BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding: Rear Light Bars Remapped For Turn Signals - Still Enabled for Tails
Vorsteiner
      05-10-2017, 11:29 AM   #23
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
Go to REM -- search for Blinken mappings, you have two options change the function to 00 or change the PWM LEVEL 1 to 00 . or both it doesnt matter
apply this for left and right
      05-10-2017, 11:52 AM   #24
enes28
Turkey
Drives: Polo TSI
Thankss for ur reply
      05-12-2017, 01:08 PM   #25
Ibo24
New BMW owner
Ibo24's Avatar
Turkey
22
Drives: BMW 320d
Yes here is mine
https://www.facebook.com/TheGarageEg...5287706544286/
It can be coded, and we can disable the yellow signals too.
Just disable blinken values
Nice video man!
But how did you do the belly dance ? (Or however it was called )
Mwahab35.00
      05-12-2017, 03:39 PM   #26
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
Yes here is mine
Nice video man!
Hahaha yes the belly dance:
You can trigger the warm and cold checks, its pretty cool.
plus i just found a way to control the intervals between the pulses, but never tried it yet
      05-12-2017, 06:40 PM   #27
cross90
cross90's Avatar
Drives: F31, 330d M-Sport
Interesting mod!
@Mwahab Could you share how to change the intervals between pulses ? Thanks
      05-13-2017, 05:17 AM   #28
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
Post Belly dancing!
Originally Posted by cross90 View Post
Interesting mod!
I will be glad if somebody had time for testing and showed the outcome.
Well, we will hang out in FEM -- 3064 LceConfiguration -- we have 6 paramters there to play with (NOTE: Its a theoretical description, its not yet confirmed)
1- PRE_DRV_CHECK_PULSE_DELAY
It controls the pulse interval in the same round when starting the ignition
2- RRE_DRV_CHECK_ROUND_DELAY
Its the interval between the rounds of pulses,not sure of that 1 HEX = 10 ms
3 PRE_DRV_CHECK_ROUND_COUNT ***
I think that this is the one, i believe it controls the rounds, try and code it to 64HEX
4- KALT_CHECK_PULSE_DELAY
Interval between Cold checks pulses on same round
5- KALT_CHECK_ROUND_DELAY
Interval between 2 successive pulses for cold checks
Test and tell me guys!!
EDIT:
The same parameters are located in REM, just it will be according to what mapping you are going to make it dance
      05-19-2017, 03:21 PM   #29
enes28
Turkey
Drives: Polo TSI
how can we use only led bars as turn signals without actual rear turn signals ?
when ı disable the rear turn signals , continue to blink rear turn signals but didnt blink led barss.
what is the problem
      05-29-2017, 01:33 PM   #30
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Just coded this and disabled the power values as instructed above. Works like a charm, thanks much! LED's now function as blinkers and work as taillights as well.
      05-30-2017, 08:49 PM   #31
hsk1610
Drives: 2013 328i xDrive
which BLIKEN data sets did you modify to just get the LED bars to blink instead of the actual turn signal lights? Just tried to code it but there were too many mapping rear turn signals to disable the actual turning signal bulbs.
      05-30-2017, 10:26 PM   #32
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Since i've gotten several PMs, i figure'd i'd upload a picture of the values that were edited. After modification of the values from the OP on Post 1 (thank you!) and following Mwahab's instructions (also thank you!), I got everything to work. In the attached picture, the orange arrows point to the werte values that should be changed to 00 as Mwahab instructed. I took this picture before in order to make sure i recorded the default values, it was from my phone, so apologies on that. Both values are found under REM.
Mwahab, i tried the original function value to 00, it did not work for me and there was a code thrown in the system that REM values were incorrect. Also it defaulted some values and negated the OP's codes. After i changed it back to default, it was fine. I tried the power values and have successfully done it.
EDIT: Ran outside real quick and took a video to show proof.
hsk161060.50
Mwahab35.00
      05-31-2017, 09:20 AM   #33
hsk1610
Now rear turn signals converted to rear fogs?
Thanks for the info on the rear leds.
Since I have the rear fogs activated, any of the experts here know how I can repurpose the actual rear turn signals as the rear fogs? I assume since the rear turn signals power or Werte values were changed from 89 to 00, something else must be changed to have the actual turn signals light up when activated as the fogs as well as the correct routing to get that activated by the fog light switch. Thanks in advance.
      05-31-2017, 11:35 AM   #34
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
So in short, you need to map the resr fog lights as turn signals? confirm and i will send u the parameters
i already done it.
and check my page for more lighting mods, there are alot
facebook.com/TheGarageEgy
      05-31-2017, 11:38 AM   #35
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
EDIT: Ran outside real quick and took a video to show proof. https://youtu.be/3MAxzkBKQFw
Yes that's right, disabling the rear turn signals is somewhat tricky, some models needs other stuff than just modifying the PWM.
I am happy you made it
      05-31-2017, 11:57 AM   #36
hsk1610
i already done it.
I am trying to use the rear turn signals as fogs since this mod lets me use the rear leds (which currently are set as the rear fogs) as the turn signals.
      05-31-2017, 12:00 PM   #37
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
i already done it.
You complicated the idea even more
I think you mean, you want to code the yellow turn signals to work as rear fog right?
i will pm you in minutes
      05-31-2017, 03:49 PM   #38
hsk1610
That is correct. Thanks for the PM. Just wondering though, if I set the PWM to 00 to turn off the yellow turn signals, would your instructions still allow the yellow turn signal to be activated as rear fogs? (It's red, btw, in the US- clear bulbs.)
      05-31-2017, 04:39 PM   #39
enes28
Turkey
Drives: Polo TSI
hello I read thread several times, but I didnt understand as exactly. Which parameters we change them for only led bars blinking not rear turn signals ?
If u share, I am happy
      05-31-2017, 04:46 PM   #40
hsk1610
See the first post on this thread to activate the rear leds, then look at Post #32 to turn off the actual turning signal bulbs.
      05-31-2017, 04:52 PM   #41
enes28
Turkey
Drives: Polo TSI
MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l
MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r
MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07
MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l
MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r
MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07
first code fdl that and blinker hl and hr pwm level 00 and code fdl ?
But first when I try to disable actual turn signal (pwm level 00), I can't. Still working turn signals. Where is the problem ?
      05-31-2017, 05:07 PM   #42
hsk1610
I haven't tested out so just going by what was posted. Are you sure you are changing the Werte values?
      05-31-2017, 05:12 PM   #43
enes28
Turkey
Drives: Polo TSI
yes I am sure but not changing, still working
      05-31-2017, 05:19 PM   #44
hsk1610
You might have to actually change the BLINKEN values then, but not quite clear where that is located in the REM tree.
