BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Engine oil measurement stopping at 15-17%
Extreme Power House
      05-04-2017, 09:11 PM   #1
harkes
harkes's Avatar
China
244
Drives: M135i, NSX and AE86
Hi
UPDATE: It's not because of the below valve, but because the oil does not have the right temperature that the measurement stops at 15-17%. Oil temp must be between ~65 and 100C and as operating temp is 110-115C the level must be measured during warm up (pretty stupid and even more so that no information is provided in iDrive)...
IF the measurement still does not work, the next step would be to check the below valve for functionality.
I have been having this issue for a while but finally decided to do something about it.
A bit of research revealed that the problem most likely is this valve (which I can now confirm): Hydraulic valve 11417622768
1: Disconnect battery
2: Remove undertray
3: Remove 3pc screws for waterpump
4: Disconnect waterpump and valve
5: Remove 1pc screw for valve
6: Turn valve 90 CCW (then you can get a finger behind it) and remove
7: Exercise valve/check function with 12v
8: Reinstall and see if it now works
bootmod3 and JB4'ed M135i PWG
(A Dane in China)
      05-04-2017, 09:41 PM   #2
harkes
harkes's Avatar
China
244
Jason Move to Maintenance section perhaps?
(A Dane in China)
      05-06-2017, 01:01 AM   #3
harkes
harkes's Avatar
China
244
Update
I found that the oil has to be between 65 and 100 degreeC for my car to measure it. Below the measurement will not start and above it stops at 15-17%. Nothing wrong with the mechanics probably.
(A Dane in China)
      06-28-2017, 12:44 PM   #4
heartwork
Romania
Drives: 2013 BMW F30 335ix
Originally Posted by harkes View Post
Update
Where did you find that oil measurement above 100 degrees C will stop at 15%-17% ?!?
Where did you find this information? From a BMW dealer or service or there is some documentation that you found ?
Thanks
      09-07-2017, 03:26 PM   #5
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
maybe if everybody can try that, mesure oil level at 120 degrees C , my car does the same thing, it will stop between 15-17% above 100 degrees C.
      09-07-2017, 08:48 PM   #6
harkes
harkes's Avatar
China
244
Thanks
Tested it myself. Would be cool if you tested it too! 100C = 212F.
(A Dane in China)
      01-08-2018, 10:27 PM   #7
TheBreeze
Drives: '08 e92 M3 (Silverstone II)
Interesting. I was having the same problem, measuring would stop at 15%. I let the car cool a bit, oil gauge at 160, and it worked perfectly. Very odd indeed.
