2013, 09:14 AM   #1639
dos1973
Drives: F30
never understand how to action with this "Salapa"
so. better i don't touch it
      01-01-2013, 09:18 AM   #1640
shawnsheridan
Scroll up 15 posts to here:
http://www.f30post.com/forums/showpo...postcount=1624
Click the link in my thread, and you will understand SALAPA-Element.
      01-01-2013, 09:24 AM   #1641
shawnsheridan
Ok. It is the 8Lx ones (not the 81x ones I listed). It seems for U.S., Europe, and Malaysia (VIN's I knew and could check), there are no Country Controller codes, but here is what is available, and known to me:
S8L1A
S8LBA
S8LFA
S8LHA = Hong Kong
S8LMA
S8LRA = Russia
S8LSA
S8LTA
If anyone has any of the unidentified ones, please advise what code you have and what country you are in.
Thanks!
      01-01-2013, 09:24 AM   #1642
kon
Singapore
Thanks Shawn, our market doesn't value life of passenger, so all passenger options are off by default.
      01-01-2013, 09:27 AM   #1643
shawnsheridan
Haha...your spouse may disagree.
So did you get it working, or in this case not working as desired?
If that didn't work, you can try it the BMW way using K-Words in your FA.
      01-01-2013, 09:40 AM   #1644
shawnsheridan
As ur car have 6.5" screen & radio professional, so u physically have a headunit called "L7 Entry" (infotainment platform shared by F20). CIC is only physically installed if u have professional nav.
I think wht's happening here is, as basic BT function is built into the L7 Entry HU, if u have 6NH then there's no combox. If u have nav pro then, as it doesn't have built-in BT, if u have 6NH then it'll come with a combox with some features disabled.
For the combination of L7 Entry + 6NK/NL, the BT hardware is not present in the headunit as a combox is present, hence a different HU p/n is present.
This has never been clear to me, but is 606 Business Nav an option on the F30 in some markets, and if so, is Head Unit considered a CIC?
      01-01-2013, 09:42 AM   #1645
kon
Singapore
I code it for my frens, I refuse to code the chime on my ride as I want to make sure everyone buckle up I'll ask him to monitor though. I think the chime we heard could be as you described, the initial one and not the persistent one.
      01-01-2013, 09:48 AM   #1646
dos1973
Drives: F30
@Shawn, what would we do without your knowledeg
just to doublecheck:
Salapa Elements are my Loaded Extra in the car? right?
Does this mean I can add as "example" the extended BT:
I add to the below textfield (with the numbers the big one) : 6NL ???
and then all values are set for this, which I have done manually?
      01-01-2013, 09:49 AM   #1647
shawnsheridan
I don't know on the F30, but for the F10, the initial Gong can be coded on or off in the same section of ACSM / 3000 via:
Initialwarnung_GWF_IW
In your case then, since you like the Gongs, you can enable the passenger one.
      01-01-2013, 10:02 AM   #1648
dos1973
Drives: F30
Hi works on F30; Thanks to Illhan :-)
Seatbelt alarm driver
ACSM 3000 SBR_FA_GWF_SBR_FA
Seatbelt alarm passenger
ACSM 3000 SBR_BF_GWF_SBR_BF
Display seatbelt driver
ACSM 3000 Gurtzustandsanzeige_Fahrer_GWF_GZA_FA
Display seatbelt passenger
ACSM 3000 Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF
set to: nicht aktiv
      01-01-2013, 10:06 AM   #1649
kon
Singapore
set to: nicht aktiv
That's the problem, I can't find the first two line in acsm fdl file.
      01-01-2013, 10:07 AM   #1650
shawnsheridan
A couple things here.
1) Your SALAPA-Element's are your vehicle's unique option codes (e.g. 205 Automatic Transmission, 609 Navigation Professional, 2VL Sport Steering, etc,)
2) You cant add or code anything "on" that requires hardware you physically do not have, whether through FA (VO) Coding or FDL Coding.
3) You can accomplish everything via FDL Coding if you know what you are doing, although it can be more tedious when there are many changes required. But for instances where you don't fully know all the required FDL Codes to enable a feature, or for ease, if you have the required hardware, you can alter your VO Option Codes, and then VO Code a module(s), which will code the entire module, all at once, making all the FDL changes for you to support every Option Code in your VO.
So for example, removing 6NH from your VO and replacing it with 6NK won't automatically get you Enhanced Bluetooth functionality unless you physically also have a Combox.
