BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Issues with 6WB DKombi retrofit - help needed
      09-12-2017, 09:42 AM   #1
raystinger
Drives: BMW F30
Hi guys, I have recently installed the F30 6WB and after VO coding it and my NBT_EVO2 (retrofitted last year, flashed to my vehicle vin, no emulator), it works for the most part except for the following issues [all solved]
1. The digital cluster does not show the gear selection under the tachometer. e.g.no display of PRNS anywhere on the cluster. - solved by VO coding DKombi with factory FA production code.
2. NBT_EVO2 Nav stopped working - when I entered the Navigation page, it prompted me with the following "Connect USB device with correct activation code to start navigation" - solved by getting NBT_EVO2 seller to send me the FSC code that originally came with the head unit.
Steps I have taken:
1. Inject CAFD into DKOMBI
2. Read VO -> Edit VO -> Remove 6WA, Add 6WB -> Calculate FP -> VO CODE NBT_EVO2 and DKOMBI
My car is a March 2012 F30, but due to NBT_EVO2 retrofit last year, the production date in the VO was changed to 0716. So I used this production date to VO code both DKombi and NBT_EVO2. Also tried changing the production date to 0717 and 0615 then VO code. None of them manage to bring up the gear selection. And in the process, I think the Nav FSC also got broken, resulting in problem #2.
Any help on solving these two issues are greatly appreciated. Thank you!
      09-13-2017, 12:42 AM   #2
raystinger
Drives: BMW F30
Update - fixed issue #1 by VO coding with factory FA production code
Looks like when VO coding with various FA production code, it has inadvertently broke the FSC in my NBT_EVO2. Any idea how to fix this? Thanks.
      09-17-2017, 07:23 AM   #3
Rick4345
Rick4345's Avatar
Drives: 2017 M2 6MT LBB
Maybe you can get in touch with shawnsheridan and get the newest maps.
It should come with a new FSC code.
I'm not an expert in the field. Just a thought.
      09-19-2017, 09:42 PM   #4
raystinger
Drives: BMW F30
Update - fixed #2 the map issue by getting the NBT_EVO seller to send me the FSC code that originally came installed with the head unit. Also thanks to shawnsheridan for his advice via PM.
All issues fixed
      09-19-2017, 10:15 PM   #5
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
All issues fixed
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      11-30-2017, 12:59 PM   #6
emmy_aquarius
Drives: Bmw F30 2013
Hello can i install 6wb on bmw f30 2012 model if yes which part no is compatible
please guide me
      12-22-2017, 02:11 AM   #7
vfx19
Drives: 2015 BMW 320i
Dkombi deleted
I was trying to read the Dkombi folder on SVT but error pops up and unable to read. I was trying to inject a cadf but instead the Dkombi folder is gone. Is there any way to bring the Dkombi folder back? Please help. Thank you.
