BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding: Rear Light Bars Remapped For Turn Signals - Still Enabled for Tails
      05-28-2016, 10:47 PM   #1
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2015 BMW 328i xDrive M-Sport
The thread about the Eyebrows remapped for turn signals over here - http://f30.bimmerpost.com/forums/sho....php?t=1264291 got me thinking...
Is it possible to remap an addition function for the Rear Light Bars to function as turn signals without removing the taillight function?
The answer...
YES!
Simply remap the following:
MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l
MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r
MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07
MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l
MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r
MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07
So in order for the light bars to be repurposed as turn signals (still function as taillights at night) - we're remapping the supposed DRL functions for the taillights to be used as turn signals instead.
Codemybimmer
USA Toll Free: +1(866)480-8094 | Vancouver, CA: +1(778)779-5708 (SMS and VM) | Toronto and Rest of Canada: +1(416)833-4921 (9:00am - 7:00pm EST) info@codemybimmer.ca;.;www.codemybimmer.ca
Competitive pricing on Enhanced Bluetooth, Sirius XM, Backup Cameras as well as NBT and NBT EVO Retrofits
      05-29-2016, 04:36 AM   #2
Gabreigns
Gabreigns's Avatar
264
Drives: F3x
This is a good find! Thanks for sharing!
Edit: worked like a charm!
The codes you mentioned are under REM. I was mistakenly looking for them under FEM_BODY.
      05-29-2016, 11:43 PM   #3
Gabreigns
Gabreigns's Avatar
264
Drives: F3x
I just noticed that when I have my left indicator turned on, there is a click coming from the back right of the car.
I don't have any such indicator clicking noise from the back right or left other than the regular indicator clicking when I have the right indicator turned on.
Any ideas what that could be?
      05-30-2016, 12:12 AM   #4
jgoens
jgoens's Avatar
2442
Drives: 2013 335i msport
Interesting...might have to try this.
2013 335i Msport Black sapphire/Coral red. JB4. VRSF DP, ER CP Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      05-31-2016, 05:38 AM   #5
rustyminded
rustyminded's Avatar
116
Drives: BMW 328i
I did it and it's amazing but downside only works with lights off not at night with lights on
      05-31-2016, 09:18 AM   #6
Tim@codemybimmer
It works with my lights on when the headlight switch is on Automatic.
Codemybimmer
      05-31-2016, 09:24 AM   #7
Montaxx
Montaxx's Avatar
Drives: F30 328i
Could some1 provide videos how it looks at day and night?
      05-31-2016, 09:52 AM   #8
rustyminded
116
Drives: BMW 328i
I don't have the automatic but i did adjust the key to make fog as corners, can you check what extra codes needed or maybe i need light sensor ?
      05-31-2016, 10:01 AM   #9
rustyminded
116
Drives: BMW 328i
https://youtu.be/Hj15HXX7UTE
      06-04-2016, 10:55 AM   #10
hsk1610
Drives: 2013 328i xDrive
code to turn off the blinker and just use the leds
I coded the led light bar to link with the turn signals but looks a little tacky with all 3 lights going off. Is there a way to turn off the regular turn signal so I can just use the lower led light bars as turn signals?
      06-04-2016, 08:30 PM   #11
Tim@codemybimmer
I'll look at it when I have time. But really you just have to turn off the mapping of the turn signals to the regular bulb.
Codemybimmer
      06-05-2016, 07:25 AM   #12
hsk1610
Thanks. Looking forward to what you find out.
      06-09-2016, 05:12 PM   #13
Gabreigns
Gabreigns's Avatar
264
Drives: F3x
Do you remember what the original values were/are? I would like to go back to the original values.
      06-12-2016, 11:17 PM   #14
hsk1610
all the original werte values were 04.
      06-13-2016, 11:15 PM   #15
Tim@codemybimmer
In addition to werte 04 for DRL function, the output was off, since the rear DRL is not activated from the factory.
Codemybimmer
      01-21-2017, 05:10 PM   #16
kadify
Drives: 428i xDrive GC
I'm getting an issue where the outer left bar blinks while the inner bars (closer to the middle of the trunk) in the left side don't blink when the car lights turn on. Otherwise when the headlights are off the function as expected. I've gone through and coded everything correctly so not sure what gives?
      01-23-2017, 04:25 PM   #17
Ibo24
New BMW owner
Ibo24's Avatar
Turkey
Drives: BMW 320d
Anyone got a proper video when working in day, link is down.
      02-03-2017, 09:34 PM   #18
hsk1610
What values need to be modified to turn off the actual turn signal bulbs and use the lower bar leds as activated here?
      05-10-2017, 03:18 AM   #19
enes28
Turkey
Drives: Polo TSI
Yess, how can we disable rear turn signal and use only the leds ?
      05-10-2017, 09:30 AM   #20
Mwahab
The Garage
Mwahab's Avatar
Egypt
22
Drives: F30
2015 BMW F30  [0.00]
Yes here is mine
https://www.facebook.com/TheGarageEg...5287706544286/
It can be coded, and we can disable the yellow signals too.
Just disable blinken values
The Garage -
Egypt
Offers some decent mods for the F series
      05-10-2017, 11:15 AM   #21
enes28
Turkey
Drives: Polo TSI
Originally Posted by Mwahab View Post
Yes here is mine
Can you write me which blinken values change ? I worked but didnt find anything
      05-10-2017, 11:25 AM   #22
enes28
Turkey
Drives: Polo TSI
ı change werte values or others ?
