BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY| F31 LCI Retrofit
      09-02-2017, 01:38 AM   #1
jdr78569
jdr78569's Avatar
79
Drives: F31 328d sport wag
Installation Date : 02 September 2017
I know people have already retrofitted LCI's in F30's and F31's. I just haven't seen a DIY for the F31, so id like to contribute to the forum.
NOTE: Like any DIY project, proceed at your own risk. I am not responsible for anything that happens to your vehicle as a result of attempting this retrofit. This information is simply posted as a reference to help others who may wish to do this project on their own.
Parts -
LCI Tail light set (inner and outer)
F31 retrofit cable
Tools-
plastic trim removal tool
phillips screw driver
flat head screw driver
small flat head screw driver
Ratchet - 10mm & 8 mm (deep socket preferred)
T bits- T20 T27 (lost my T25 but T27 worked)
wire hanger
tape
OEM wire tape
Time - Took about 2.5 hours (to include pictures and info for DIY) + coding time
**Ensure all doors/windows are unlocked prior to disconnecting battery
Remove panels and covers.
-Use trim tool to remove plastic rivets.
-Use 10mm to remove plastic bolts
Remove tray over battery
- Disconnect negative
Remove light trims and bolts
Disconnect inner light connection
Remove outside tail lights by pulling straight out
Disconnect connection from outer light
Remove clip
Use small screw driver and remove pins
Reroute pins and repeat on other side
Remove inner lights
Remove pins and reroute
Use a hanger ( I wrapped end with tape to avoid scratching) to route cable to passenger side
*Might have to connect battery to open/close window and tailgate
Remove T screw
Pop out plastic (3 clips) and remove rubber at top
Use hanger to route up the wires up
Route wires through rubber sleeve and inside
Route wires with harness to REM
Tap LCI wires into REM 12B & 14B
Driver Side REM A174*12B - Tap into 17
Passenger Side REM A174*14B - Tap into 12
Test lights prior to reassembling
Coding is preferred to avoid bulb warm up test. I activated rear fogs and got a warning on the idrive. After coding it was cleared. :thump:
Hope this helps other and motivates them for a great upgrade.
Used Imgur for uploading pictures.
      09-03-2017, 12:50 AM   #2
jdr78569
jdr78569's Avatar
79
Just cuz my GoPro took random shots.
      09-06-2017, 08:44 PM   #3
Johnny250
Drives: 328d Wagon
wow.. bravo!
      09-06-2017, 08:56 PM   #4
jdr78569
jdr78569's Avatar
79
Originally Posted by Johnny250 View Post
wow.. bravo!
Thanks bro!
      09-07-2017, 01:33 PM   #5
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Damn bro, you're making wanna do mine lol.
Did my post help? Click "Appreciate!"
F30 328i xDrive Sport Line | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | DINAN Sport Tuner | Integral Audio | Retrofit: 522 & 524 EDM | 5AC HBA | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB
      09-07-2017, 10:33 PM   #6
jdr78569
jdr78569's Avatar
79
Do it! No balls before u start up with the X3 lol
      09-07-2017, 10:59 PM   #7
LiquidMercury
Drives: 2012 F30
Nicely put together, bud.
      09-08-2017, 09:51 AM   #8
jkwhar
x5* and already started tearing apart yesterday to install a 2ch dashcam haha.
      05-10-2018, 05:29 PM   #9
SQUARETIP
Drives: 320D M SPORT TOURER
Its an F31. Ive ordered some Posi tap connectors so I can slice into the OEM wires without causing much damage. Can I get away without having to remove the pins on the wires Ill connect to the outers or will I have to cut them off?
