BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Replacing steering column switch cluster on F3x...
      03-16-2016, 07:40 AM   #1
gevoooon
Hi there,
I am planning to replace my faulty steering column switch cluster (SZL) on my F30.
I have read a lot of info from forums and websites which that the new SZL unit has to be reprogrammed and steering angle sensor recalibrated, but all those pages are talking about E9x not F3x.
Is it the same for F3x? I don't think VIN is specifically injected to SZL for F3x. So what sort of programming is required? Is it only recalibrating the steering angle sensor which I guess can be done with Tool32?
Thanks a lot.
Gev
      03-16-2016, 11:47 AM   #2
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi ACF Custom Build
Originally Posted by gevoooon
Hi there,
Thanks a lot.
Gev
Tool32 is outdated and dangerous. Get yourself a working copy of ISTA which will give you all the BMW workshop guides along with all diagnostic procedures and even coding and programming.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      06-18-2016, 07:28 PM   #3
Tritan84
Drives: 2011 535i
I'm in a similar situation with my F10. I have a working version on ISTA/D. I'm not sure how to use it. I'll be replacing my SZL. Can you provide a how to on reprogramming a used SZL to the vehicle?
      06-19-2016, 11:19 PM   #4
roxxor
roxxor's Avatar
97
Drives: 2013 328i M-Sport
I replaced the SZL on my F30 when retrofitting some options, no reprogramming/calibration was required for it, and I have had 0 problems with it.
      06-21-2016, 04:07 PM   #5
cryptocar
cryptocar's Avatar
I've never had to do this before, but with a fully functioning version of ISTA/D with coding enabled and the latest full psdzdata you should be able to simply use this page in ISTA,
it's built for the lame excuse for "technicians" most dealers employ, and should be simple enough to figure out using basic common sense.
Also as roxxor stated programming may not even be needed.
Good luck!
      09-10-2017, 10:24 AM   #6
Tritan84
Drives: 2011 535i
Bumping thread.
I have a working version is ISTA and I can get to that page, but I get the same message even after performing the vehicle test. Any suggestions?
Also, how do I make sure I have the most current version of pszdata working with ISTA?
