03-05-2014, 07:21 AM | #45 |
Rep 15,858
A thought...
Has anyone actually asked BMW Technical Department (not BMW UK CS) the question... can an alternative lowered spring be fitted to xDrive? The answer may be no, but there may be some reasoned answers given. HighlandPete |
03-05-2014, 07:32 AM | #46 |
Rep 19,982
Any evidence as to why this would make a difference? I can see why that might be an option, but what if the xdrive damper has other characteristics which are more relevant to the car than the sdrive ones, outside just the ride height?
03-05-2014, 07:47 AM | #47 | |
Rep 385
An X drive Adaptive with lowering spring would be out of range. An S drive wouldn't be as far out. * Assuming S drive = 15mm lower than X drive.
Current:
Range Rover Sport - Alpina D3 Bi Turbo |
03-05-2014, 07:52 AM | #48 | |
Rep 19,982
I can see how a spring could be made progressive, but even on adjustable dampers you are adjust the rebound and/or compression, but that would still be a fixed rate throughout the working range surely?
03-05-2014, 07:57 AM | #49 | |
Rep 385
Move them out side of their designed range and you open up lots of random problems, even such things like heat evacuation start to be an issue.
Current:
03-05-2014, 08:28 AM | #50 |
Rep 19,982
So I guess this is why a proper coilover set can be so expensive?
03-05-2014, 08:30 AM | #51 |
Rep 385
Especially when you move into the world of remote reservoirs etc.
Current:
03-05-2014, 09:11 AM | #52 |
Rep 11,292
I’m not sure how you contact the BMW technical department but I emailed the question to BMW before I got my car. I was told to contact my local dealership for information on this as I was told they are “fully trained in all technical aspects of BMWs”. I never bothered contacting them as they probably wouldn’t have a clue.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack Last edited by dopper99; 03-05-2014 at 09:17 AM.. |
03-05-2014, 12:19 PM | #53 |
Rep 53
Hi guys, whilst I do really appreciate all the constructive and technical feedback, the way I see it is a bit more simple. It's my car I own and I'll do with it what I want, I'll take advice from people I trust and give it a go, if it doesn't work out I must accept the problem and deal with it, change it back, keep it whatever?! I believe from my non technical, simple minded view it will run and corner as good as it does now which will be fine for me!
I've been into birds bmw today and explained what I'm after and Kevin knew exactly what he was talking about and we compared my car to several other models he has and it really does sit to high, looking to drop around 30mm front and 25mm approx rear. I'm just waiting for him to get back to me with a firm solution which he believes he has sorted then get booked in! I'll keep you all posted!! Dan. |
03-05-2014, 12:24 PM | #54 | |
Rep 19,982
03-06-2014, 06:56 AM | #56 |
Rep 53
Hi all, just to keep you posted. Ok the solution is sorted, drop the car 20mm on eibach springs, spring rate, ride etc is maintained - there is a restriction on the suspension that is way to complex for me to understand is 20mm enough, a question for me?
Solution 2 is to use a much harder h&r spring, will drop 40mm, probably too much anyway but ride quality will be severe and probably hit the stops. Anyway there you go. 645+vat. Now it's make up my mind time!! Dan. |
03-06-2014, 07:05 AM | #57 | |
Supreme Being
1804
Rep 5,425
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
03-06-2014, 07:23 AM | #58 |
Rep 11,292
Yep, fair play to you Dan for pioneering this (in the UK anyway). Will be interesting to see what you go for and how it looks.
You know you'll have LOTS of envious xdrive owners drooling at them pics....
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
03-06-2014, 07:49 AM | #59 | |
Rep 19,982
03-06-2014, 07:52 AM | #60 | |
Rep 3,445
Drives: G22 M440D
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
03-06-2014, 08:01 AM | #61 | |
Rep 53
Hope that helps a little. |
03-06-2014, 08:02 AM | #62 |
Rep 53
03-06-2014, 09:34 AM | #63 |
Rep 816
20mm sounds good to me - a little lower than an M-sport s-drive, which actually keeps it quite discreet, whilst maintaining the ride quality. If it reduces body roll as well then it would get my vote
03-06-2014, 10:22 AM | #64 |
Rep 11,292
Are you going to change the ARB to the one as fitted to the 330d? That will also improve body roll of course.
03-06-2014, 10:24 AM | #65 |
Rep 19,982
It will save labour costs if all done at the same time too. The ARBs need the subframes dropped to be done, so not a simple job!
