BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > HOW TO/DIY: Enable Driving Mode Configuration/Sport Steering w/ Comfort Throttle!
      02-07-2015, 08:30 AM   #23
Terabyte
Austria
Drives: BMW F30 316d
Yes maybe there is a difference.
I have European car
      02-07-2015, 08:32 AM   #24
beppeM3+123d
Drives: bmw m3 dct + 123d e81
Originally Posted by Terabyte
Yes. NBT and macro_fds works with older build date.
Did you try to move the flag?
      02-07-2015, 08:35 AM   #25
smithf80
smithf80's Avatar
Drives: '16 F80 M3 6MT
Send a message via AIM to smithf80
Yeah, I'm assuming you did actually try to change the mode and you can check something other than "Drivetrain and Chassis"
2017 6MT F80 M3 - Mineral Grey over Sakhir - Executive & Lighting Packages, 19" Wheels
      02-07-2015, 08:38 AM   #26
Terabyte
Austria
Yes all 3 modes are working
      02-07-2015, 08:45 AM   #27
Steelers6891
Steelers6891's Avatar
35
Drives: '14 335 MSport
2014 335ix  [0.00]
Wow thats awesome.. I think i'm gonna give coding a try on my f30 soon
2014 F30 335i | JB4 | ER Catless DP | Eisenmann Race | BMS Performance Intake | M-Sport | xDrive | Alpine White | Black Dakota | Harmon Kardon | Cold | Driver Assistance | Premium | Tech | 18" Style 400M | CF Spoiler | Black Kidney Grilles | M Performance Side Sill Decals | 20% Tints |
      02-07-2015, 03:00 PM   #28
beppeM3+123d
@Terabyte can you share your build date, chassis, and what have you coded to make it work? I am european too with f32 3/14. Actually i have the setup possibility screen enabled but i cant move the flag.
      02-07-2015, 03:14 PM   #29
smithf80
smithf80's Avatar
If you do the stuff in the first post it will work.
      02-22-2015, 10:03 PM   #30
Catania830
BMW Client Advisor
Catania830's Avatar
Drives: i8
Hey, did you notice any other changes in NBT or FEM? I was reading in another forum that if you changed to that specific build date in CIC and code KOMBI then the nav on the instrument cluster came up weird and out of proportion. So I'm wondering if i change NBT or FEM that MY14 will act up. I would also be temped to code KOMBI so i can have my time on the bottom right corner
2016 i8 Tera World
2015 F82 M4 475/LKDA[Sold]
2014 F32 435i 300/KCSW [Sold]
2012 F30 328i A96/LCL3 Sport Line[Sold]
      02-22-2015, 10:20 PM   #31
smithf80
smithf80's Avatar
I coded my KOMBI to the same build date in this thread for just that reason, I like the time there.
As far as I know the only module that gets weird if you Vo code it to 2015 is the DSC, it will throw a TPM error.
      02-22-2015, 10:27 PM   #32
Catania830
BMW Client Advisor
Catania830's Avatar
Drives: i8
AH! Defiantly VO coding KOMBI if there isn't any problem with the nav! Thanks!
2016 i8 Tera World
      02-24-2015, 10:47 AM   #33
hsk1610
Drives: 2013 328i xDrive
You can correct for the resolution by going back into Kombi and under one of the settings for NBT_Enabled, set that to Off so the KOMBI will know you have the CIC and not the NBT and works perfectly.
      02-24-2015, 10:52 AM   #34
Catania830
BMW Client Advisor
Catania830's Avatar
Drives: i8
Very good to know, thanks
2016 i8 Tera World
      02-24-2015, 06:14 PM   #35
therealm3
Drives: F30 335 Msport, E70 35i
thank you! this is awesome! can't wait to try it out.
      03-12-2015, 06:22 PM   #36
mane
Finland
Drives: F01 LCI
I would really like to have sport or sport+ modes configured with comfort (light) steering. Heavy steering feels so artificial that I really wonder why I cant adjust that. It does not make any better road feel, just harder to turn the wheel..
Has anyone found any parameters related to steering values/stiffness?
      03-19-2015, 10:42 AM   #37
robg
Drives: bmw 335i
UNless I'm misunderstanding you should be able to achieve this by selecting "drivetrain only" from the configure sport mode screen. that should give you the transmission and throttle response of sport mode with the lighter steering. And of course if you dont care about the sport mode throttle you can simply move the gear lever to the left in comfort mode to get the "sport" transmission shift points.
The one thing that isn't achievable is to have sport throttle only since they bundle throttle and transmission settings together under drivetrain. Personally i'm ok with that since i can't stand the sport throttle setting.
But you should be able to achieve:
-steering only (by sleecting chassis only)
-tranmssion only (using gear lever)
-Steering, trans and throttle (all)
-Steering and trans (chassis only + gear lever to left)
-trans and throttle only (drivetrain)
      03-19-2015, 10:47 AM   #38
robg
Drives: bmw 335i
I am very excited to discover this thread. Does anyone know if this also works on US 2014 F10s? I'd love to have the sport steering wihout the throttle and tranmission settings. My current workaround is put the traction control into DTC mode (which has the side effect of making the steering heavier too). Not the best idea from a safety standpoint and when my wife is in the car she gets upset about it.
And since i"ve never VO coded (only FDL coded before), I have a question: I gather that one of the things VO coding does is to automatically set individual parameters in the ECUs according to the options and build date. Of course, you could in theory do this manually with FDL coding. But is there more to it than that? In other words, if you did a "diff" of the CAFD files before and after changing the build date, and then manually FDL coded the relevant params, would it be the same? Or is changing the build date mandatory to get certain features to work (such as this).
Also, I have FDL coded a few settings in HU_NBT. I assume these will all be wiped and reset to factory defaults after VO coding that ECU?
      03-19-2015, 10:53 AM   #39
carzaddict
Drives: M-Sport 328i X-drive
i did this to my car as soon as I got it, one of the best things ive done to the car.
2011 Jaguar XFR
2013 VW Beetle
      03-19-2015, 11:12 AM   #40
smithf80
smithf80's Avatar
You could figure out the difference, yes, but I have no idea what parameters it changes when you change the build date, which is why I just did the VO coding vs FDL. For all I know the 2015 build date just allows it to work when coded to the FEM_Body? I honestly have no idea but I suppose it wouldn't be hard to compare the original to the 2015 VO coded version.
      03-19-2015, 01:37 PM   #41
mane
Finland
Drives: F01 LCI
Yeah that's true. But there are 4 variables if you have adaptive m-sport suspension. Dampers will stiffen up on sport mode also. So the combo that I'm missing is :
- comfort steering
- sport suspension
- sport or comfort transmission mode
- sport or comfort throttle response mode
I had E90 M3 and in M-Drive settings you were able to tune all of these as you wish. F80 must have that same menu. I guess software is pretty much the same on F80 and F30.. it just could be possible somehow. Maybe even enable M-Drive menu?
      03-19-2015, 03:12 PM   #42
smithf80
smithf80's Avatar
- comfort steering
- sport suspension
You could enable the MDrive menu but I'm 99.99% sure it won't work at all.
      03-19-2015, 03:16 PM   #43
mane
Finland
Drives: F01 LCI
Oh yeah, forgot that you need to have the M-button in steering wheel to use it. That menu is kind of worthless without that
      03-19-2015, 10:58 PM   #44
robg
Drives: bmw 335i
- comfort steering
- sport suspension
Ah very true. It is kind of silly that they don't offer a true individual setting mode on non-M cars. I believe Audi and Mercedes do.
I drove an e90 M3 once and really liked being able to control all 4 parameters separately.
