BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [TUTORIAL]Retrofit rear lights BMW F30/F31/F80 LCI
Extreme Power House
      05-05-2016, 10:54 AM   #23
david51
david51's Avatar
France
252
Drives: bmw M235i bleu estoril
Originally Posted by cailas View Post
What for these things are needed?
Cache left gutter (51497410819)
Cache right channel (51497410820)
yes because the shape of the taillights is different
      05-05-2016, 10:55 AM   #24
david51
david51's Avatar
France
252
Originally Posted by kemiksiz View Post
Perfect post, thanks a lot in the name of the lci modders
thank you
      05-16-2016, 10:09 AM   #25
BMW_1900
Drives: BMW 320d M Sport F30
Hi, great job David!
I have purchased a set of used LCI rear taillights. Would this method work for UK? I have RHD and need to know if the coding and wiring will work in the UK. I need to ensure the fog light is also enabled. Help please!
      05-16-2016, 11:24 AM   #26
david51
david51's Avatar
France
252
normally you can follow the same procedure
      05-16-2016, 06:39 PM   #27
BMW_1900
Thanks David I have will try my best
I can't understand what these are used for from the instructions:
2x connector for indoor lights (61138364834)
Any clarity?
      05-18-2016, 12:09 PM   #28
david51
david51's Avatar
France
252
2 connectors (61138364834) are used to connect as these pictures attached.
this will allow to turn the left and right turn signals
      05-19-2016, 11:30 AM   #29
BMW_1900
Ah I see thanks David. I have purchased the connectors and plugs and have lights installed in the car.
Next week I shall try your method and report back to you.
The two wires which go into the new connectors, where do I source them two wires from? Existing black inner plugs?
      05-19-2016, 06:48 PM   #30
BMW_1900
Can I also check the purple/grey and the blue/red wire were provided by yourself and ran into the REM module next to the battery?
      05-21-2016, 05:13 AM   #31
david51
david51's Avatar
France
252
Yes that's right
      06-22-2016, 10:58 AM   #32
david51
david51's Avatar
France
252
here is a picture
      09-11-2016, 03:32 PM   #33
Wunsch
Wunsch's Avatar
Drives: 2017 330i Touring
I assume that these part numbers for the LCI outer taillights are for the US/Canadian versions with red turn signals. Does anybody have the part numbers for the RoW versions with orange turn signals, especially for the F31?
      09-11-2016, 04:31 PM   #34
Gabreigns
Gabreigns's Avatar
376
Drives: F3x
The Part Numbers you are looking for are 7372209 7372210 7369119 7369120. These are euro amber LCI and fit the F31.
      09-11-2016, 08:53 PM   #35
david51
david51's Avatar
France
252
the references are for Europe
      09-18-2016, 06:20 PM   #36
jbeer
jbeer's Avatar
Drives: BMW 320i M Sport
Hi David, I hope you can help me?
I stupidly decided to be over curious today and starting looking at how the rear lights could be changed and a stupidly started to remove one of the rear tailgate lights, it lifted slightly and as it wasn't moving tried to put it back.... I got the part nearest the centre of the tailgate to sit flush but the edge nearest the side of the boot lid is slightly proudness as if it's not sitting flush, it is only slight but I know it's there.
How easy is it to remove and refit the lights? Is anything likely to snap etc...
Current: F30 320i M Sport Saloon with 403M Alloys
Accessories: BMW OEM Roof Bars & Bike Carriers, Dashcam - Blackvue 450S
      09-19-2016, 08:52 PM   #37
david51
david51's Avatar
France
252
Hello
do you have a picture ?
      09-28-2016, 03:45 AM   #38
jbeer
jbeer's Avatar
Hello
David sorry for the delay with the picture...the top pic shows the light slightly protruding and the bottom pic is the other side which is more flush.
As I mentioned before it's not massively out but it is out of alignment
      09-28-2016, 11:09 PM   #39
david51
david51's Avatar
France
252
Hello
the small plate that allows to engage the rear lights on the part of the trunk must be bend which prevents you to secure the rear lights.
see photo with arrow
      09-29-2016, 01:37 AM   #40
jbeer
jbeer's Avatar
Great thanks, I might leave it as it is as it's not leaking and is only a fraction out. Thanks again
      09-29-2016, 07:31 AM   #41
david51
david51's Avatar
France
252
OK but beware that it does not come off
      09-29-2016, 07:33 AM   #42
jbeer
jbeer's Avatar
Will do
      09-29-2016, 02:10 PM   #43
david51
david51's Avatar
France
252
Will do
      10-07-2016, 02:39 PM   #44
rfcoolz
Drives: 2014 F30 328i xDrive
Pictures are gone
