BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > M sport - Is anyone digging the 18" more than the 19"
      03-19-2012, 04:03 PM   #23
cstavaru
cstavaru's Avatar
313
Drives: 2009 335i M Sport Sedan 6MT
Originally Posted by okolisr View Post
I haven't seen this mentioned this yet, but I always learned that the main performance benefit from larger-diameter wheels (with lower-aspect-ratio tires to keep the same overall diameter) is NOT because of the larger wheel size, rather it's because of the lower aspect ratio of the tires which results in REDUCED TIRE SIDEWALL HEIGHT. With reduced sidewall height, tires do less flexing and floating while cornering, for better stability and road contact.
This is not true. If you look closely, the BMW Motorsport race cars have 18" Advan RS wheels (or custom BMW style). Also look at Formula 1 cars. Too little sidewall height results in loss of grip. Plus, larger wheels means that the wheel barrel must travel at a higher speed (because it is farther from the wheel center) which increases the force needed to rotate the wheel. Larger wheels = less performance, but better looks.
      03-19-2012, 04:48 PM   #24
Red Bread
Drives: Smog machines
F1 has 15" wheels because Max Mosley says so. But yeah, even LeMans cars tend to run 18's, without as many regulations as F1.
      10-15-2012, 02:33 PM   #25
claykin
Drives: various BMW
Originally Posted by MacAttackBMW View Post
I prefer the look of the 19's. Agree that the look is the main factor but given then staggered size and slightly bigger footprint on the road, I don't agree there is no performance impact. Sure, they may be slightly heavier but given that they are forged alloys - that's negligible. You are good either way but let's not knock the 19's!
Where did you read the 403M wheels are forged aluminum? I suspect the option would be more than $800 if the 18s were cast and 19s forged.
      10-15-2012, 02:41 PM   #26
SamS
I like the 18" 400M wheels much better. There is zero performance benefit to the 19s, if anything they are a cost and performance hindrance. I normally get the biggest OEM wheel possible, but it seems the 19" (and 20" for that matter) are strictly a cosmetic upgrade, and will be a detriment to ride quality.
      10-15-2012, 02:55 PM   #27
clarence
Drives: F30 328i M-Sport
They're not.
From http://felgenkatalog.auto-treff.com/, the 400M weighs 11.8kg whereas the 403M weighs over 13kg.
      10-15-2012, 03:02 PM   #28
draco4691
Contractor
draco4691's Avatar
Drives: 335i XDrive M Sport AW
19" M sport wheels +1
      10-15-2012, 03:07 PM   #29
SamS
Originally Posted by clarence View Post
They're not.
Good site, I always forget about it.
Shows the 403M weigh 3lbs more per wheel than the 400M. And that doesn't take into account any increase in tire weight of the 19" version.
      10-15-2012, 03:08 PM   #30
justinnum1
Drives: 2018 330i Msport 6mt
I like the design and how they look, but i dont think it makes sense to pay extra money and lose performance. Thats extra weight where you dont want extra weight.
      10-15-2012, 03:12 PM   #31
SamS
Exactly. And I'd rather tighten up the suspension (M-adaptive) and have some extra sidewall cushion on the 18". Otherwise you risk your fillings rattling out when you hit every seam in the road.
      10-15-2012, 03:12 PM   #32
FlyByNite
Drives: 2019 M4 Comp.
2019 M4  [0.00]
2016 BMW M3  [0.00]
2011 BMW 528i  [0.00]
19's!
      10-15-2012, 03:15 PM   #33
Mrcarcrazy
Sarcasm free with all posts.
Drives: 05 Elise REV310
The 19's look so much better in my eyes. Since this is a family sedan theoretical "performance differences" are not a valid statement on either end IMO (and I'm always right, so don't bother trying to sway me).
With the 18's the car needs to be lowered to look right, on the 19's it looks great as is. Not to mention with the 19's everyone knows you are hot shit. 19's are a requirement to be awesome...sorry guys, but it's like having a 328.
The best 2013 M sport is owned by me.
      10-15-2012, 03:21 PM   #34
justinnum1
Cant take a anything you say seriously anymore. Sorry.
      10-15-2012, 03:23 PM   #35
pkimM3r
pkimM3r's Avatar
205
The bottom line is that even though I do faster cornering in my BMW than 95% of drivers, I don't need the "ultimate" capability. The 18" 400M wheels are plenty good enough.
And they look great.
professional racer?
      10-15-2012, 03:33 PM   #36
Mrcarcrazy
It's probably best, since the majority of my posts are placed entirely to entertain myself.
I will say though, that if you're looking for all out performance and running runflats, you should take a second look at that.
      10-15-2012, 03:59 PM   #37
JUSKIDN
JUSKIDN's Avatar
Drives: 2013 EBII 328i M Sport
I like both but more partial to the 18's because thats what i have
      10-15-2012, 04:35 PM   #38
WilliCO
WilliCO's Avatar
Drives: 2013 F10 535 xDrive MSport
Originally Posted by pcbrew View Post
M-Sport 18s ARE staggered
Same staggered widths as the 19s, just slightly higher profile.
403M are 225/40 front and 255/35 rear
Agree.
IMO, as regards looks - the tire width makes a lot more difference than the wheel diameter. 18" is a large enough wheel to look good on the F30 body. A 19 may or may not look better, but unless you're looking at two cars side by side having each, you won't see the 18 as a "small" wheel.
Having those wide 255s in the rear is what makes the car look muscular, again IMO. 275 would be even better.
-Will
2013 535i xDrive M-Sport | 2005 545i Sport (Retired and missed) | 2001 X5 3.0 Sport (Retired)
      10-15-2012, 04:39 PM   #39
MaestroAl
Drives: 335xD
When the first M Sports arrived at my local dealer, I went into their lot with my guy and looked at them all, having been previously adamant I'd get 18s. Then I saw a car with 18s next to a car with 19s and suddenly 19s were very, very high up on my must have options list.
I was robbed
In isolation, the 18s look awesome. Next to the 19s they look wrong. But since nobody else on my road, no wait: estate, no wait: town has an F30 M Sport then I coulda got 18s and been very happy with them
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH
      10-15-2012, 05:18 PM   #40
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
I was robbed
Same here. I went to the dealer with the intention of ordering 18's. They had a red sportline with 19's....i was sold!
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      10-15-2012, 05:58 PM   #41
DerekS
DerekS's Avatar
197
Drives: '24 X3 M Sport
Yes, so true !!! 19s are also heavier than 18s.
      10-15-2012, 07:09 PM   #42
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
Someone who truly understands the internet, and how to enjoy it!
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      10-15-2012, 08:01 PM   #43
iwannabimmer
iwannabimmer's Avatar
Drives: 2009 mazda6s grand touring
I like the design of the 18s but I think the F30s look better with 19s in terms of size. Some aftermarket wheel company should make replicas of the 18s design in size 19.
      10-15-2012, 09:35 PM   #44
zibawal
Drives: 2012 X5D
OP would you like to swap for 19 incl tires? Lol
