BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Super Cheat Sheet - PDF Attached! [Updated July 1st, 2015]
      08-06-2014, 08:14 PM   #1
Halsifer
Halsifer's Avatar
Drives: 2014 335i xDrive M-Sport
LATEST UPDATE:
Updated to v1.7 (07/01/2015 1:30AM CST): (Download attached below, or click here)
  • Added FA Code: Sport Auto Transmission - Enable SAT for quicker and smoother shifts.
  • Added Code: ‘ICMKOD_B_SPORTINDIVIDUALISIERBAR’ - Allows Macro_fds to function. Sport Mode Configuration.
  • Added Code: ‘KOMFORT_OEFFNEN’ - Delay before activating Comfort Opening
  • Added Code: ‘C_ZSW_Aktivierunggeschwindigkeit_Funktion_low’ - Change Active Blind Spot Activation Speed.
  • Added Code: ‘NAVI_ROAD_PREVIEW’ - Enables ‘Route Info’ (Turn-By-Turn Directions)
  • Added Code: ‘EINAUSSTIEGSHILFE’ - Activates Easy Entry when entering the vehicle.
  • Added Code: ‘MEMORY_GONG’ - Enables chime when seat position successfully stored in memory
  • Added Codes: Active Sound Design Modification (Change to M3/M5/Disabled)
  • Added Codes/Section: Active Spoiler (F34 3-Series GT only)
  • Added Test Codes: ‘REGEN_SCHLIESSEN’ - Close Sunroof on Rain Detection
  • Changed Code: ‘NAVI_FLIGHT’ -> ‘ROUTE_FLIGHT’ (Updated Name)
  • Changed Description: Enhanced Bluetooth (Added difference between 6NK & 6NS)
  • Changed Description: ‘Macro_fds’ (Now working with all Head Units)
  • Changed Description: ‘TFL_Modus’ (Gave difference between Tfl_s and Drl_s)
  • Fixed Code: ‘SL021_IBA_3’ -> ‘SL21_IBA_3
  • Fixed Code: ‘MAPPING_TAGAHRL_H2_L_OUTPUT’ -> ‘MAPPING_TAGFAHRL_H2_L_OUTPUT
  • Fixed Code: ‘MAPPING_TAGAHRL_H2_R_OUTPUT’ -> ‘MAPPING_TAGFAHRL_H2_R_OUTPUT
  • Fixed Description: SeatBeltReminder_SBR_Beifahrer & SeatBeltReminder_SBR_Fahrer (Was Reversed)
  • Moved Code: ‘TFL_MODUS’ to Day-Running Lights & Activate Rear Fog Lamps
  • Moved Code: ‘Daydriving_light’ to Day-Running Lights & Activate Rear Fog Lamps
  • Removed Code: ‘ASD_SOUND_OFF’ - Varied Results. Replaced with Active Sound Design Section.
  • Removed Code: ‘KOMFORTSCHLIESSUNG_PA’ - Unnecessary. Active in all CA cars by default.
  • Removed Code: ‘RLS_FLC_SCHWELLWERT_SATZ’ - Not found in F30, only F10.
  • Removed Code: ‘MAPPING_UNIVERSAL_6_OUTPUT’ - Unused.
  • Removed Code: ‘MAPPING_UNIVERSAL_7_OUTPUT’ - Unused.
  • Removed Code: ‘Sportschalter’ - Replaced with Sport Auto Transmission FA/VO Coding
  • Removed Code: ‘Sportschalter_alt’ - Replaced with Sport Auto Transmission FA/VO Coding
  • Verified Code: ‘KOMFORT_OEFF_HINTEN’ -> Moved to 'General Locking/Window Features & Convenience Features'
  • Verified Code: ‘KOMFORT_OEFF_SHD’ -> Moved to 'General Locking/Window Features & Convenience Features'
  • Verified Code: ‘KOMFORT_SCHL_VORNE’ -> Moved to 'General Locking/Window Features & Convenience Features'
  • Verified Code: ‘KOMFORT_SCHL_SHD’ -> Moved to 'General Locking/Window Features & Convenience Features'
*Any codes added or changed will have the function and description bolded in the cheat sheet.
**If you decide to test codes in the 'TO BE TESTED' section, please let me know your results!
Previous Versions:
v1.6 (12/23/2014 11:45AM PST):
  • Added Code: 'CLM_TIMEOUT_HK_SMO' - Change the Comfort Access trunk opening delay time.
  • Added Code: 'CLM_SMO_INDICATOR' - Turn off taillight flashing when opening trunk via Comfort Access.
  • Added Codes: Enable LIM Function. (It will change Cruise Control's 'SET' button on the steering wheel to act as the 'LIM' button)
  • Added Codes: Show Active Cruise Control iBrake Distance in HUD.
  • Verified Code: ENT_MC_VIDEO_SUPPORT -> Moved to 'Video In Motion & Playback Features' (Does not save videos to internal HD)
v1.5 (10/18/2014 5:00PM PST):
  • Added Section: 'Seat Heating Temperature Levels'
  • Added Code: (REM) 'FH_TUERAUF_STOP_MAUT' - Allows the rear windows to be rolled up while the door is opened.
  • Added Code: 'NSW_EIN_AUF_LDS_STL' - Allows Fog Lights to turn on while only parking lights are on.
  • Changed Code: 'OFF_MEMORY' -> 'MEMORY_OFF'
  • Changed Code: 'LCMKOD_B_SPORTLENKUNG' -> 'ICMKOD_B_SPORTLENKUNG'
  • Fixed: 'C_CLC_ENA' - Value and Default Value.
  • Fixed: 'JUNCTION_VIEW_HUD' - Now working. (Sometimes images/writing are messed up though.)
  • Fixed: Description in 'FRA_H_R_IS_LED/FRA_H_L_IS_LED' - May cause check engine light.
  • Fixed: Description in 'Variable Light Distribution' - No need to code FLA/KAFAS2.
  • Fixed: Description in 'General Locking/Window Features & Convenience Features' section. (Explained how some cars with MEMORY_OFF enabled may always have the A/C defaulted to Off at each startup.)
v1.4 (9/03/2014 1:45PM PST):
  • Added Section: 'INEFFECTIVE OR UNAVAILABLE CODES'
  • Added Code: 'VOL_MAX_ON' - Retain volume setting up to 100% at vehicle startup
  • Added Code: 'MEMORY_UMLUFT' - Remember Air Re-Circulation Setting from previous shutdown.
  • Changed Description: BMW Logo - '(Not working on updated cars.)'
  • Fixed: Launch Control code - Added both Function Names to Code
  • Fixed: Description in 'General Locking/Window Features & Convenience Features' section. (Explained how ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN and ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN are dependent on each other.
  • Moved to Testing Codes: NAVI_AUTOZOOM - Users appear to find this unable to be selected.
  • Moved to Testing Codes: HINTERGRUND_FARBE_NACHT & HINTERGRUND_FARBE_TAG - Users unable to find these codes.
  • Moved to Unavailable Codes: FLA_AUTO_AKTIV
  • Moved to Unavailable Codes: HUD_TLC_ENABLE
  • Moved to Ineffective Codes: HVAC_POPUP codes
  • Moved to Ineffective Codes: ASD_CONFIGURATION
  • Moved to Ineffective Codes: BC_MOTORTEMP_ENABLE
  • Verified Code: ROAD_EDGE_WARNING_ENABLED -> Moved to 'Safety Features & Precautions'
v1.3 (8/17/2014 2:45PM PST):
  • Added Code: Another line of code for Auto Headlamp Sensitivity
  • Added Code: Disable Active Sound Design
  • Added Code: Changes Navigation Voice from English to British English
  • Added Code: Remove Speed Require to Watch videos on HU_NBT
  • Added Code: Removes speed requirement to read service messages on HU_NBT
  • Added Code: Removes speed requirement to read office messages on HU_NBT
  • Added Test Codes: Active Sound Design Configuration Menu
  • Added Test Codes: Enable Speech Input for E-Mail reply or SMS reply
  • Added Test Codes: Enable Time-Stamp Display for Call Logs
v1.2 (8/17/2014 1:20PM PST):
  • Added Section: 'Heads-Up Display'
  • Added Section: 'TO BE TESTED'
  • Added Code: Threshold Speed for Activating Emergency Brake Light
  • Added Code: Reverse Gear Gong Chime Code
  • Added Code: Maximum speed the mirrors are allowed to fold
  • Added Code: Time before it auto-locks the car when no doors have been opened
  • Added Code: Number of turn signal flashes when unlocking/locking.
  • Added Code: Ringtone Type (All BMW ringtones)
  • Added 4 more codes for Headlamp washers
  • Separated Active High Beam Assistant and Variable Light Distribution in FA Codes
  • Added Test Codes: Delays between opening/closing Front, Rear, and Sunroof Windows during Comfort Opening/Closing
  • Added Test Codes: Auto High Beam Automatically On as Default (Pretty sure it won't work on F30.)
  • Added Test Codes: Toggle PDC between vertical and horizontal
  • Added Test Codes: Codes to show Climate Control on iDrive Display
  • Added Test Codes: Make Lane Departure recognize grass/curbs and light up lanes only when detected.
  • Added Test Codes: Change Steering Wheel Vibration Intensity
  • Added Test Codes: Show Engine Temperature
  • Added Test Codes: Show Lane Change and ACC Distance in Heads Up Display
v1.1 (8/6/2014 8:00PM PST):
  • Removed a duplicated Lighting Section.
  • Added LED Turn Signal Coding
  • Fixed Table of Contents and Links
Original Post:
So a while ago, I decided to make my own cheat sheet. I have kept it to myself for a while but then I shared it with a few people on the BMW forums and got really good feedback and suggestions to share it with everyone.
This is basically a compilation of all the codes I could find on forums, external sites, PMs, and other cheat sheet. I wanted to make it because I was sick of how tiny the writing was on spreadsheets and how lose and all over the place codes were. So I made it how I thought it would look the best! (In my opinion of course.) I revised it to make it coherent with everyone. So download it below
If people here end up liking it, I can continue updating it and posting it to the forums with a change log. I want to continue to add codes or missing information, so feel free to notify me if I'm missing anything.
Anyways, check it out and lemme know what you guys think!
Here's a screenshot of the Table of Contents for reference... They are clickable links in the PDF.
2014 BMW 335i xDrive Alpine White ---- M-Sport/Premium/Cold Weather/Technology/HK/Driver Assist+/Active High Beam/8AT Sport
2010 Audi A6 3.0T [Sold]
2011 Ford Mustang 3.7L V6 [Sold]
2003 BMW e46 325i [Sold]
Appreciate 26
      08-06-2014, 08:33 PM   #2
fea30boy
fea30boy's Avatar
Drives: F30 320i
Very Good! Thanks for sharing!
      08-06-2014, 08:38 PM   #3
pikcachu
pikcachu's Avatar
832
Drives: M235i (F22 Red angel)
nice
      08-06-2014, 09:44 PM   #4
jon102034050
Thanks! Great work!
ozuna5.50
      08-06-2014, 10:00 PM   #5
Rxpert
Rxpert's Avatar
Drives: 435i xDrive 6spd EBII
Wow, thanks so much for this! Definitely a must have quick reference.
I had a quick scan through it, but couldn't see anything for coding LED lightbulbs in the break lights and rear turn signals. I know this info is in another thread I just can't seem to find it at the moment either.
Perhaps an addition to future versions of the cheat sheet???
      08-06-2014, 10:19 PM   #6
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
Nice !
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE
2010 X5 35d Black fully loaded (Sold)
2012 X1 28i Black (Sold - not missed)
2007 335i sedan Antracite (Sold and missed !)
      08-06-2014, 10:23 PM   #7
Halsifer
Halsifer's Avatar
Updated! Also, brake lights in the F30 are already LED bulbs.
      08-07-2014, 10:29 AM   #8
carzaddict
Drives: M-Sport 328i X-drive
nice writeup!
make sure to include any new codes into the BMW database app for the people that use it
2011 Jaguar XFR
2013 VW Beetle
      08-07-2014, 04:36 PM   #9
junkyjunky
junkyjunky's Avatar
Drives: 2013 328xi Sport Line
Funny I was thinking about doing the same thing, you're awesome. One thought I had in mind was creating some macro so that when you pick what mods you wanted to do you could click this macro and it would sort the mods by CAFD. That would make programming it easier.
Again, this is fantastic!!!!
I vote sticky for this thread.
      08-07-2014, 10:35 PM   #10
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: '14 435i FBO ACF S2
Well done Halsifer!
      08-09-2014, 05:37 PM   #11
F31Bimmerman
Drives: MY2014 328d xDrive touring
Thanks!!
      08-10-2014, 08:46 PM   #12
BMW_F30
Drives: F30 2013
Great job. Thank you.
      08-17-2014, 12:56 PM   #13
Jera_Jakerz
Jera_Jakerz's Avatar
Drives: 2014 BMW 335i xDrive
Originally Posted by Halsifer View Post
EDIT:
Updated to v1.1:
Original Post:
First off- AWESOME it was nice to see something more up-to-date and from a 2014 owner.
Your guide helped me with the two most important codes I wanted (seatbelt gong) and start-up disclaimer. With just those two, I would be a satisified customer for the Token/Pin and cable purchases.
I also noticed:
FEM_BODY 3023 TCM_MSA_DEFAULT_OFF aktiv nicht_aktiv Auto-Start-Stop set to ‘Off’ at every startup
I tried this and not sure if it is what I wanted it to be. Actually I am unsure of what it did if anything at all. I figured each time I went into eco the start-stop part would stay off. However, after testing, it still did the annoying feature where it would go back to 'on' every time I went from any mode to ECO. What am I missing?
      08-17-2014, 01:00 PM   #14
Halsifer
Halsifer's Avatar
I also noticed:
Of course, glad I could help. I'm going to be uploading a new copy with added and fixed things.
Ahh, Eco Pro will always turn on Auto Start-Stop, regardless of what you code. That specific coding feature TCM_MSA_DEFAULT_OFF makes it so the vehicle will always start with the ASS turned off, instead of remembering ASS being on/off.
      08-17-2014, 01:06 PM   #15
Jera_Jakerz
Aww so if I turned my car off with it 'ON' then when I turned my car back on where it automatically returns to "comfort" the ASS will be off from what I had coded?
      08-17-2014, 01:09 PM   #16
Jera_Jakerz
OH OH - Is it possible to code where the modes are displayed for 10 seconds on the screen between switches to not appear?
Basically when I switch from ECO to Comfort to Sport, I don't want my wife to know so she does not get any fair warning.
      08-17-2014, 01:09 PM   #17
Halsifer
Halsifer's Avatar
Correct!
You would need TCM_MSA_MEMORY set to nicht_aktiv.
And TCM_MSA_DEFAULT_OFF set to aktiv.
      08-17-2014, 01:12 PM   #18
Halsifer
Halsifer's Avatar
That doesn't need to be coded. That's in the iDrive settings. Go to Settings -> Control Display -> Driving mode info.
If it's on, it will show on the iDrive screen. If off, it will only show change in your instrument cluster.
      08-17-2014, 01:24 PM   #19
Jera_Jakerz
Looks like I am done coding until I do a read through of your new product...
      08-17-2014, 04:23 PM   #20
bcornwellatl
Drives: 2013 F30 328i
Oh this is too funny. My wife does the same thing. Gives me that look and says "really, you have to be in "sport mode" to go our of the neighborhood?"
Yeah I disabled my pop up.
      08-17-2014, 04:27 PM   #21
Halsifer
Halsifer's Avatar
Updated to v1.2 (8/17/2014 1:20PM PST): (Download in the original post as an attachment)
If anyone decides to test out the codes in the 'TO BE TESTED' section, and finds out if it works or not, please let me know!
      08-17-2014, 05:45 PM   #22
Halsifer
Halsifer's Avatar
Updated to v1.3 (8/17/2014 2:45PM PST): (Download in the original post as an attachment)
