BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > HOW TO/DIY: Enable Driving Mode Configuration/Sport Steering w/ Comfort Throttle!
European Auto Source
      04-11-2015, 09:18 PM   #67
smithf80
smithf80's Avatar
Drives: '16 F80 M3 6MT
Send a message via AIM to smithf80
Originally Posted by RSnic View Post
Hi,
I have a 2014 F30 (build date 7/13) with manual transmission, "standard" steering, suspension & brakes.
Am wondering if this great "find" will work on my car and if it will enable me to "adjust" steering & suspension?
BTW, have the cited functions in both ICM & HU_NBT
Appreciate your thoughts -- if it does, will definitely code this in.
Thank you very much
The main benefit for you will be the ability to have comfort throttle with sport steering if you'd like.
2017 6MT F80 M3 - Mineral Grey over Sakhir - Executive & Lighting Packages, 19" Wheels
      04-13-2015, 03:33 PM   #68
RSnic
RSnic's Avatar
Drives: 2014 328i
Hi,
Coded both ICM (with ICMKOD_B_SPORTINDIVIDUALISIER) and HU_NBT (with MACRO_FDS) and I now have extra menu item that allows setting Sport mode as: Drive Train & Chassis; Drive Train; Chassis.
Thanks
Al
2014 328i | Technology | Premium | Cold Weather | Harmon Kardon Audio | Manual|
Mods: Trunk spoiler| Rear & Side cameras| Both PDCs|
      04-14-2015, 09:44 AM   #69
beppeM3+123d
Drives: bmw m3 dct + 123d e81
Tahnks Rsnic. finally is no more necessary move the vo build date and flash modules!!! Thank you so much, considering that the last version 55.x have cafd trimmed...
      04-14-2015, 11:04 AM   #70
RSnic
RSnic's Avatar
Drives: 2014 328i
BeppeM3+123d,
Really appreciate SmithF32 for laying this out. Yup, it works quite well and allows me to "mix & match" comfort & sport settings with:
  • Chassis setting which gives me tighter Sport Steering & Comfort accelerator
  • DriveTrain setting which gives me responsive Sport accelerator & Comfort steering
By the way, I have manual transmission, so Sport mode settings are not affected by this Configure Sport Mode menu
Al
      04-23-2015, 10:54 AM   #71
beppeM3+123d
mmm a friend of mine have an f31 with hu entry no sport trans, no sport susp, no sport variable steering but was activated from factory!!! so probably is strange, because almost the steering must keep the sport setup separated from engine....
      04-23-2015, 12:28 PM   #72
smithf80
smithf80's Avatar
2015's have it as standard now I believe.
      05-21-2015, 04:59 PM   #73
robg
Drives: bmw 335i
Yeah 2015s have it standard. And its still relevant even in a base car because the modes still can control:
-Transmission mode (sport or regular)....Which even the base (non sport auto) trans has
-Throttle response
-Steering effort (even the non sport variable steering has the ability to change the asssist level). FYI- the "variable" the variable sport steering actually refers to the way the rack is designed. They cut the teeth such that the ratio changes the more you lock you apply. Basically it means that you dont need to turn the wheel as much to get the same amount of wheel angle as you would on a standard car. Nothing to do with the amount of steering asssist however.
      05-25-2015, 01:16 AM   #74
pikcachu
pikcachu's Avatar
575
Drives: M235i (F22 Red angel)
Originally Posted by smithf32 View Post
That's awesome!! I knew it had to be something, I just really didn't have the time to get out there and figure it out with work and all.
Glad you were able to find the FDL code that the FA coding was doing.
I'm shocked I didn't see that in there and try it, I've been thru all of the modules several times lol.
would be nice if you could update the 1st post to show what's required if you are doing FDL route
      05-25-2015, 06:44 AM   #75
RSnic
RSnic's Avatar
Drives: 2014 328i
PikCachU,
Please check my post above as I did not do any VO coding, just FDL.
This feature is great!
      05-25-2015, 11:29 AM   #76
pikcachu
pikcachu's Avatar
575
PikCachU,
I did.... what I'm saying it would be nice to add it to the first post for others looking, so they don't have to read 4 pages of posts
      05-25-2015, 11:43 AM   #77
smithf80
smithf80's Avatar
Ok.
Done
      05-25-2015, 12:13 PM   #78
pikcachu
pikcachu's Avatar
575
Ok.
Done
      06-05-2015, 08:27 AM   #79
aacabriolet
aacabriolet's Avatar
Drives: '14 435i Coupe
Thanks so much for this! Just got it working by
Icmkod_b_sportsindividualisierbar to ein (werte 01).
And MACRO_FDS in HU_NBT to "popup_and_configure"
      10-05-2015, 12:32 PM   #80
CarlosC
Drives: 2012 BMW 328i
Originally Posted by robg View Post
No - for cic you only need to code the macro_fds parameter on hu_cic. No need for these shenanigans
Tried this on my car (2012/CIC) this past weekend, just modified the MACRO_FDS parameter and it does now show the additional chassis/drivetrain settings in SPORT and ECO mode but NOT in COMFORT mode. Is there something else I need to modify to get this working for COMFORT mode?
      10-05-2015, 12:37 PM   #81
smithf80
smithf80's Avatar
There are no other options for Comfort mode.
      10-05-2015, 12:45 PM   #82
CarlosC
So what I was after was COMFORT mode with the SPORT steering feel. Does this mean I can go into the SPORT setting, modify the drivetrain and chassis options to essentially achieve this?
      10-05-2015, 01:22 PM   #83
smithf80
smithf80's Avatar
Correct. You customize Sport mode to be Chassis only.
Obviously if you have EDC then you will have sport suspension in comfort mode, but if you don't then its perfect, sport steering with everything else comfort.
      10-05-2015, 01:25 PM   #84
RSnic
RSnic's Avatar
Drives: 2014 328i
CarlosC,
Take a look at my April 14 post above. In essence, that is what I have with this coding
      01-20-2017, 01:54 PM   #85
robert4u
Drives: BMW F31
Thx for all the info.
Today I tried this on my F31, with build date 08-2013.
First I coded "Makro_FDS" to "popup and configure" and I was able to select/change the settings, however this didn't change the feel of the car.
Then I coded "Icmkod_b_sportsindividualisierbar" to "ein" and then I could feel the differences when changing the settings.
      01-20-2017, 04:45 PM   #86
RSnic
RSnic's Avatar
Drives: 2014 328i
Robert4U,
Am glad you figured this out. As discussed earlier, it works quite well and allows me to "mix & match" comfort & sport settings with:
There's a bunch of great stuff on cheat sheets that are posted elsewhere -- makes this a lot of fun!
All the Best
Al
      02-25-2017, 02:32 PM   #87
wilbur_the_goose
Drives: 2014 F30 Sport Line Sedan
You know what's strange about this? The in-car electronic owner's manual describes how to do this, but the actual "Settings/Driving Mode" choice is missing.
Sounds like somebody on BMW's software team introduced a nasty defect.
      02-26-2017, 10:59 AM   #88
tomsab0
Drives: 320xd GT
Did anybody read the fault memory after doing the FDL coding? It Produces an error Code in ICM...
