BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F31/F30 Surround View Retrofit (5DL)
European Auto Source
      09-03-2017, 03:47 AM   #1
jdr78569
jdr78569's Avatar
53
Drives: F31 328d sport wag
Installation Date : 28 July 2017
First things first. Mad shout out to jkwhar for helping me with the finishing touches
I used Roxxor's and hrvojehk DIY for parts and references. Since the pics are gone I had to figure it out. My car already had front and rear PDC
http://f30.bimmerpost.com/forums/sho....php?t=1130598
http://f30.bimmerpost.com/forums/sho...0&postcount=39
NOTE: Like any DIY project, proceed at your own risk. I am not responsible for anything that happens to your vehicle as a result of attempting this retrofit. This information is simply posted as a reference to help others who may wish to do this project on their own.
Parts :
-Surround view control unit
-Surround view HSD
-Fillister head screw x 4 07149166316
-Center Console Switch 61319252913
-Bumper repair kit 51117324343
-Front bumper camera x2 66539240352
-Mirror camera housing (Left & Right)
-Mirror screws 51167284135
-Mirror cable x2 61129281712
-Custom FAKRA Cable x2
Tools: See other lists, don't recall every tool but i did use other items to help
- pipe cleaners
-cable ties
-OEM bumper cutting tool
I apologize i did not take pictures every step of the way. Doing it in the GA heat makes you want to hurry up
You can start on any side first (Passenger bumper, passenger door, driver bumper, driver door).
Remove front bumper.
I removed it and placed it on a padding to avoid scuffs. At this time I also installed the LED fog lights.
I used the OEM PDC cutting tool to make perfect holes :thump:. Installed the front bracket and camera.
I plugged the cable to the cameras and routed them upwards. I then reinstalled the front bumper.
Next moved onto the mirrors.
I removed the door panel and speaker trim.
I remove the T-30 bolts that holding the mirror and removed the mirror.
I brought the mirrors inside to disassemble and do some prep work.
I wrapped the HSD cables in OEM loom tape to make it as factory as possible (not required)
I removed the custom cable plastic connectors, you will not be needing them.
Once mirror is disassembled you'll need to bore out the circle hole. This is where the mirror cable goes through. I believe it was a 1/4 bit.
Start small and keep working u on bits and fitting it till it locks in *click*
Install the camera to the mirror camera housing and route cable. Reassemble mirror and install back on door.
Route the custom cable with the door harness. Ensure you keep track of the connections so it works. Route and wrap the cable along the harness.
Push the connector till it locks in
Be sure to plug in cable and test to ensure its plugged in correctly
Warning: Routing the cable through the door is a pain in the A. Also working on the inside of the car to the door slot. FYI. Re assemble door panels once you verify the connections are the same.
*The custom cable; I connected it to the mirror straight on. When it Comes to the inside to the door part you will have to rotate it and trim the corner down to the angle. FYI
Repeat this for the other door.
Next I moved onto the floor. I removed the plastics under the driver and passenger side.
I replaced the current module with the surround view module on the driver side top left corner.
Right next to the module along the firewall you will see a big black rubber grommet where the wires go through.
There is a few small pre-holes for repair wires. You'll have to puncture through so the bumper camera wires go through. After I routed the from bumper wires through i secured them with zip ties along the harness.
Also be sure to seal the firewall with sealant to prevent water or anything to go through later.
Same with passenger side. Locate the rubber grommet. Route passenger cable along inside harness.
I then removed the AC trim to route the wire through. This is where I used the pipe cleaners
Route and tuck under the black air vents. Then route it down the left side of the vent ( you will see a hole down to the driver floor mat)
Route all cables to the surround view module and secure the cables.
Once all assembled.
Coding is the last thing. VO Code 5DL
My camera
I then used ISTA to recalibrate the cameras. The front bumper worked but the mirrors did not. my TRSV didn't have the CAFD so that was next. After having to inject the CAFD folder I was able to get my mirror cameras calibrated. :thump:
      09-03-2017, 06:00 AM   #2
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
You got balls of steel, great job/write up.
Regards
Evdok
      09-03-2017, 08:17 AM   #3
jdr78569
jdr78569's Avatar
53
Haha thanks!! Wasn't the first and won't be the last I'm sure. It wasn't all that hard honestly. Hardest thing was the coding, since it was my first at it for anything. But with help I figured it out. Then moved onto FDL coding
      09-03-2017, 03:28 PM   #4
kevinm03
Ireland
Drives: 2016 F36 430d
Great write-up! Where did you source the HSD cables?
      09-03-2017, 09:08 PM   #5
jdr78569
jdr78569's Avatar
53
I ordered them from tuner motor sport, I've seen people sell the cables on eBay. But when I was looking it was more expensive that way. It's easy to make the wires. But hard part is finding the end that goes to the camera. I've tried searching for it but no luck.
      09-07-2017, 01:34 PM   #6
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Nice write up!
Did my post help? Click "Appreciate!"
F30 328i xDrive Sport Line | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | DINAN Sport Tuner | Integral Audio | Retrofit: 522 & 524 EDM | 5AC HBA | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB
      09-07-2017, 03:47 PM   #7
G4Z808
G4Z808's Avatar
Drives: not yet
How much did all the parts set you back ?
      09-07-2017, 10:31 PM   #8
jdr78569
jdr78569's Avatar
53
Originally Posted by jkwhar View Post
Nice write up!
Just doing my part for the community ?
After selling a few parts to recuperate funds; so far I'm at 330 still have a few things to sell. Im fixing to put up some mirror cams.
      09-13-2017, 02:45 PM   #9
cjsansom
Drives: 2012 F30
Originally Posted by jdr78569 View Post
So Surround view thinks BMW's look like Mini-Van's from above??
      09-13-2017, 02:47 PM   #10
jdr78569
jdr78569's Avatar
53
LOL they should have at least put the pano sunroof on the F31
      09-13-2017, 10:48 PM   #11
steelerfan
steelerfan's Avatar
81
Drives: F30 335i Msport 6MT F25 X3.35
Thanks for posting.. i need to make the time to finish this project i bought all the stuff over a year ago
OEM 437M Wheels | Dinan Exhaust & CAI | MPE: Front Aero Lip | Rear Diffuser | Rear Spoiler | Interior trim | Red Brakes |
Click here to see my entire Build Thread
      09-14-2017, 07:29 AM   #12
jdr78569
jdr78569's Avatar
53
What's holding you back? Doesn't have to be all at once. I did the front bumper 1 day and mirrors and wiring another.
      01-06-2018, 01:19 PM   #13
Diljee
South Africa
Drives: BMW 2015 F32 420d Msport
Parts :
-Surround view HSD
- pipe cleaners
-cable ties
Once all assembled.
My camera
Hi,
I have an issue with my rear camera install. I have the parking lanes and the obstacle identification which works, however, I get a rear camera failure error. After checking with Rheingold, it says the cable might be damaged. The problem is, the camera pinouts are the same as what roxxor quoted as this is an OEM cable which I bought from a scrap yard. I tested the continuity and all is fine. Basically all works fine except there is no image from the camera on the iDrive. I also noticed my i-Step file is not available when trying to inject the CAFD file to the TRSVC. How do I get the same CAFD file in the TRSVC list
