04-26-2013, 03:46 PM | #3389 |
Rep 53
Who can sum up all working cheats in a spreadsheet for us
Youtube: Noyan 22 K Followers and growing
F30 320i ED LuxuryPlus Imperial Blu-Saddlebrown HarmanKardon, Memory Sport Seats, High beam a., anthracite headliner.... SOLD F10 520i N20B16 Mediterranean Comfort Zintbraun Dakota Seats Shadowline NBT Led Adaptive Headlights Harmankardon Active Cruise Control 2017MY @production |
04-26-2013, 03:57 PM | #3390 |
Rep 40,763
04-26-2013, 04:07 PM | #3391 | |
Rep 53
04-26-2013, 06:26 PM | #3392 |
Rep 169
Hi guys, this thread is a little bit overwhelming. So much information.
Could someone please tell me if the first post in this thread, is still valid? Can I use this as a tutorial to get connected & obtain the right cables? Thanks in advance. |
04-26-2013, 07:31 PM | #3393 |
Yr1OfD1
107
Rep 900
the first post was right on. but as of today, updates were implemented on the new E-Sys 3.22.5
you can still use the step by step procedure created by the OP. that is the guide i used but mine is a little different because of the latest version of E-Sys here is my folder structure running 3.22.5 and psdzdata 49.1 |
04-27-2013, 08:02 AM | #3394 |
Rep 67
Can anyone pm me couple files? Thanks in advance.
cafd_000000f9-007_003_020 cafd_00000794-004_124_042 cafd_00000223-013_008_002 cafd_000007a1-005_022_031 |
04-27-2013, 08:19 AM | #3395 | |
Rep 41
Thank you so much for your prompt reply. I saw this in my FP today "8TN" which is a VO code for Non Xenon DRL.So I am wondering if Non Xenon(W/o Angel eyes,just normal DRL Lamps)& Xenon(with Angel eyes) Headlights have different VO codes for DRL.In case yes could you please tell me what is the VO Code for DRL of Xenon Headlights(with Angel Eyes)?So if VO code is different I think I need to change this code as well before I can code FEM_BODY right? thanks in advance Harman |
04-27-2013, 09:12 AM | #3396 | |
Rep 4,553
Also, do these customizations, such as remove disclaimer, video in motion, folding mirrors on lock, TPMS, etc. get cleared and defaulted after dealer performs software update? My car is scheduled to go in for the 3/2013 software update now that BMW has resolved the updating issues.
2023 840GC | 2021 740i | 2019 X3
04-27-2013, 10:35 AM | #3397 | |
Rep 40,763
As for your "customizations", when the dealer programs your car, they are all returned to their default state in accordace with your Vehicle Order, so yes, they are cleared.
04-27-2013, 10:55 AM | #3398 |
Rep 40,763
PM sent.
04-27-2013, 11:08 AM | #3399 | |
Rep 40,763
Adding newer CAFD's to an older PSdZData library does not always work though as the newer CAFD's often require newer binaries as well (.jar, .dll, .etc), so you may still require a full PSdZData update.
04-27-2013, 11:41 AM | #3400 | |
Rep 40,763
If you have stock Xenon lights though, and all you are trying to do is enable the Angel Eyes as DRL, then the VO Code is: 8TL Daytime Lights Front and Rear Active And if you have CIC, you can also enable this to add a checkbox under iDrive Options to turn on and turn off DRL: 8TN Daytime Lights About Light Menu Adjustable Lastly, once you have DRL's working, I think you can FDL Code this to enable the rear DRL's as well: FEM_BODY => TFL_MODUS = drl_s (U.S.) or = tfl_s (ECE)
04-27-2013, 11:53 AM | #3401 | |
Rep 4,553
The retrofitters do this so retrofitted options continue to work after BMW software updates. |
04-27-2013, 12:14 PM | #3402 | |
Rep 40,763
As for the OP's original question regarding his customizations though, everything FDL Coded will be wiped out by dealer programming.
04-27-2013, 01:16 PM | #3403 |
Rep 67
Shawn, Thanks again. You are always the Man. I will give it a try before I am going to download the full version. The 4 files were much quicker to download.
04-27-2013, 01:18 PM | #3404 |
Rep 40,763
No doubt about that. I hope they work for you.
04-27-2013, 08:13 PM | #3405 |
Rep 67
Shawn, you are right. I just tested coding and Cafd_000000794_004_124_042 does not work for Rem_Body. Currently I am on E-sys 3.18.4.
Btw, how do I find out what version of Daten file I am on? Last, can you please pm me the latest e-sys and full psdzdata update. Thanks. |
04-27-2013, 08:18 PM | #3406 | |
Rep 40,763
TargetSelector: Project=F020_13_03_503, VehicleInfo=F020 PM sent.
04-27-2013, 08:29 PM | #3407 |
Rep 67
Shawn, you are super fast. Thanks.
What is the latest version of e sys without need of token? do you have a link to that too? |
04-27-2013, 08:35 PM | #3408 | |
Rep 40,763
PM Sent.
04-28-2013, 01:00 PM | #3409 |
Rep 304
Okay so I got all the downloads done, installed, and patch/token applied. I attempt to open up ESYS and cant get through the "Loading ESYS screen". It gets to the Creating Log file on the progress bar and then just closes and nothing happens. Any idea ?
04-28-2013, 01:10 PM | #3410 | |
Rep 41
But because I had to disconnect the battery terminals so that I could play with the wires ,after I connected back the system has started to throw an error/reminder which is unrelated to whatever I did with the wiring or headlights.The system shows my car is due for service,i think because the date in the system corresponding to service is 12/2001 though I have already changed the date and time from the settings menu which got reset but its still unchanged and still throws error/reminder.please help! |
