08-16-2013, 04:08 PM | #1 |
Rep 387
Is it possible to clear check engine codes with Esys / an ENET cable?
I coded some stuff in the Kombi box and triggered a check engine light somehow, the car is running fine. Is there a way with the ENET cable to to check the codes and clear them?
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
08-16-2013, 04:40 PM | #2 |
Rep 3,225
You can try Tool32 and with thanks to Shawnsheridan, this is how you do it.
There are two versions of Tool32 in EDIABAS so make sure you use the German version as the English one won't work. Assuming the fault condition no longer exists, to clear the fault code. 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it. Good luck H |
08-16-2013, 09:03 PM | #3 | |
Rep 387
That worked perfectly, thanks so much!
08-17-2013, 11:52 AM | #5 |
Rep 453
Let's chat about this a bit further as I was wondering the same thing.
Recently I had a bad experience after changing my spark plugs. The car was in limp mode, CEL on, and it would not start at all. There were TONS of codes stored when the car got to the dealer. But I ran Tool32, all of the steps described above, and it did not find ANY codes. Thoughts? |
08-17-2013, 08:10 PM | #6 | |
Rep 40,733
09-08-2013, 08:07 PM | #7 | |
Rep 27
When I try to load the prg file the program just hangs... and if I click stuff I get different errors of OCX files missing, but they are in the folder... any thoughts?
Thanks, Quote:
09-08-2013, 08:30 PM | #8 | |
Rep 40,733
Are you connected to the car, with power on the car when you try it?
09-08-2013, 08:42 PM | #9 |
Rep 3,225
12-19-2013, 08:51 AM | #10 |
Rep 17
I'm trying to use Tool32, but I think I have the English version, not the german how i can get the german version. Thanks
ED 2014 335i M-Sport AW - Sport Automatic, 403M, M Sport Brakes, NBT, Hupper Optik - 40% Tint, M Performance Black Kidney Grille, Rear Spoiler and Front Lip
Coming Soon: Borla Cat-Back S-Type |
12-20-2013, 02:00 PM | #12 |
Rep 17
What worked for me after reading for a while is to copy to C:\Windows\SysWOW64 the following files "MSLFXGRD.OCX" and "Richtx32.ocx" from C:\EDIABAS\Bin and register the using Command Prompt as an Administrator with the following command regsvr32 C:\Windows\SysWOW64\MSLFXGRD.OCX and regsvr32 C:\Windows\SysWOW64\Richtx32.ocx. I think this problem only happens in computer running 64bits. Hope that helps
01-14-2014, 02:17 AM | #13 |
Rep 68
Drives: 2013 F30 328i
Hi guys, I got the coding pack, but not sure where the german version of tool 32 is? There is only 1 tool32 in bin?
01-14-2014, 03:07 AM | #14 |
Rep 3,225
I'm not sure what Shawn now sends out mate. Just try the one and see if it works. If it's not the correct one you will notice it just hangs when you try to use it.
01-14-2014, 03:17 AM | #15 |
Rep 68
Ok, figured it out. Had to run it as administrator.
01-14-2014, 09:42 PM | #16 |
Rep 17
I had the same issue with Tool32, I needed to run it on windows pro because it was 32bit and my machine only ran 64bit (or windows xp/vista). I tested this on a few computers too and that was the common denominator.
01-15-2014, 12:59 AM | #17 |
Rep 458
I found when VO coding the KOMBI it reset the date and time. This causes the warning triangle to appear and setting it correct on the iDrive clears it.
03-21-2014, 06:30 PM | #18 | |
Rep 19
03-21-2014, 11:06 PM | #19 | |
Rep 40,733
PM sent.
03-29-2014, 03:12 PM | #20 |
BooGooBird
17
Rep 79
03-29-2014, 04:18 PM | #21 |
Rep 40,733
PM sent.
Largo5.00 |
06-02-2014, 03:55 PM | #22 |
Rep 7
Hi Shawn
I have an engine code also. Do you have the latest tool32?
2021 C43 AMG, 2009 E350, 2016 Audi A6 3.0T (Sold), 2014 BMW 528i///M-Sport (Sold), 2016 BMW 340i///M-Sport (Sold), 2014 BMW 335i///M-Sport (Sold), 2006 E60 530i (Sold), 2001 E46 330i
