BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding: Rear Light Bars Remapped For Turn Signals - Still Enabled for Tails
      05-31-2017, 05:25 PM   #45
enes28
Turkey
Drives: Polo TSI
Originally Posted by hsk1610 View Post
You might have to actually change the BLINKEN values then, but not quite clear where that is located in the REM tree.
Maybe , it can be priorities ?
Anyone knows that ?
      06-01-2017, 06:15 AM   #46
enes28
Turkey
Drives: Polo TSI
the bad one is that; I have not bmw and I cant try the codes when I wanna that
      06-18-2017, 06:33 AM   #47
beppeM3+123d
Drives: bmw m3 dct + 123d e81
Thank you guys very nice feature! One question I have coded mine f31 lci led tail light and the turn signal work but with daydriving they are off only angel eyes are on! What I do wrong??
      06-18-2017, 03:30 PM   #48
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
My guess is that you have to chose between drl or turn signals. From what I understand d you are coding the lights to be as DRLs but tricking the mapping to only push power to it when turn signal is activated. I might be mistaken though
      06-18-2017, 11:12 PM   #49
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
If you could rephrase your request, i may help you then.
      06-19-2017, 08:48 AM   #50
beppeM3+123d
Sorry
I I would like to make with coding of tail light the following 2 features:
- always on with day running light
- flashing with turn signal
The second work properly the first no, but your coding write up should include both! On my brother f32 pre lci work on my f30 lci with full led work only flashing with turn signal!!
What I do wrong??
      06-19-2017, 01:54 PM   #51
Mwahab
Egypt
35
Drives: F30
2015 BMW F30  [0.00]
Sorry
What I do wrong??
Ok this is logic,but i can override it, and code the 2 things you need.
If possible, you can hook me up over team viewer, will sort it out for you.
PM me with ur details
      09-03-2017, 10:45 PM   #52
F30Beast335i
F30Beast335i's Avatar
51
Drives: 2013 f30 n55 335i
Yes here is mine
https://www.facebook.com/TheGarageEg...5287706544286/
It can be coded, and we can disable the yellow signals too.
Just disable blinken values
I have coded the above from OP but only is active in DRL mode , not when switch is on automatic . Any help would be greatly appreciated .
      09-03-2017, 10:53 PM   #53
F30Beast335i
51
Originally Posted by Timbits93 View Post
The thread about the Eyebrows remapped for turn signals over here - http://f30.bimmerpost.com/forums/sho....php?t=1264291 got me thinking...
Is it possible to remap an addition function for the Rear Light Bars to function as turn signals without removing the taillight function?
The answer...
YES!
Simply remap the following:
MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l
MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r
MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07
MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l
MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06
MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r
MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07
So in order for the light bars to be repurposed as turn signals (still function as taillights at night) - we're remapping the supposed DRL functions for the taillights to be used as turn signals instead.
What did you do to maintain these to blink with headlights switch in the auto position mine seems to only work with DRL . Tho when I first codednit it worked on auto but now seems not too.
      09-12-2017, 11:51 PM   #54
RazF30
Drives: F30
i tried these codes but none of them working, i disconnect and connect back to the car and ensure that all the value are changed, but it doesnt work, anyone know why? many thanks!!
      09-18-2017, 01:17 AM   #55
SalpacinoBMW
SalpacinoBMW's Avatar
Drives: 2012 335i Sedan
It works with my lights on when the headlight switch is on Automatic.
how did you make it work on automatic? I coded everthing on first post and #32 but will only work when lights are off. When i switch to automatic the blinker wont even work now (i know why) but would like to to work the same when on automatic if lights DRL or at night.
      09-18-2017, 01:29 AM   #56
SalpacinoBMW
I have coded the below and works perfect when lights are off and DRL are on. Once i switch it to Automatic it does not work and turn signals dont turn on now (thats because i turned them off to only allow bar to blink). Can anyone give me any ideas of how to get them to work when switch to automatic would be great. thanks
MAPPING_BLINKER_H_L_PWM_LEVEL_1 > werte 00
MAPPING_BLINKER_H_R_PWM_LEVEL_1 > werte 00
      09-19-2017, 09:31 PM   #57
daMANiack
daMANiack's Avatar
Australia
Drives: BMW F26 X4 35d
Hi,
Is this Rear Light Bars remapping possible with 2016 X1 F48 and X4 F26?
Are there any negatives?
Cheerz
      09-20-2017, 01:12 AM   #58
SalpacinoBMW
So with some help from Mwahab (thank you) and some messing around with the settings, i finally figured out how to get this to work with the Automatic and all light settings (Automatic, Off, Parking Lights, Headlamps). Looks like i just needed to set the priority fields. Below is the complete coding needed to get the Rear Light Bars Remapped For Turn Signals and turn off the actual rear corner orange turn signals.
REAR LIGHT BARS REMAPPED FOR TURN SIGNALS
MAPPING_TAGFAHRL_H2_L_PRIORITY > Priority 1
MAPPING_TAGFAHRL_H2_R_PRIORITY > Priority 1
MAPPING_TAGFAHRL_H_L_PRIORITY > Priority 1
MAPPING_TAGFAHRL_H_R_PRIORITY > Priority 1
MAPPING_STANDL_H1_L_PRIORITY > Priority 3
MAPPING_STANDL_H1_R_PRIORITY > Priority 3
MAPPING_STANDL_H2_L_PRIORITY > Priority 4
MAPPING_STANDL_H2_R_PRIORITY > Priority 4
Turn off L/R Rear Orange Turn signal
MAPPING_BLINKER_H_L_PWM_LEVEL_1 > 00
MAPPING_BLINKER_H_L_PWM_LEVEL_r > 00
      05-14-2018, 01:32 PM   #59
doodlebro
Drives: '17 X3 35i
Any insight as to the coding for those of us with an FRM/TMS module combo?
